Kchula-Rrit Posted September 28, 2020 Share Posted September 28, 2020 Here are a couple of modules I put together to, hopefully, help with debugging DSR calls. Log output is specified in the calling program, and can be to a disk file or serial/parallel port. They replace DSR calls and log caller parameters and results for Level-2 and Level-3 DSR calls. There are four object files: L2DUMP;O Logs Level-2 DSR calls to a log file or device with descriptions. L2RDUMP;O Logs Level-2 DSR calls to a log file or device as raw hex data. L3DUMP;O Logs Level-3 DSR calls to a log file or device with descriptions. L3RDUMP;O Logs Level-3 DSR calls to a log file or device as raw hex data. The only Ed/Assem dependencies should be DSRLNK and the loader. The object files are rather large, for a TI- 2.5K to 6.5K bytes. I hope these will prove useful. K-R. L23Dump.zip 4 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted September 28, 2020 Share Posted September 28, 2020 Thanks for the interesting test utilities! 1 Quote Link to comment Share on other sites More sharing options...
Kchula-Rrit Posted September 29, 2020 Author Share Posted September 29, 2020 Hope it works out for you! I appreciate you letting me know. Forgot to mention that I have not tried it in a real TI. My console is in pieces at the moment. I wrote it using Fred Kaal's TI99W and TI99Dir, along with VIM in my Win98 system. When I get the console back together I will test it. K-R. Quote Link to comment Share on other sites More sharing options...
Kchula-Rrit Posted October 3, 2020 Author Share Posted October 3, 2020 I have added another file to this package, called DumpRegs, which will print the caller's register contents to a file or device. The ReadMe file is updated as well. K-R. L23Dump-2020-1002.zip 2 Quote Link to comment Share on other sites More sharing options...
