Synthpopalooza Posted September 8, 2020 Share Posted September 8, 2020 So, one of my compatriots in the 7800 forum came up with this: It's a series of retuned POKEY note tables, in 16 an 8 bit, 64 and 15 khz clocks. The theory is, by changing the base tuning from A4=440 to something else, you can extend note accuracy into the 7th octave. This is an ideal workaround if you are doing music exclusively in $Ax distortion. I played around with this, and I like the ideas. I wonder if this would work in other settings, i.e. $Cx bass plus $Ax leads, or 15 khz $Ax bass plus 1.79 mhz $2x lead. 3 Quote Link to comment Share on other sites More sharing options...
ivop Posted September 9, 2020 Share Posted September 9, 2020 Good to see just tuning is explored! I once suggested something similar in one of emkay's threads. Depending on the key of your song, it could be beneficial to use a different AUDF table. It might even sound more in tune than the original, which was played on well tempered instruments One can vary the A=440Hz variable up and down, and can either tune just or well tempered. Lots of tunings to explore! Maybe I should pick a random .rmt file, determine its key, and reassemble with different frequency tables. Then find the best A to base your just tuning on. Perhaps this could even be automated. Regarding $Cx bass, there is a lot less leeway. But it could be determined which keys are mostly in tune having $Cx bass, and try to match your $Ax table as close as possible. Then create your song in one of those keys Songs that are in a key that's problematic could be transposed to the closest key. Quote Link to comment Share on other sites More sharing options...
emkay Posted September 9, 2020 Share Posted September 9, 2020 (edited) 3 hours ago, ivop said: Good to see just tuning is explored! I once suggested something similar in one of emkay's threads. Depending on the key of your song, it could be beneficial to use a different AUDF table. It might even sound more in tune than the original, which was played on well tempered instruments One can vary the A=440Hz variable up and down, and can either tune just or well tempered. Lots of tunings to explore! Maybe I should pick a random .rmt file, determine its key, and reassemble with different frequency tables. Then find the best A to base your just tuning on. Perhaps this could even be automated. Regarding $Cx bass, there is a lot less leeway. But it could be determined which keys are mostly in tune having $Cx bass, and try to match your $Ax table as close as possible. Then create your song in one of those keys Songs that are in a key that's problematic could be transposed to the closest key. For a lot cases, the 16 Bit resolution of POKEY is the "last saving point for music" . But, if a tune has to be clean from the start to the end, the full control of Pulse Width Modulations is strongly recommended. In theory it offers an 8 bit plus 8 bit resolution and it multiplies with the available offsets that were also about 8 bit plus 8 bit possibilities. If you do the math, it's about a (almost) "32 Bit" resolution. This can vary between full 16 bit sound and added waveforms with approximated "real notes" . It also offers some "magic" Edited September 9, 2020 by emkay Quote Link to comment Share on other sites More sharing options...
