wolhess Posted October 12, 2020 Share Posted October 12, 2020 Hi, maybe an assembly expert can help me, I'm just taking my first steps in assembly language programming. I don't really understand the sound output. I have tried the example program "A CHIME" from the EA manual on page 321 and it works as it should. Then I changed the program to produce a BEEP. This also works as it should. However, if I include a keyboard query to repeat the BEEP with "REDO" and to exit the program with "ESCAPE", then my program only works for the first BEEP. I come back to the EA with "ESCAPE". However, with "REDO" no sound is played and the TI gets stuck. Even if I then reload and start the program in the EA, no sound is played. Only after a reset via the TI title screen the program is working again at the first run. Spoiler * * Example program to play a chime * E/A page 321-323 * Modified for playing a BEEP * REF VMBW,KSCAN DEF BEEP * KEYVAL EQU >8375 STATUS EQU >837C BUFFER EQU >1000 * SAVERT DATA >0000 * H01 BYTE >01 REDOV BYTE >06 ESCPV BYTE >0F EVEN * BEEP MOV R11,@SAVERT SAVE RETURN ADDRESS LI R0,BUFFER VDP-RAM BUFFER ADDRESS LI R1,BEEPST BEEP SOUND TABLE LI R2,8 BLWP @VMBW LOAD VDP-RAM * LOOP LIMI 0 DISABLE VDP INTERRUPT LI R10,BUFFER LOAD SOUND TABLE ADDRESS MOV R10,@>83CC LOAD POINTER TO THE TABLE SOCB @H01,@>83FD SET VDP-RAM FLAG MOVB @H01,@>83CE START SOUND PROCESSING LIMI 2 ENABLE VDP INTERRUPT * LOOP2 MOVB @>83CE,@>83CE READY CHECK? JEQ KEY YES, LOOK FOR A KEY PRESSED JMP LOOP2 NO, WAIT UNTIL FINISHED KEY CLR @STATUS CLEAR STATUS BLWP @KSCAN PERFORM A KEY SCAN MOV @STATUS,@STATUS A KEY IS PRESSED? JEQ KEY NO, CHECK AGAIN CB @KEYVAL,@ESCPV ESCAPE? JEQ ESCAP YES, -> CB @KEYVAL,@REDOV REDO? JEQ LOOP YES, -> JMP KEY NO, CHECK AGAIN ESCAP CLR @STATUS MOV @SAVERT,R11 RT * BEEPST BYTE >03,>8E,>0F,>91,>1E BYTE >01,>9F,>0 END What do I have to do so that the sound is also played on the second run? Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted October 12, 2020 Share Posted October 12, 2020 1 hour ago, wolhess said: JEQ LOOP YES, LOOK FOR A KEY PRESSED Maybe this should be... JEQ KEY YES, LOOK FOR A KEY PRESSED ...not too sure I'm an expert though. Quote Link to comment Share on other sites More sharing options...
wolhess Posted October 12, 2020 Author Share Posted October 12, 2020 Yes, you are right, that's how I did it, but then the program behaves exactly as I described it. --> I changed it in the first message! Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted October 12, 2020 Share Posted October 12, 2020 1 hour ago, wolhess said: KEY CLR @STATUS CLEAR STATUS Maybe interrupts need to be off during KSCAN... KEY LIMI 2 LIMI 0 CLR @STATUS CLEAR STATUS 1 Quote Link to comment Share on other sites More sharing options...
wolhess Posted October 12, 2020 Author Share Posted October 12, 2020 I will check this, Thank you. Quote Link to comment Share on other sites More sharing options...
wolhess Posted October 12, 2020 Author Share Posted October 12, 2020 Your suggestion works. Wow. I would never have figured it out on my own. Thanks alot! 1 Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted October 12, 2020 Share Posted October 12, 2020 You're welky. Despite that I should have recognized this, from my own pitfalls ...years gone by! Classic99's LOG, warned about the (SCAN?) program writing to VDP RAM with interrupts on. So, looks like TURSI gets some of the credit too! 1 Quote Link to comment Share on other sites More sharing options...
wolhess Posted October 12, 2020 Author Share Posted October 12, 2020 I did not find this information in the EA manual. Neither with SOUND or KSCAN nor with SCAN or LIMI. However, LIMI says that LIMI 0 is the normal state of the computer. Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted October 12, 2020 Share Posted October 12, 2020 I'd noticed, some time ago... That there are a lot of seemingly different examples of how to setup/use KSCAN. Not all of them worked consistently for me though. I think this method came from the red Molesworth book. I suppose... interrupts need to be on when the key is depressed, in order to be detected. But need to be off when KSCAN runs. Dunno for sure though. But, this seems to always work for me. Quote Link to comment Share on other sites More sharing options...
