Sign in to follow this
Omega-TI
Plug & Play - Replacements with possible updates.
Mean Time Before Failure - It's starting to look like this is beginning to effect more and more P-Box power supplies.
Preemptive Maintenance - Fixing the situation before it destroys something else more expensive with it's failure or, puts one out of service.
Plug & Play - Designed so even the least technical people in the consumer market will feel comfortable installing it, ensuring more sales.
Limited Targeted Market - Niche markets, usually have test markets or single runs of a moderate size to keep costs down.
I'm thinking it may be time for "someone out there" to consider a viable Plug & Play replacement for the P-Box power supply.
1 - Could the cost be reasonable? (How much are you willing to spend for an easy replacement to protect your equipment)
2 - Could it be a direct replacement, not requiring any other modifications from the customer.
3 - Could there be "an extra" on the board as a further inducement to purchase?  (Example:  USB power port)
Meanwell makes power supplies with quad outputs and various voltages. Get one that outputs +/-15 and +/-9 at the correct amperage levels and you should be good to go without having to change any of the card regulators. . .
