zezba9000 #26 Posted November 8, 2020 (edited) @ParanoidLittleMan Awesome stuff. Hooked up your TOS ROMs and can switch between the different OS's with a pull-up switch. Edited November 8, 2020 by zezba9000 Quote Share this post Link to post Share on other sites
KonsolenKrieg #27 Posted March 21, 2021 On 10/7/2020 at 8:59 AM, ParanoidLittleMan said: It is most likely because you have TOS 1.00 or 1.02 in those machines. And they are not good with so many files in partitions. There is new SD card image, what is done specially for those old TOS versions. https://www.mediafire.com/file/hgkdnnwym334ilg/1000GamesT02.zip/file 541 MB. Unpack it and write to SD card - 2 GB card min needed. Btw. UltraSatan should be detected without extra reset after power on. Maybe recap of PSU is necessary ? Before asking: TOS 1.00 is year 1985, 1.02 is 1987, 1.04 is 1989 in Desktop Info . So I did all that and what was written above and it really already helped a lot, especially in regards to file transfer between Atari 1040STf and any other computer (also booted up an older linux OS configured the SD card for DOS and flashed it). My issue is, it is still not playing the Games even the 1mb files. I also cannot swap SD cards and have to restart the Ultrasatan when something is changed. However if I download a program like Cubase Lite, it is no issue to run it on the SD card. The issue with my SD card which I purchased (amigastore.eu) is the same as described initially and I cannot even mount it with an older linux distribution. It has the ICD pro installed and Kobold and at lest these programs on the main partition are running, which is nice, but as I cannot run anything else and I cannot mount it on any other devise, nor the Ultrasatan recognises the second SD card it becomes basically worthless? However these issues are for along the way as I just got into this machine and still have a lot to learn. Main point: Any hints how I get it to play the games? Quote Share this post Link to post Share on other sites
ParanoidLittleMan #28 Posted March 22, 2021 If games don't work something is wrong, works unreliable. Should do write reliability test - copy some longer files with Atari, then compare written with original file on PC - I do it with Total Commander. PSU recapping is practically mandatory after all this years. That 1000Games... is demo version. It does not support hot swap, 2 cards. Things are that ST machines are very old, and there will be more and more problems. Hardest to find cause is when it works so-so. Quote Share this post Link to post Share on other sites
KonsolenKrieg #29 Posted March 22, 2021 I get that. But as said, other programs I download work so far. However, I will try what you said. PSU check is easy for me and indeed I have not opened up the unit, yet. Last thing, how do I get the full version of the SW, because at least this recognizes DOS formatted cards and I can dump applications. Quote Share this post Link to post Share on other sites
ParanoidLittleMan #30 Posted March 22, 2021 http://atari.8bitchip.info/pphdr.php There is e-mail address for concrete payment details, order . 1 Quote Share this post Link to post Share on other sites
thecaver99 #31 Posted September 8, 2021 is there another link to the file 1000gamest02.zip as the one abover doesnt work Quote Share this post Link to post Share on other sites
