VIC-20 Keyboard Mostly not working
johndias
Hi all, my new power supply from Ray arrived today so I got a chance to boot up for the first time.
System comes up, no problem, but the keyboard ... probably 80% of the keys don't work.  I had pulled them and cleaned them while I was retrobriting the case (and lost one spring - anyone got a spare?).
I saw another thread @carlsson recommended swapping the 6522 chips, which I will do. What else can I check?
Is there a pattern to which keys are not working? Like it was mentioned in the other thread, every second key worked and the rest didn't. If you have a massive fail of up to 80%, sure it could be a toasted 6522 but it makes me wonder what other causes it could be.
In case you own a C64, the keyboard is mechanically (*) and electrically compatible with the VIC-20 one so you could swap keyboards to rule out sources of error.
(*) The white C64C keyboard may have different mounting points so it would be difficult to fit physically, but loose out of the case it works the same way.
I pulled the keyboard PCB out and cleaned it with IPA. Then I plugged it back in and used a wire to jump the contacts to see if that would respond. The keys did (I didn't do a complete test but enough to convince me that I had a mechanical problem).
Then I took a plunger (the commodore key) and used it to connect each of the contacts. No bueno, the key presses did not show up. So, I think my plungers are bad, what to do? These are NOT the rubber dome ones but rather like this one
There's no pattern, that I can determine. The working ones are scattered about.
Oh man, rookie mistake! Short story, while I thought the contacts were clean I put them under my microscope and realized there was corrosion on most of them. So, with extra diligence I cleaned them all up and for kicks tested the resistance on all of the plungers (they were all around 100 ohm which I guess is good?) and tested - all the keys work!
Well, except for the Commodore key, for which I lost the spring. Anyone know where I can buy one?
Just now, evg2000 said:
cool!
what did you use to clean off the corrosion?
IPA and a paper towel. I think the problem before is that I was using a non-cotton fiber swab like the ones here and it wasn't doing much scrubbing. They're great for general grime and cleaning tape and disk heads, though.
3 hours ago, carlsson said:
Probably someone has spare keyboards in parts from where you could source a spring if that is all you're missing. I suppose measuring an existing one might allow you to find somewhere selling springs only, though I don't know if hardware stores have that.
I've had to match springs before, it's challenging. There are online places that sell springs. That's my last resort, I'm hoping to find a kind soul with a spare VIC-20.
