I bought this a couple of weeks ago and just got around to trying it out.  I had been using my TI with a 10.1” security monitor because it had an AV input.  That was good for testing, but kind of hard on my old eyes.  Tonight I decided to try out the AV2VGA with an old VGA monitor.  The first picture is from the security monitor, the others from the VGA monitor.  Not a bad result for a device that cost less than fifteen dollars.  The dark spot near the center is from the monitor.
Edited by Keneg
Nice, but upside down photos drive me nuts, so I hope you do not mind...
10 minutes ago, OLD CS1 said:
What brand is that AV2VGA; Is that an Onn from WalMart?
I got it from eBay.  Whoever made it wasn’t proud enough to put their name on it.  It looks like the same one that Walmart has.
I have with all the same markings, and it only gives me a black & white picture from the 4A composite output. I only tried it on one console... and then stuck it in a drawer.
But, more importantly, I don't recall seeing a door like that in Tunnels of Doom.
Don’t know why it would’ve give color.  Maybe yours is defective.  I am playing the King scenario.
It is a common problem with devices which do not sync properly to the composite output of our classic machines.  Stipulating the chipset of @jedimatt42's unit is the same as yours, I would speculate the console output is slightly out-of-spec due to the 10MHz crystal.  I posted the link elsewhere to a blog entry where the author describes how the 10MHz crystal was out of spec enough to cause the color burst to look fine in an oscilloscope but cause the converter to only sample luminance.
Nice I use a HDMI version Keneg. Works great on a old Flat Screen Monitor.
None of my old 4:3 aspect monitors have anything other than VGA.
All but a few of mine have DVI.  However, not all HDMI converters output a signal which is handled by the DVI monitors.  More pain.
So could this be fixed with a crystal change without affecting the rest of the computer?
Interesting article.  If he had his scope on the same setting each time, it looks like the frequency was too high before he changed the crystal.  It is about 3 divisions to start and about 3.3 after the crystal change.
I thought it was just a different Russian ti knock off. Man...
Nah, the original photo was of an Australian model.
  • Haha 1
