pnevmati Posted July 2, 2021 Share Posted July 2, 2021 That makes perfect sense, many thanks! Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted July 2, 2021 Share Posted July 2, 2021 Yup I have many in stock at arcadeshopper.com if you need a 120v oneSent from my LM-V600 using Tapatalk Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted July 2, 2021 Share Posted July 2, 2021 Uh-Oh, That diagram is wrong! In more ways than one... ...and I have more than one degree in electronics. Not that I'd need them for this. ...don't try it! Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted July 2, 2021 Share Posted July 2, 2021 (edited) Between 1,2 - 8.5vac approx.(unloaded) Between 2,3 - 19.3vac approx.(unloaded) Between 1,3 - 27.8vac approx.(unloaded) ...so, pin 2 is center tapped. The numbers on the plug are in a different order. Not sure how that "3. Red 5 volt" reading was arrived at! A reading of 5vac between pins 1,3(loaded) would indicate that one of coils in the xfmr. has been wired out of phase(inverted). This would cause the 7905 in the diagram to load the wrong alternation. Though seemingly insignificant, this could result in different thermal coefficients. Edited July 2, 2021 by HOME AUTOMATION Quote Link to comment Share on other sites More sharing options...
