Sign in to follow this
Retro_Game_Lover96
Coleco ADAM TMS-RGB Mod Possible?
12 hours ago, Retro_Game_Lover96 said:
I checked all of the pins from the connector, and they're fine.
Did you also check the plastic ribbon cable?
Voltage check from the internal power supply
V3 (-5V) - -4.6V
+V2 (+12V) - +11.2V
+5V - +4.7V
I used the multimeter black probe to touch the COM on the supply while the red probe touches the V3, +V2, & +5V points.
Edited by Retro_Game_Lover96
14 hours ago, Retro_Game_Lover96 said:
I see, maybe the Apollo power supply for the Adam should do the trick.
But I am not sure it will work better than the internal power supply mod, so maybe I should try it sometime.
As I stated in a previous message, your best option right now is to remove the TMS-RGB and BIOS mod and return the system to it’s original state as you received it when purchased. From there, proceed to testing everything in the steps I outlined.
If it doesn’t work, then you probably got a serious issue.
If it works, then that is a good thing and you can then reinstall the different mods you added like the BIOS mod and the TMS-RGB one at a time and test in between.
Edited by NIAD
Ouch, that didn't work after I remove the TMS-RGB.
I am still mad about this issue, so I tried everything.
3 hours ago, Retro_Game_Lover96 said:
I don’t know what to do.
Maybe it could be the DRAM chips or something. I am not sure.
Unfortunately, if you don't have good testing equipment and knowledge, you may need to send it to someone who has both.  There's only so much we can do with a simple voltmeter, and it would likely take months of back and forth even if we could come up with things to test otherwise.
Alright, and I know it sucks.
eColeco site should have some replacement parts for the ADAM, but some of them aren't pictured.
RIP My ADAM
From the time I got it until it has the black screen problem, but I can't get it fixed. T_T
RIP My ADAM
Check with Jim Walters or William Hicks on the Coleco Adam Facebook group. They probably have extra Adam Logic Boards and CV Delta boards that are known good and could swap them out to narrow down where the problem resides. Much easier than to buy testing equipment and go step by step testing everything based off the info in the Adam Technical Manual.
Do I have to replace both of them to save my ADAM?
So if it works, I have to re install the RGB mod, and if it works, I should put it back together.
BTW, I do not have a Facebook account.
Ideally you would swap out one board   at a time to narrow down which one has the issue(s) and keep your fingers crossed that both don’t show issues.
William Hicks is a member on here. Send a PM to MilliV.
Who is MilliV?
William Hicks is actually on the Facebook, but I don't have an account.
So MilliV is his Atariage account?
There are others to try for repair, such as Crossbow.  Well, I don't know if AA has a directory for people who repair stuff, but I know there are others on here too.
If only I could replace one of the boards to fix that stupid black screen problem or something.
Not sure I could tackle an Adam as I've never owned one much less worked on one and I never like my clients to be the 'first' on a system I've not much experience with.
Blindly replacing chips might fix it, but it's not an ideal way.
Like Crossbow says, I don't have actual Adam experience either.  What I'd do is offer to buy it as a non-working unit, then if I can fix it, I'd sell it back at original plus repair price.  That way, even if the repair fails, you're not left empty-handed.
6 hours ago, Retro_Game_Lover96 said:
What if MilliV doesn't respond?
Yes, MilliV is William Hicks. You can also contact him via the email address on www.adamarchive.org
Hmmmmm. Okay, I think he has some of the replacement parts for the ADAM to replace.
I think he has some chips to replace for the ADAM Gamma Board (bottom board for the standalone ADAM), so I hope this'll fix the black screen problem.
