HDTV1080P
TOP OF THE LINE 60 WATT ATARI 5200 VIDEOGAME SYSTEM POWER SUPPLY (ALSO COMPATIBLE WITH THE ARCADIA-2001)
Question: One of my original ATARI 5200 CO18187 power supplies was made in Korea, and has a label on it that says it outputs 9.3 volts DC at 1.95 amps. The other ATARI 5200 CO18187 (also called CX-5200 or DV9319A) power supply that was made in Taiwan, has a label on it that says it outputs 11.5 volts DC at 1.95 amps. Why does this third-party ATARI 5200 compatible power supply that is made in China, have a label on it that says it outputs 12 volts DC at 5 amps?
Answer: The original ATARI 5200 power supplies used lower quality and lower price unregulated DC power supply designs with incorrect voltage levels placed on the ATARI 5200 power supply labels. These incorrect voltage levels printed on the unregulated ATARI 5200 power supplies might have been done by mistake or on purpose (Perhaps for marketing reasons so that no one attempts to use a third-party power supply on an ATARI 5200 videogame system). I have measured the no load voltage and full load voltage on at least 4 different official ATARI 5200 CO18187 unregulated videogame system power supplies. For example, on the official Atari 5200 CO18187 power supply that is made in Korea, that ATARI 5200 power supply label claims it outputs 9.3 volts DC. However, on the official 9.3 volt DC ATARI 5200 CO18187 power supply the actual no-load voltage is really around 14.97 volts DC and when measured under a load the voltage measured around 12.64 volts DC (Similar results occur with all unregulated ATARI 5200 CO18187 power supplies, including the ones with a 11.5 volt DC label). What this means is that the ATARI 5200 videogame system when under a load requires a 12 volt DC power supply with a minimum of 1.95 amps output. This high-end made in China third-party power supply for the ATARI 5200 outputs a regulated 12 volts DC at up to 5 amps (Will normally output 1.95 amps but the extra amps might be required for future hardware accessories like graphics cards or other items that might plug into the expansion port). For example, with this high-end third party 60 watt ATARI 5200 regulated power supply the no load voltage measures around 12.33 volts DC and when measured with a load the voltage measured around 12.09 volts DC. Also, this power supply has excellent short circuit protection and uses some of the best electronic components in the industry.
Question: What is the best power supply to use with the ATARI 5200 videogame system and Emersion Arcadia- 2001?
Answer: The high-quality top of the line power supply made in China called the Chanzon which is 60 watts 12 volts with 5 amps is the best power supply for use with the ATARI 5200 videogame system. This Atari 5200 compatible power supply can be purchased from Amazon directly for around $14.99 to $15.99 with free shipping (prices can change daily). Yes there are some 3 prong 12 volt 5 amp power supplies that cost around $25-$35+ that will also work with the ATARI 5200 videogame system. However 3 prong power supplies are not compatible with the Emersion Arcadia-2001, only two prong power supplies. One of the main advantages of the Chanzon power supply is the over 20+ worldwide safety certifications including the required energy efficiency level VI. Also the Chanzon power supply uses a self-adapting DC port, it automatically adjusts to both 2.1mm and 2.5mm Power Inlets perfectly. The ATARI 5200 requires a 5.5mm outside x 2.5mm inside plug. The Arcadia-2001 requires a 5.5mm outside to 2.1mm inside plug. Therefore, since the Chanzon power supply uses a state of the art self-adapting port for both 2.1mm and 2.5mm, this means the plug makes a perfect fit with both the ATARI 5200 and Emersion Arcadia-2001 videogame systems.
