tschak909 Posted October 7, 2020 Share Posted October 7, 2020 I'm putting together a zip of useful stuff to dump onto a SD card, that we will link to from fujinet.online. Do you have something that you think all FujiNet users need quick access to? A favorite DOS? Utility? other program? Post it, here. -Thom 1 Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted October 7, 2020 Share Posted October 7, 2020 ICE-T, BobTerm and PLATOTerm are the most popular files on my tnfs server so far by quite some margin. I'd also put a DOS2.5 with all drives enabled and the FNtools on it, a MyDOS 4.53/4 set up the same, Commbat, MIDIMaze, All the test suite files Quote Link to comment Share on other sites More sharing options...
+Philsan Posted October 7, 2020 Share Posted October 7, 2020 Atari Control Picture (PAL).xex Copymate XE (128).xex Hardware Tester.atr Memory Test Radon.atr MILF.atr Screen Height Meter.xex SysInfo v2.24.atr Video Upgrade Test.xex XRAM v0.21.xex 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted October 7, 2020 Author Share Posted October 7, 2020 (edited) I chuckled when I saw MILF. Clicked on it, run it: written by dely/bjb. because, OF COURSE @dely would name this tool MILF. -Thom Edited October 7, 2020 by tschak909 2 Quote Link to comment Share on other sites More sharing options...
Mathy Posted October 7, 2020 Share Posted October 7, 2020 Hello guys 4 hours ago, Mr Robot said: ... a MyDOS 4.35/4 ... I guess that's a typo and it's meant to read 4.53/4. Forget 4.53/x, try 4.55 beta 4. It can be set to a minimum of either 3 or 4 numbers in the sector count. Sincerely Mathy Quote Link to comment Share on other sites More sharing options...
tschak909 Posted October 7, 2020 Author Share Posted October 7, 2020 is there ever going to be a 4.55 release? -Thom Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted October 7, 2020 Share Posted October 7, 2020 34 minutes ago, Mathy said: Hello guys I guess that's a typo and it's meant to read 4.53/4. Forget 4.53/x, try 4.55 beta 4. It can be set to a minimum of either 3 or 4 numbers in the sector count. Sincerely Mathy Yes that was a typo. I tried 4.55b4, couldn't get it to do the AR0 AR1 thing at all, fell back to 4.53/4 which worked fine. Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted October 8, 2020 Share Posted October 8, 2020 I see @Philsan posted the PAL version of @Bryan's ACP.XEX, so here's the NTSC version I use all the time. acp.xex Quote Link to comment Share on other sites More sharing options...
tschak909 Posted October 8, 2020 Author Share Posted October 8, 2020 Okay, so I've put everything into a github repo: https://github.com/FujiNetWIFI/fujinet-sd-card And have cut an appropriate release: https://github.com/FujiNetWIFI/fujinet-sd-card/releases/tag/sd-card-2020-10-08 Of special note, is the DOS folder, which contains lots of different FMSes, each with a copy of fnc-tools ready for use. fujinet-sd-card-sd-card-2020-10-08.zip fujinet-sd-card-sd-card-2020-10-08.tar.gz 3 Quote Link to comment Share on other sites More sharing options...
Atari8guy Posted October 26, 2020 Share Posted October 26, 2020 Do you have to put anything in the root directory of the SD card to get it to work? I've tried 3 different SD cards with no luck. (including the one I use in my S-Drive Max). The "SD" is in the first slot on my Fujinet Device. This should work? Quote Link to comment Share on other sites More sharing options...
tschak909 Posted October 26, 2020 Author Share Posted October 26, 2020 Yup, there's nothing special, the filesystem should either be FAT16 or FAT32. -Thom Quote Link to comment Share on other sites More sharing options...
Atari8guy Posted October 26, 2020 Share Posted October 26, 2020 Well I grabbed a newer MicroSD and it worked fine, however I feel like 16GB is way too much. (one of my old ones was only 64MB, but it didn't work). Quote Link to comment Share on other sites More sharing options...
tschak909 Posted October 26, 2020 Author Share Posted October 26, 2020 7 minutes ago, 8bitguy1 said: Well I grabbed a newer MicroSD and it worked fine, however I feel like 16GB is way too much. (one of my old ones was only 64MB, but it didn't work). I use a SanDisk 2GB micro-SD card. -Thom Quote Link to comment Share on other sites More sharing options...
mchorvat Posted October 28, 2020 Share Posted October 28, 2020 received my Fujinet just this week. What an amazing device! great job, @tschak909 and the rest of the team. Been playing with FJ and so far I am very happy about it despite few issues. I understand many features are still in development, so no biggie. Few suggestions for files to be put on SD card: - SECTCOPY.ATR - selection of few good sector copiers, my favourite being Copy2000 (supports 360k disks on XF551 and can copy/format flawlessly atr's via SIO2SD device) HTML13.ZIP - simple html viewer/converter I wrote some 20 years ago (html was way simpler back then, haha). It's not the fastest viewer (no read/write buffer) but did the job back then. There is also a doc file attached. Marek SECTCOPY.ATR html13.zip 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted October 28, 2020 Author Share Posted October 28, 2020 @mchorvat excellent! Thank you for the additions. I am curious, how should I package the html1.3 viewer? Am thinking on a SpartaDOS 3.2d disk, by itself, but not sure. As for any questions on how things should work/possible bugs, please refer to the bug testing/reporting thread: -Thom Quote Link to comment Share on other sites More sharing options...