Casey Posted October 12, 2020 Share Posted October 12, 2020 There’s an excellent beginners assembly language book I just happened to read through that specifically brought up the subject of sound generation and the need for an LIMI 2/LIMI 0 pair in the main loop to make sound work. It’s aimed at the Mini Memory cartridge with the Line By Line assembler, but it had a lot of good information for a beginner in it. COMPUTE!’s Beginners Guide to Assembly Language on the TI 99/4A. You can find that I think on archive.org as a PDF. It might be worth taking a look through, even if you are planning to use Editor/Assembler. 2 Quote Link to comment Share on other sites More sharing options...
wolhess Posted October 12, 2020 Author Share Posted October 12, 2020 21 minutes ago, Casey said: There’s an excellent beginners assembly language book I just happened to read through that specifically brought up the subject of sound generation and the need for an LIMI 2/LIMI 0 pair in the main loop to make sound work. It’s aimed at the Mini Memory cartridge with the Line By Line assembler, but it had a lot of good information for a beginner in it. COMPUTE!’s Beginners Guide to Assembly Language on the TI 99/4A. You can find that I think on archive.org as a PDF. It might be worth taking a look through, even if you are planning to use Editor/Assembler. Thank you very much , in the book the subject of sound is described in great detail. On page 167 it is also stated that the VDP interrupt should be switched on and off quickly. That was the secret that I didn't know. 2 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted October 12, 2020 Share Posted October 12, 2020 There is another interesting point about this LIMI 2/0 and the VDP interrupt. You know, they just did not tell us the whole story ... ? When I learned assembly language programming, I learnt that I have to do this LIMI 2/0 in a loop for interrupt-driven function, and that it works. But why does it work? My concern was that these LIMI operations ran in a couple of microseconds, and why should the VDP just raise its interrupt line in between? Wouldn't I miss a lot of interrupts? Much later (actually, when I worked in MAME) I understood what happens. The interrupt input of the 9900 is level-triggered; that is, the interrupt service will start as soon as the processor detects INTREQ*=0 (and the level indicated via IC0-IC3 is higher than the LIMI mask). The VDP interrupt output is latched inside the VDP. That is, when an interrupt occurs, its INT line gets active and stays so, until you clear the interrupt in the VDP. This can only be done by reading the status register. If you look inside "TI Intern" you see that at address 094A, the SBO 2 instruction first disarms the interrupt trigger in the 9901 (Heiner Martin's comment was wrong at that point), and at 0A84, the status is read, which clears the interrupt again. Thus, when LIMI 2 is executed, the latched VDP interrupt will make the CPU jump to the interrupt service immediately. BTW, the 9995 has its own latches which can be queried via CRU addresses 1EE4/6/8. 2 Quote Link to comment Share on other sites More sharing options...
Tursi Posted October 13, 2020 Share Posted October 13, 2020 18 hours ago, HOME AUTOMATION said: I suppose... interrupts need to be on when the key is depressed, in order to be detected. But need to be off when KSCAN runs. Dunno for sure though. But, this seems to always work for me. No, the TI keyboard is literally just a grid of switches. They don't trigger interrupts, so interrupts don't need to be enabled. There's no storage and no caching of status. The KSCAN function literally reads the keyboard by enabling each column, and seeing if any rows on that column are pressed - this is why KSCAN takes a fair bit of time to run. It also means you only know the state of the keyboard at the exact time that you scan it. I don't see in a quick scan why interrupts should interfere with KSCAN, but all console software in the TI runs on the assumption that interrupts are normally disabled. When you violate assumptions in other people's code, you tend to get bugs. 1 Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted October 14, 2020 Share Posted October 14, 2020 I tested this on Classic99 somewhat... ...looks like you're right(again). Upon better recollection, I probably have the LIMI 2/0 in my keyscan loops, as a simple way to allow the QUIT key-pair to function. Perhaps also to provide simple compatibility with TI's wonderfully well-thought-out sample code. ...Not to mention my own. Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted October 14, 2020 Share Posted October 14, 2020 22 hours ago, Tursi said: I don't see in a quick scan why interrupts should interfere with KSCAN, but all console software in the TI runs on the assumption that interrupts are normally disabled. When you violate assumptions in other people's code, you tend to get bugs. Doesn't the ISR under normal circumstances try and read the QUIT key ? That in itself might interfere. 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted October 14, 2020 Share Posted October 14, 2020 15 hours ago, sometimes99er said: Doesn't the ISR under normal circumstances try and read the QUIT key ? That in itself might interfere. Ah... yeah, that's probably it. Changing the CRU setup in the middle of a scan wouldn't be helpful. Quote Link to comment Share on other sites More sharing options...
