After this little discussion:
it came to my mind that it should be fairly easy to reproduce this effect using mostly VBXE blitter with little CPU intervention, also making it moving. The result is attached (the archive also contains the source code @tschak909).
PS. One of the darkest shades of grey looks blueish. A bug probably.
PS. 2. On Altirra the movement does not look smooth, on real hardware it does. I do not know, why.
landvbxe.arc
It is as smooth as it can get for me, given that in PAL the emulator needs to resample from 50Hz to 60Hz. In NTSC, it is overrunning the frame and dropping to 30Hz due to the huge scroll blit:
By my reckoning VBXE only just barely has enough memory bandwidth to brute-force scroll a 320x240 SR screen in NTSC and not enough to do further rendering. There are 114 * 8 * 262 = 238,944 local cycles per frame, of which 153,600 are needed for the blit and 76,800 are needed for display (overlay) DMA. 153,600 + 76,800 = 230,400, with 8,544 local cycles left over. It might actually be faster to redraw the entire landscape from scratch with a large blit list of lines since the blitter can fill at 1 cycle/byte vs. copy at 2c/b. Hardware scrolling would be much faster than either, though.
Posted (edited)
Whenever I run Altirra, I run it in a window, and it is not smooth then. I forgot about the full-screen option. Running full-screen it is as smooth as on my Atari, so everything is right in this point.
So it seems I have accidentally created my first PAL-only program (also somehow forgetting at that moment that NTSC exists and the blitter may indeed run out of frame cycles doing the blits).
Are hardware scrolls available in VBXE pixel modes at all? The documentation seems to speak of them only as of a feature available in the texmode, but perhaps I get this wrong.
Edited by drac030
Posted (edited)
You don't really need hardware type scrolling in the bitmap modes.
Firstly since it's a byte per pixel there's no fractional value to worry about.
Secondly, the XDL allows you to specify start address of the bitmap and increment value per scanline with little limitation.
So without too much work you could implement scrolling as a measure to free up blit cycles.
Edited by Rybags
That is true, one could just draw with the blitter and change the display memory location within a 150k buffer.
But I will rather not update the program further, it was just a toy for one evening (and next morning), and even at 30 Hz it looks good enough in NTSC (I just checked in emulator). So maybe someone else will implement it better, either from scratch or basing on the source attached to post #1. :)
