Dionoid #1 Posted September 10, 2020 Using PlusCart ver. 0.14.15 When I go to Setup and change the TV Mode to PAL (or PAL 60Hz), the mode is changed. However when I turn off & on my '2600, the TV mode is back to NTSC again. It seems like the TV Mode isn't stored? Btw: the new 32-char text is amazing! Share this post Link to post Share on other sites
Al_Nafuur #2 Posted September 10, 2020 35 minutes ago, Dionoid said: Using PlusCart ver. 0.14.15 When I go to Setup and change the TV Mode to PAL (or PAL 60Hz), the mode is changed. However when I turn off & on my '2600, the TV mode is back to NTSC again. It seems like the TV Mode isn't stored? Btw: the new 32-char text is amazing! did you changed the TV Mode very often? Share this post Link to post Share on other sites
Dionoid #3 Posted September 10, 2020 5 minutes ago, Al_Nafuur said: did you changed the TV Mode very often? I think so. Does that affect storing the value? Share this post Link to post Share on other sites
Al_Nafuur #4 Posted September 10, 2020 1 minute ago, Dionoid said: I think so. Does that affect storing the value? The user settings are stored in flash, by an eeprom emulation routine. When the end of the storage is reached it should get erased at the next write event and writing should start from the beginning of the storage again. But there seems to be a bug in this routine Share this post Link to post Share on other sites
Al_Nafuur #5 Posted September 12, 2020 Should be fixed in the new release: @Dionoid it might be that your second next user settings changes (Font or TV mode) do not work as expected, but from then on everything should be fine. Share this post Link to post Share on other sites
Andrew Davie #6 Posted September 12, 2020 (edited) On 9/11/2020 at 5:12 AM, Dionoid said: Btw: the new 32-char text is amazing! The lowercase? Edit: NM I see you mean the change from the 1st text display system to the 2nd Edited September 12, 2020 by Andrew Davie Share this post Link to post Share on other sites
Dionoid #7 Posted September 12, 2020 7 hours ago, Al_Nafuur said: Should be fixed in the new release. @Dionoid it might be that your second next user settings changes (Font or TV mode) do not work as expected, but from then on everything should be fine. Yes, it's fixed now. Thanks! Share this post Link to post Share on other sites
Dionoid #8 Posted September 12, 2020 I wanted to append "FIXED " to the title of this topic, but apparently that isn't supported on this forum. Share this post Link to post Share on other sites
Thomas Jentzsch #9 Posted September 13, 2020 At least the tag is correct. Share this post Link to post Share on other sites