*** I used two separate Chanzon 12 volt DC 5 amp power supplies on both a ATARI 5200 4 port and ATARI 5200 2 port videogame systems. Both ATARI 5200 systems were running 24 x 7 for over a month using a stress test program and also once and awhile playing real videogames. The Chanzon is a high-end power supply that is the best power supply for use with the ATARI 5200 videogame system. ***
Voltage test results in regards to the 3 different ATARI 5200 power supplies on the market when compared to the high-end Chanzon power supply
The ATARI 5200 power supplies made in Korea appear to be lower quality when compared to the ATARI power supplies made in Taiwan, plus the stated label voltage on the ATARI power supplies made in Korea is way off from actual voltage (but the advantage of the Korea made power supplies is that they have screws on the bottom to open and close the power supply). I had one brand new in the box ATARI 5200 power supply that was made in Korea, and the power supply went dead after 1 hour. This can be expected to happen to any brand new ATARI 5200 power supplies that have been sitting in the box for around 38 years.
Detailed voltage test results while using an ATARI 5200 4 Port videogame system
ATARI CO18187 (DV9319A) (claimed output voltage is 11.5 volts DC, which is wrong): Real world no load voltage 14.70 volts DC, Voltage measured when ATARI 5200 off and connected to the 4 port TV game switch was 13.86 volts DC, voltage when ATARI 5200 4 port videogame system is under a full load measures 12.10 volts DC.
ATARI CO18187 (CX-5200) (claimed output voltage is 11.5 volts DC, which is wrong): Real world no load voltage 14.25 volts DC, Voltage measured when ATARI 5200 off and connected to the 4 port TV game switch was 13.56 volts DC, voltage when ATARI 5200 4 port videogame system is under a full load measures 11.97 volts DC.
ATARI CO18187  (claimed output voltage is 9.3 volts DC, which is a big error on label): Real world no load voltage 14.97 volts DC, Voltage measured when ATARI 5200 off and connected to the 4 port TV game switch was 14.14 volts DC, voltage when ATARI 5200 4 port videogame system is under a full load measures 12.57 volts DC.
ATARI 5200 compatible Chanzon power supply (claimed output voltage 12 volts DC):  Real world no load voltage 12.33 volts DC, Voltage measured when ATARI 5200 off and connected to the 4 port TV game switch was 12.32 volts DC, voltage when ATARI 5200 4 port videogame system is under a full load measures 12.07 volts DC.
Detailed voltage test results while using an ATARI 5200 2 Port videogame system
ATARI CO18187 (DV9319A) (claimed output voltage is 11.5 volts DC, which is wrong): Real world no load voltage 14.70 volts DC, Voltage measured when ATARI 5200 off and connected to the 2 port motherboard was 13.81 volts DC, voltage when ATARI 5200 2 port videogame system is under a full load measures 12.22 volts DC.
ATARI CO18187 (CX-5200) (claimed output voltage is 11.5 volts DC, which is wrong): Real world no load voltage 14.25 volts DC, Voltage measured when ATARI 5200 off and connected to the 2 port motherboard was 13.56 volts DC, voltage when ATARI 5200 2 port videogame system is under a full load measures 12.14 volts DC.
ATARI CO18187  (claimed output voltage is 9.3 volts DC, which is a big error on label): Real world no load voltage 14.97 volts DC, Voltage measured when ATARI 5200 off and connected to the 2 port motherboard was 14.12 volts DC, voltage when ATARI 5200 2 port videogame system is under a full load measures 12.64 volts DC.
ATARI 5200 compatible Chanzon power supply (claimed output voltage 12 volts DC):  Real world no load voltage 12.33 volts DC, Voltage measured when ATARI 5200 off and connected to the 2 port motherboard was 12.32 volts DC, voltage when ATARI 5200 4 port videogame system is under a full load measures 12.09 volts DC.
*** This is a top of the line 60 watt Desktop style power supply for the Atari 5200 and North America Emersion Arcadia-2001 videogame system. This power supply has excellent build quality. ***
  • Worldwide International power cords for United Kingdom, Europe, Australia, and United States of America (Accepts AC voltage between 100-240 Volts at 50/60Hz).
  • High-end 60 watt 5 amp Desktop style power supply will output 12 volts at up to 5 amps maximum (when used on the Atari 5200 will output the proper 1.95 amps. When used on the Emerson Arcadia-2001 will output the proper 0.5 amps).