mchorvat Posted October 28, 2020 Share Posted October 28, 2020 (edited) you are very welcome! maybe just extract .com and .doc and put it in a dos atr bundle of your choice. html viewer was not written for command line DOSes though, but should work in SpartaDos (I am huge fan of SDX nowadays). Been using BiboDos 6.4F for many years as it was very popular in Europe (also supported XF551 drive/DSDD disks). Maybe I will rewrite HTML viewer/converter to run as command line tool and make it faster. btw, It had built-in support for 80 columns by Itay which was very nice feature. Will check out the bug reporting thread for sure. thanks! Edited October 28, 2020 by mchorvat Quote Link to comment Share on other sites More sharing options...
fenrock Posted October 28, 2020 Share Posted October 28, 2020 (edited) I would really appreciate the latest Terminal emulators in the project. I've just spent the last hour trying to find the latest Bobterm, platoterm and ice-t xex's / atrs. I don't think the latest versions are always uploaded to the original thread they originally are mentioned in, and often updates are on a page half way through the entire thread thus requiring to trawl through many pages of forum updates to see if there's a latest beta version/alpha version etc, and it's ummm time consuming. I do wish the (what seem to be) 3 core apps (Bobterm/platoterm/ice-t) had modern day github/gitlab release pages, but sadly not. (Willing to be proved wrong!) This project could be a very good place to have the latest all kept up to date with PRs as changes are made, and keeping people (like poor me who is new to all this) from having to search and filter the latest. EDIT: just found: - https://github.com/tschak909/platoterm-atari-cart/releases/tag/PLATOTERM-ATARI-LITE-1.3 Thanks! Edited October 28, 2020 by fenrock Quote Link to comment Share on other sites More sharing options...
tschak909 Posted October 28, 2020 Author Share Posted October 28, 2020 If you look on the atari-apps.irata.online tnfs in Comms/ You'll find: * modem-programs.atr (a set of modem programs) * plato.atr (PLATOTERM for the N: device, automatically connects to IRATA.ONLINE) -Thom Quote Link to comment Share on other sites More sharing options...
fenrock Posted October 28, 2020 Share Posted October 28, 2020 Thanks @tschak909, how do i transfer those to an SD rather than always having to download them? I tried going (on web browser) to that site to simply download them so I could copy them to the SD, but got "the site cannot be reached". Sorry if this is a beginner question, but that's me Quote Link to comment Share on other sites More sharing options...
tschak909 Posted October 28, 2020 Author Share Posted October 28, 2020 It's all good, am here to help. Before I do mention anything, this is sort of the point of FujiNet, so you don't have to keep multiple copies of things, you can just stream them off the network, to the Atari there is no difference. So just boot it off there. with that said: There is the beginning of a TNFS client, written in python, if you have a python environment installed: https://github.com/FujiNetWIFI/spectranet-tnfs-fuse Your observations really are indicative of the fact that there is TONS of activity around this project, things are evolving. We will get everything organized eventually. -Thom Quote Link to comment Share on other sites More sharing options...
fenrock Posted October 28, 2020 Share Posted October 28, 2020 thanks! i do have a good dev env, so will that running tomorrow (it's my wedding anniversary, and my wife's giving me daggers). Completely understand that you want to keep it in the network so we don't have to worry about versions (etc), and I agree... except when the site you rely on is down. I'll give a more rounded report on my experience, but to start with I'm blown away with how much fun this is. Zaxon pre-configured (or maybe it's in the base unit) some sites for me, so i was completely ready to go, read a couple of web pages on basic setup, all went well from the off. I'm in love with this thing, and as a programmer, can't wait to write some apps that use it. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted October 28, 2020 Author Share Posted October 28, 2020 7 minutes ago, fenrock said: thanks! i do have a good dev env, so will that running tomorrow (it's my wedding anniversary, and my wife's giving me daggers). Completely understand that you want to keep it in the network so we don't have to worry about versions (etc), and I agree... except when the site you rely on is down. I'll give a more rounded report on my experience, but to start with I'm blown away with how much fun this is. Zaxon pre-configured (or maybe it's in the base unit) some sites for me, so i was completely ready to go, read a couple of web pages on basic setup, all went well from the off. I'm in love with this thing, and as a programmer, can't wait to write some apps that use it. Here's a wiki page describing a netcat app, plan is to add a version for every major atari language as a rosetta stone: https://github.com/FujiNetWIFI/fujinet-platformio/wiki/A-Simple-NetCat-Program -Thom 1 Quote Link to comment Share on other sites More sharing options...
alortegac Posted October 29, 2020 Share Posted October 29, 2020 (edited) My SD card is a SandDisk Ultra 128GB, I can't make it work. Directory is not recognized. Are there any special SD card to be used? thanks! Edited October 29, 2020 by alortegac Quote Link to comment Share on other sites More sharing options...
alortegac Posted October 29, 2020 Share Posted October 29, 2020 BUMP. - I used a 2 GB SD and worked like a charm. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted October 29, 2020 Author Share Posted October 29, 2020 Yup, the 128GB card is too big. -Thom Quote Link to comment Share on other sites More sharing options...
