ok1rp Posted September 6, 2020 Share Posted September 6, 2020 Hi all, does somebody have tip or hint for memory extension on 800XL please? Thanks Petr Quote Link to comment Share on other sites More sharing options...
xrbrevin Posted September 6, 2020 Share Posted September 6, 2020 there are many options depending if you have soldering skills, do you want extra ROM slots too.. check the profile of user: @tf_hh check lotharek's site a device called 'antonia' replaces the CPU and gives you selectable RAM and ROM versions/types there are others that give you a fixed 256k, 320k, 576k, 1088k but the more modern upgrades allow you to select between any of these. Quote Link to comment Share on other sites More sharing options...
archeocomp Posted September 6, 2020 Share Posted September 6, 2020 (edited) If you want 256kB XE compatible, I could send you one. Check also Igi's site http://blog.3b2.sk/igi/search.aspx?q=rozšírenie I believe Ctirad has still one left https://atariage.com/forums/topic/162420-ram-320xl/#comments Best would be to produce a new batch, so if you can catch him in Prague... Edited September 6, 2020 by archeocomp Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted September 6, 2020 Share Posted September 6, 2020 Ultimate 1MB from Lotharek - 1 megabyte of additional RAM configurable several different ways; built in SpartaDOS X; built in real-time clock; user selectable slots for four different OS ROMs; user selectable slots for four different 8K BASIC versions or any other simple 8K ROM image; if you use an XEGS operating system, you also get four more slots for the XEGS built-in game (not just Missile Command). If your 800XL has the OS ROM and MMU in sockets, the installation requires only four wires to be soldered. 2 Quote Link to comment Share on other sites More sharing options...
ClausB Posted September 6, 2020 Share Posted September 6, 2020 (edited) Or go old school and build it yourself: https://atariage.com/forums/topic/122470-ram-upgrade-applications/?do=findComment&comment=1481893 Edited September 6, 2020 by ClausB 1 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted September 6, 2020 Share Posted September 6, 2020 Alternatively, you can get the latest incarnation of the Turbo Freezer 2011 cartridge, which, among many other features, provides 512K of additional system RAM (giving 576K total). It plugs into either the PBI or Cartridge Port + ECI. So, no modifications are required on the machine -- except PBI 5V mod for power on the 800XL, which is a single wire mod. Here's the original Turbo Freezer 2011 thread, which gives some basic details of the cart's features. Quote Link to comment Share on other sites More sharing options...
Mathy Posted September 6, 2020 Share Posted September 6, 2020 Hello Petr If you are new to the Atari or getting back in after many years, forget about the Ultimate 1MB. Get acquainted with the Atari first, then look at the U1MB. Sincerely Mathy 1 Quote Link to comment Share on other sites More sharing options...
BillC Posted September 7, 2020 Share Posted September 7, 2020 (edited) You may also want to consider the SYSCHECK 2.2 for RAM expansion. It has 512KB that can be configured for Rambo compatible modes, as well as a flashable 4-OS selector and hardware testing. Edited September 7, 2020 by BillC Quote Link to comment Share on other sites More sharing options...