  • Combined power cord length is a total of 9 feet (273cm): AC Power cord 5 feet (150cm) plus DC Power cord 4 feet (123cm).
  • High-quality Ferrite Bead on power cable eliminates or greatly reduces EMI/RFI noise.
  • UL and FCC certified supply (UL safety certificate number E161451).
  • Efficiency Level VI certified by the Department of Energy (DOE)
  • High Quality 120uF Capacitor with High-quality Transformer (Plus Cooling and Protection System)
  • Anti-interference technology
  • Current Overload Cut-off | Automatic Thermal | Short Circuit Protection | High Efficiency | 40 x 0.15mm 100% Copper Power Cord with USA 2-prong Plug | Easy Install | 12 V Constant Voltage | Low fever & No Noise | Full Wattage 60 W | Long Lifespan | High Quality Shockproof Retail Packing Box | Secure Black Plastic Case with LED
This is a factory new 100% compatible power supply for the Atari 5200 and North America Emerson Arcadia-2001. This is a high-end replacement power supply for the Atari 5200 and Emerson Arcadia-2001. This power supply is better quality when compared to the original Atari 5200 and Emerson Arcadia-2001 power supplies. This power supply will output 12 volts at up to 5 amps maximum, however when used on the Atari 5200 will output the proper 1.95 amps, and when used on the Emerson Arcadia-2001 will output the proper 0.5 amps.
This power supply is legal to sale and use anywhere in the world since it contains over 20+ worldwide Safety Certifications
  • Safety Certification : UL-Listed (USA) / FCC (US) / CE (Europe) / GS (Germany) / TUV (Germany) / PSE (Japan) / CCC (China) / EAC (Russia) / BSMI (Taiwan) / TECT (Ukraine) and etc.
  • Level VI Energy Efficiency : Meet the Requirements of US Department of Energy (DOE6), Will Save 10%-15% ($2-$3) Charge for Electricity per year under Normal Use.
Questions and Answers
Question: What videogame systems is this 60 watt power supply compatible with?
Answer: This power supply is 100% compatible with the Atari 5200 videogame system and the Emersion Arcadia - 2001 videogame system. Power supply is 100% compatible with both the 4 port and 2 port Atari 5200 videogame systems.
Question: How does the quality of this third party 60 watt power supply compare to the original Atari 5200 power supplies and the original Emersion - Arcadia 2001 power supply?
Answer: This third party power supply is better quality when compared to the original ATARI 5200 and the original Emersion Arcadia - 2001 power supplies. This high-quality top of the line third party ATARI 5200 power supply is a regulated power supply that works anywhere in the world. The original ATARI 5200 and Emersion Arcadia - 2001 power supply only works in North America. This third-party high-end ATARI 5200 power supply is a regulated power supply that offers a stable 12 volts DC voltage between 0 amps to 5 amps. This third-party high-end ATARI 5200 power supply contains over 20+ worldwide Safety Certifications and can be used legally anywhere in the world (Also this power supply meets the required Energy Efficiency level VI by the US Department of Energy).This third party power supply has an input voltage of 100-240 volts at 50/60Hz. In addition, there are power supply cord styles offered for almost every country in the world. When used on the Atari 5200 this third party power supply will output the proper 1.95 amps (Also if some company in the future develops a graphics card or some type of plug in expansion module for the ATARI 5200, this power supply will most likely be able to power just about any add on hardware device, since this third party power supply can output up to 60 watts (5 amps) of power). When used on the Emersion Arcadia 2001 this power supply will output the proper 0.5 amps.
Edited by HDTV1080P
  • Sad 1
The above post shows one what the ATARI 5200 power supply looks like when ordering directly from Amazon (plain black power supply with no label). However if one prefers a custom label, then when ordering from a EBAY or Amazon dealer here is what the label looks like on the power supply.
Edited by HDTV1080P
  • Sad 1
10 minutes ago, Shawn said:
Well that was a wall and a half of WTF.
Here ya go, good quality, $2.39 with free shipping.
