Sign in to follow this
bluepen61
v9t9 and windows 10 / java 1.8.0_261
I have v9t9 running on my windows 10 pro but the sound doesn't work. This appears in the  command window:
"java version "1.8.0_261"
Java(TM) SE Runtime Environment (build 1.8.0_261-b12)
Java HotSpot(TM) 64-Bit Server VM (build 25.261-b12, mixed mode)
WARNING: Found unknown Windows version: Windows 10
Attempting to use default windows plug-in.
Loading: net.java.games.input.DirectAndRawInputEnvironmentPlugin
Log file: v9t9.log
**** RESET ****
java.io.IOException: failed in waveOutPrepareHeader: The specified device handle is invalid.
        at ejs.base.sound.Win32SoundListener.createWaveHeader(Win32SoundListener.java:332)
        at ejs.base.sound.Win32SoundListener.access$500(Win32SoundListener.java:40)
        at ejs.base.sound.Win32SoundListener$1.run(Win32SoundListener.java:211)
        at java.lang.Thread.run(Unknown Source)"
Is there a fix or work around?
John L Kemmis
Now V9T9 works!!  Here is the work around:
The author instructed me to install Zulu SDK version 8 (no higher).
It is here: https://www.azul.com/downloads/zulu-community/?version=java-8-lts&os=windows&architecture=x86-64-bit&package=jdk
Then I edited the .bat file by adding this PATH statement:
PATH="c:\Program Files\Zulu\zulu-8\bin";%PATH%
Voila, V9T9 sound and speech works on Windows 10. And it seems the game modules and disk drive setup works too; although to what extent, I am not sure. But Parsec works and so does TI-Writer and I Editor/Assembler starts.
Thank you Ed!!
Hope this helps others.
John L Kemmis
