Sign in to follow this
BillG
Cycle counting question
Please reference Chapter 4 of https://ia800307.us.archive.org/10/items/9900MicroprocessorSeriesFamilySystemsDesignDataBook/TexasInstruments9900MicroprocessorSeriesFamilySystemsDesign_text.pdf
Starting with page 4-89 and particularly pages 4-91, 4-92, 4-95 and 4-100
The following code sequence appears to take 29 machine cycles:
    mov     @Var,R0          ; 11 cycles
    ai      R0,2             ; 7 cycles
    mov     R0,@Var          ; 11 cycles
While this only takes 9:
    inct    @Var             ; 9 cycles
Am I correct?  If so, there would appear to be plenty of opportunities for a compiler to optimize code like this.
You are correct.
Which compiler is generating the first code?
I guess my cover is blown, so...
I have been working on compilers for the 6502 and 680x among other processors.  I just started to attempt code generation for the 9900.
It appears that adding a value from 1 to 6 to a variable can be optimized; likewise for subtracting a value from 1 to 6.
Cool.
The 9900 has that interesting memory to memory architecture so a lot of ideas that are used for 6502 or 68xx uPs have to be re-thought. :)  (Had a commercial project on 68HC11 years ago)
You can also apply the INC/DEC instructions to arrays with indexed addressing mode. So pretty powerful instruction set.
What language are your compilers for?
Python on the 6502
BASIC on the 6502, 6800 and AVR
Pascal on the 6502, 6800, 8080, AVR, 68000 (maybe 9900)
COBOL on the 6800 (started as a joke)
Not very big right now.  The only things I have working is DISPLAY and PERFORM.
PERFORM is rather complicated if you know COBOL.
Only at the syntax level. Never thought about internals.
Why is a COBOL sub-routine call complicated?
6 minutes ago, BillG said:
You can PERFORM something THROUGH something else, so they are not like standard subroutines.
https://www.ibm.com/support/knowledgecenter/en/SS6SG3_4.2.0/com.ibm.entcobol.doc_4.2/PGandLR/ref/rlpsperf.htm
Wow.
Mind numbing complication for a simple idea.
But hey I write in a language that has no syntax so what do I know.  :)
Thanks for the link.
32 minutes ago, BillG said:
Python on the 6502
Very nice collection.  I first read this as "COBOL on the 68000."  I used a COBOL compiler on my Amiga in college.  Worked well enough until I had to start using RM*COSTAR.
A complication: I was somehow under the impression that the 32K RAM card in the PEB was 16-bit memory, but it is 8-bit.
The TI documentation says three machine cycles for a memory access.  Now I read about a 4-cycle penalty due to the 8-bit bottleneck.  Four and not three.  So is the total 7 cycles or is there an extra wait state on both bytes for a total of 8?
Cycle counting is further complicated by whether the Workspace is in fast or slow RAM.
I guess our cover is blown! 🙂
Ya totally sucks doesn't it.  If you are using the TI-99 "O/S" as it were you are best to treat the 256 bytes of 16 bit RAM with kid gloves.  There are about 120 ish bytes at the top that you can use.
For example in most Forth systems the workspace is at >8300. So at least the primary registers are in fast ram.
The reason by the way is that the machine was originally designed for the TMS9995 which was like the 8088.  16 bits internal with an 8 bit buss for cheaper memory parts usage.
The 9995 wasn't ready in time and so a shoehorn was applied for the 9900... and the rest is ... our life now. :)
My cross assemblers for most other processors offer an option to display the number of machine cycles each instruction uses.
My 9900 one does not attempt doing so due to the complexity of calculating it and that was not even taking 8-bit delays into account.  It is so helpful that I may still attempt it.
The intention was to use the TMS 9985, but that didn't get ready in time. The TMS 9995 came later. When it was ready, the Home computer was already cancelled.
The TMS 9900 does a memory access in two cycles. But if it accesses the memory expansion, or rather anything outside the 256 bytes RAM or the 8 K monitor ROM in the console, it accesses that memory byte by byte, adding a wait state for each byte. So instead of two cycles, a memory access is six cycles.
Thus an assembler can't really know the cycle count, since it doesn't know where the code and the workspace is located. The same software will also behave differently, depending on the machine. My main console has 16-bit wide (two cycle per access) memory for the memory expansion, so it runs faster than a standard TI 99/4A.
There are also different additions depending on the addressing mode used, but they can be calculated, as they are consistent.
Starting with page 4-89 and particularly pages 4-91, 4-92, 4-95 and 4-100...............................
I think you are in the 9940 section. On page 8-23 of that book we find:  "TMS 9900 INSTRUCTION EXECUTION TIMES"
Your jaw will drop when you see the number of clock cycles each instruction uses.
A simpler way is to assume the workspace is in fast memory and everything else is in slow memory.
Unfortunately, the tables in the manual do not separate workspace accesses from everything else, so I will have to figure those out.
You are right.
Jaw dropped...
One access for the instruction, one for any immediate, one for any symbolic or indexed address (two if it's a destination, like in A @SOURCE,@DESTINATION). The rest are registers.
Consider the case of
    inc     @I
The documentation says 10 base cycles, 3 memory accesses and Table A says 8 additional cycles and one additional access for symbolic mode.  The operand is listed as the source instead of the destination.  None of the memory accesses is workspace.
That makes sense. Read instruction, read destination, write to destination. Three memory cycles. When the address is symbolic, you need to read the address too, so one more memory cycle for symbolic (and indexed).
Even though it is a challenge and I love a challenge, I am getting somewhat discouraged about trying to generate good code for the 9900.
Are any of the emulators accurate in counting machine cycles?
I forgot that I also started PL/M compilers for the 6800 and 6502.
That sounds ambitious too.
MAME precisely executes the operations with all cycles as in the tables. To see the cycles, however, you'll have to set a flag and recompile.