Didn't even need to go on for a page and a half
preaching to my peers like they are a bunch
of ignorant morons.
Yes that power adapter you posted for $2.39 that is made in China should work on the Atari 5200 videogame system. However that power adapter that is being imported directly from China is in violation of United States law since it does not have the required FCC certification and Energy Efficiency level VI rating from the Department of Energy. Also that adapter is not UL listed, but UL listed is not required and is a optional certification in the United States.
Edited by HDTV1080P
There are Desktop power adapters that cost $25-$35+. The high-end 60 watt 12 volt DC and 5 amp Chanzon for around $14.99 to $15.99 from Amazon with free shipping is a perfect power supply to use with the ATARI 5200 and Emersion Arcadia-2001.
https://www.amazon.com/110V-220V-Converter-Lighting-Transformer-Flexible/dp/B073QTNF9F/ref=sr_1_5?dchild=1&keywords=chanzon+12+volt+dc+power+supply&qid=1600457192&sr=8-5
I am sure if one were to look hard enough they could find a adapter that works for under $10 with the ATARI 5200 that is also FCC and level VI, but then they would lose the perfect auto fit technology that allows the adapter to also work with the Arcadia-2001. Plus getting over 20+ worldwide safety certifications should be worth the extra $5.
Edited by HDTV1080P
I realize I already posted these test results before, but I am posting it again since there was one small typo where I said 4 port instead of 2 port in the last sentence in the original post. One cannot edit their original post after 1 hour at ATARIAGE.
ATARI 5200 compatible Chanzon power supply (claimed output voltage 12 volts DC):  Real world no load voltage 12.33 volts DC, Voltage measured when ATARI 5200 off and connected to the 2 port motherboard was 12.32 volts DC, voltage when ATARI 5200 2 port videogame system is under a full load measures 12.09 volts DC.
Edited by HDTV1080P
  • Confused 1
Ya cause the USA is the only country in the whole world. :roll:  Your postings are straight up madness.
P.S. Those other adapters you are praising? THEY ARE ALL MADE IN CHINA.
There are high-end top of the line power adapters that come off the Chinese automated robotic assemble lines, however there are also low quality products that are made in China without all or most the safety certifications. The original post has a high-end power adapter that is made in China and with 20+ worldwide safety certifications, which makes the adapter legal to use and sale anywhere in the world. That is another advantage of the Chanzon company.
Have seen plenty of examples when doing embedded development of supplies that come into the UK with CE marks but, once opened, just looking at the board you can see it wouldn't have passed.
To be fair, his CV power supply solution is really nice and currently my main PSU for the CV. The one advantage of this 5200 supply he is listing and all of them actually, are that they are switching supplies so quite efficient in their energy use. Also, they don't take up too much space on a outlet strip since they only use a standard 2-prong lamp type cord on the end that plugs into the outlet itself. That is quite an advantage. But for the normal user, the one that @Shawn posted above is also pretty touch to beat for that price.
Also, while he didn't state it, you can use a 5200 PSU to power an Intellivision 2 console as well. Yes...that console originally uses an AC adapter, but like the NES, it has internal rectification of that AC to drop it back to DC anyway, so you can safely use either an AC or DC adapter in that console. Been using a 5200 PSU with my Intelly 2 for testing for well over a decade without issues.
So while the amperage on this bad boy that HTDV1080 is listing is way overkill, it is nice it can produce that much current if needed.
of ignorant morons.
Here's some more fun from this guy a few years back: ATARI 5200 Ultimate SD Wafer Drive (Up to 32GB of storage space)
Edited by MrFish
It's alright, man... there's all sorts of people who enjoy Atari tech stuff- and some of them will write walls of text, and I'd say "more power to ya."
Here's an HDTV1080P topic where it was well-received by all:
Why scoff at somebody who's a 5200 fan? I'm not for doing that, no matter what- even if their content has 100 extra explanatory words that might not have been necessary.
HDTV1080P, you're alright in my book
Edited by ave1
