Atari Macro Assembler - Command Line Support for SpartaDOS?
bhall408
Was wondering if anyone had ever added SpartaDOS command line support to Atari Macro Assembler and/or MEDIT?
If not, does anyone know if source code for AMAC ever managed to find it's way to the wild?
With source, I think it would be pretty easy to add it.
Without source, I think you'd patch the existing binary to add support for picking up command line arguments from SpartaDOS, and then calling into/faking out the code that takes the command line after the program runs. ie, shim in new code for command line support, which in turn jumps straight in to wherever the existing code handles the text that is entered from the main menu.
