matosimi
MDCMC - Mono Double Chaos Music Composer
Hi,
I have created modification to classic CMC (Chaos Music Composer) that extends replay routine same as it is in stereo SDCMC by Datri... which results in better and richer drums. This playback mode requires only single call of replay routine per frame.
You can read some info and download the binaries here: http://matosimi.websupport.sk/atari/2020/10/mdcmc-mono-double-chaos-music-composer/
There is demosong p6mondbl (on the mdcmc disk image) that has instruments adjusted for this modified version of CMC (Thanks to @Poison for quick adjustment).
MDCMC player source can be found here: https://sourceforge.net/p/mdcmc/code/HEAD/tree/
Enjoy.
Edited by matosimi
deleted some stuff
  • Like 9
  • Thanks 4
2 hours ago, Heaven/TQA said:
nice.... how much rasterlines does the player consume?
around 72 compared to 52 of original cmc
1 hour ago, rensoup said:
So are you just calling the replay routine twice in a row rather than in the Vbi then in a DLi midscreen ?
nope, that would play the music in 2x speed; replay routine consists of 3 parts (executed on 1st call) and in the 2nd call only 3rd part is executed.
that's an expensive player 😲
Sure, the better question would have been: Do you update the pokey registers twice in a row rather than in the Vbi then in a DLi midscreen ?
Or are you only updating them once per frame ?
its updating twice a frame
2 hours ago, fox said:
Are you aware of CMC DoublePlay made by Greg in the '90s?
I have done some research, CMC DoublePlay by Greg is a bit different mod. His CMC is actually being executed twice a frame (normal cmc module is playing twice the speed).
However when I changed the speed from 05 to 10, it sounds pretty same as Datri's mod :)
I have also found that (with respect to the player greediness) it also runs through 72 rasterlines and it is just executed twice in a row (no midscreen execution).
So now i know the only difference is that Datri's double mode does not count second execution of replay routine as separate, so there is no need to slow the tempo.
replay routine from Greg's DMC:
	jsr cmc.replay+6
	jmp cmc.replay+6
replay routine from Datri's SDCMC:
	jmp cmc.playDouble
playDouble
	jsr play
	lda czygrc
	sta tmp01
	lda #$01
	sta czygrc
	jsr play
	lda tmp01
	sta czygrc
	rts
hmm... I did not want to reinvent the wheel...
hmmm.... I always wonder why Atari music players consume so many cpu time... ;) compared to SID players... I still like Wratchild's work on the Adam Gilmore player... but of course... no editor just by editing by hand...
Because they take use of the available chip commands and features. But they sound very "common" . Special tunes use also much more CPU there.
And, yes, It's one of my "development goals", to have best POKEY sound with the lowest need of CPU.
You don't find any other tune at an equal quality , using equally low CPU....
(CPU usage given by the player itself)
Dmsc's LZS takes 10 scanlines constant, not sure anyone is using it beside me though!
21 minutes ago, xxl said:
interesting but what are the player names ?
You might hear it that it is "Richard Munns" music . Could be a rip off from the game and re used for "similar" sounding tunes.
Wait. Is it just RMTplay using every routine unrolled ?
Is would save CPU time but cost more RAM.
Edited by emkay
I most certainly should give this one a try. Although today it seems to be a quite obsolete music editor (compared to other formats like RMT, but even compared with TMC and MPT), but it is the only music editor I ever learned to use.
Is this updated version also compatible with atari's with a STEREO upgrade? I noticed that originally CMC songs do weird things on Stereo Atari (which has to set to mono with the switch to sound good).
Thanks for keeping CMC alive. I will give it a try soon!
I have two wishes:
1. Oh... I should definitely learn to arrange stuff like this. I think always way too much from the perspective using chords which eat way too many notes. This is really a fabulous song, with a wide acoustic field. Well done, any suggestion how I could learn this? (I know how music works, it is more that I am not skilled in making this kind of arrangements)
2. I love using atari 8bit, and I dislike using PC / Mac for Atari 8bit stuff. You seem to use RMT (am I right?) ... so that would not my #1 choice, since I want to use my a8 more frequently. Is there anything native on a8 that comes close to what RMT can do? I thought Theta Music Composer was adviced to use on a8 to me... but I can not remember clearly. Is there a good manual available for Theta Music Composer, or do you recommend a different composer on a8?
Great stuff emkay!
I have not spotted this, but there was a call to $d21f (which indicates 2nd pokey) in the editor and it of course messed up the sounds.
Here is the fixed version, it took me a minute to fix this:
cmceditor.xex
  • Thanks 2
A great. I will check it out soon!
(Is that also fixed in the player-routine then, in case I might use one of the newly created CMC's in a demo or game in the future....)?
Do not use embedded player in the CMC editor, but use the one in the repository instead (linked in original post)... it was already ok, only composer had this bug.
Edited by matosimi
typo
3 hours ago, Heaven/TQA said:
ah sorry...that is the ST like dump of the pokey stream.... should play with it finally some day.
Yep, it's not difficult to use at all
it's a raw dump of the Pokey registers compressed LZ style... discussed here
Sorry for the thread hijack
6 hours ago, Marius said:
I have two wishes:
The only way I'd know is to use a SID Tracker. I'm still hoping someone is doing a "Goat-Tracker" to "RMT" converting tool.
Using it the old way: One channel bass + drum , one channel an arpeggio, and one channel using any possibility of the SID modulation.
Seems the "SID musicians" get inspired by the resulting sounds there.
If this can be played on SID, it also can be played on POKEY then.
The thing is: You can do "Pokey tunes" while you're doing something on the PC. Running RMT , listen to the tune, and find the needed positions and solutions.
If you're doing this on a real Atari, it will cost more time.
The perfect solution could be to have the tune "99%" perfect on the PC and then do the final tuning on the real thing. Because there is a lot of possibilities missing to control in RMT.
Btw: We found out that my "Hardsynth" Method does work well even if played by the LZS "Player" .
10 Scanlines for such complex tunes....
Great stuff emkay!
Well, Sack-c0s posted a video of his "Chordian" conversion. I took the notes and pattern from the video and added my own instrumentation. You can see the development steps in the "emkayvideo" channel.
At least this way we've got something outstanding. ;)
So far, we have determined one thing that doesn't work with SAP-R/LZS Player, and that's two-tone mode.
I might add that timed writes don't work either, so pavros' way to sync dist C does not work.
Now that's determination! :)
You could also have run the original SID through siddump ;)
That way I was 100% sure, the notation will fit. So it was worth the work ;)
I'm not sure what 2 tone mode is, care to give some details why it doesn't work in the original thread (we've totally hijacked this thread)?
Does any of the regular players support timed writes ? I'm guessing not, RMT at least just updates Pokey at the end of its replay routine I think
Two-tone mode is enabled through SKCTL ($d20f) which is not recorded by SAP-R. It only records writes to $d200-$d208, i.e. all the AUDF and AUDC registers and AUDCTL.
For a description what enabling two-tone mode actually does, I refer to phaeron's excellent Altirra Hardware Reference Manual, chapter five, just before section 5.5. Page 97 in the latest version I have.
Quote
No, AFAIK, no player in the wild supports timed writes to reset the poly counter to a known state.
Somewhat resetting the poly counters in RMT is done by playing the highest frequency possible for a frame and then go back to your desired note. That works with SAP-R/LZS player.
Something that won't work work SAP-R either, is putting the poly counter in a known state before you start playing your tune (and keep your notes that rely on those counter within certain modulo boundaries), by means of writing a non-zero value to STIMER ($d209). STIMER is also not recorded in SAP-R.
Yes, we have :D
Edited by ivop
