Wrathchild #26 Posted October 3, 2020 1 hour ago, rensoup said: Any number of them can be selected. The final color will the be the one with the smallest sum of the distances in YUV space. Usually I use the config above as it seems to give slightly better results than just using one of them. Though sometimes I just use Altirra or Laoo. I think you'd be better off with a single palette selection and ciede distance here Quote Share this post Link to post Share on other sites
emkay #27 Posted October 3, 2020 31 minutes ago, Wrathchild said: I think you'd be better off with a single palette selection and ciede distance here If rensoup did his work, the pictures don't need any palette. Just a color adjustment would be needed. Quote Share this post Link to post Share on other sites
rensoup #28 Posted October 3, 2020 3 hours ago, Wrathchild said: I think you'd be better off with a single palette selection and ciede distance here I tested ciede in RC but I think it gave worse results than YUV. Didn't really investigate... The results I get are good enough most of the time but when they're not it's because translating the C64' softer colors sometimes isn't possible. In that case I replace the original color with one of the from Altirra palette in a paint program to avoid any surprise. Quote Share this post Link to post Share on other sites
rensoup #29 Posted October 4, 2020 5 hours ago, emkay said: If rensoup did his work, the pictures don't need any palette. Just a color adjustment would be needed. You tell that to anybody who uses tables. (hint: EVERYBODY) Quote Share this post Link to post Share on other sites
rensoup #30 Posted October 4, 2020 I may have space for an extra picture on the cart, so I may possibly make another release... Does anybody know of somemusicianbody who could let pick me a tune from their collection ? Quote Share this post Link to post Share on other sites
rensoup #31 Posted October 9, 2020 V1.1 is available ( See First post! ) 2 new pictures and 1 removed so the total is now 20 and the cart is almost fully used! 2nd tune: "Pro BMX sim" by Matt Gray, turned into a pretty cool Pokey-Sid version by Emkay. This tune can take up to 40 scanlines when replayed with RMT but takes only about 10 with LZS 3 Quote Share this post Link to post Share on other sites
