atrax27407 #1 Posted September 25, 2020 I have some .bin files that I need to change to .rpk files. Is there a utility somewhere to automatically convert them? Or, can someone give me a step-by-step tutorial on how to do it? Quote Share this post Link to post Share on other sites
HOME AUTOMATION #2 Posted September 25, 2020 Hi, I don't know of an automatic utility... probably need a script or the like for that. I've only done this before once or twice, what I would do is... 1. find an existing .rpk file, to use as a test\example.(XB, provided below) 2. rename the file to .zip. 3. de-ark to a folder 4. open the layout.xml with wordpad. 5. change the appropriate filenames under <resources>. 6. change or remove the unneeded entries under <configuration>, intuitively. 7. replace the needed .bin files. 8. re-ark to .zip. 9. rename the file to .rpk. 10 cross fingers, and hope that I knew what I was talking about. ...also edit the other .xml files if desired. I hope this helps, somewhat. Bye. extended_basic.zip Quote Share this post Link to post Share on other sites
mizapf #3 Posted September 25, 2020 Hi Bob, the point is that you have to put some knowledge into the RPK, namely to say how the cartridge handles the dumps. For that reason, an automatic RPK creator could be a bit difficult, but not impossible. Or let's say, I did not invest the time to write an autodetection yet. So if you have the bin dumps, you need to know what kind of cartridge it is. Michael Quote Share this post Link to post Share on other sites
WhataKowinkydink #4 Posted September 25, 2020 I thought RPKs were deprecated...? Quote Share this post Link to post Share on other sites
mizapf #5 Posted September 25, 2020 Not for homebrew cartridges, at least not yet. 1 Quote Share this post Link to post Share on other sites
Asmusr #6 Posted September 25, 2020 I think the majority of rpk files that people want to create today would have the type set to paged378. There seems to be little need to create an inverted cartridge or a specific 2 bank cartridge. Quote Share this post Link to post Share on other sites
