+Ksarul #26 Posted October 14, 2020 The only one of Quinton Tormanen's programs I've ever seen converted to a cartridge image is War Zone II. That conversion was done by Rasmus. Quote Share this post Link to post Share on other sites
Count9929A #27 Posted October 14, 2020 44 minutes ago, Ksarul said: The only one of Quinton Tormanen's programs I've ever seen converted to a cartridge image is War Zone II. That conversion was done by Rasmus. so all of them were commercially released as disk, right? Quote Share this post Link to post Share on other sites
Keneg #28 Posted October 14, 2020 I tried changing the CRU base today. I was thinking if it was the same as a real disk drive it might work. Still no joy. Quote Share this post Link to post Share on other sites
+Ksarul #29 Posted October 15, 2020 All of them were released on disk by Comprodine. 2 Quote Share this post Link to post Share on other sites
jedimatt42 #30 Posted October 15, 2020 On 10/13/2020 at 7:10 PM, Keneg said: So it just won’t work on the real hardware. Bummer! TIPI isn't a finished product, give us a minute, and we'll figure it out. Quote Share this post Link to post Share on other sites
jedimatt42 #31 Posted October 15, 2020 37 minutes ago, jedimatt42 said: TIPI isn't a finished product, give us a minute, and we'll figure it out. And, TIPI is more of a hard drive for you 4A, not a floppy drive, it just has some floppy device name support for usage convenience. And that convenience is good enough for most programs. When I'm done with my day job today, I'll investigate this. 2 Quote Share this post Link to post Share on other sites
Keneg #32 Posted October 15, 2020 1 hour ago, jedimatt42 said: And, TIPI is more of a hard drive for you 4A, not a floppy drive, it just has some floppy device name support for usage convenience. And that convenience is good enough for most programs. When I'm done with my day job today, I'll investigate this. Thanks. Also, I have another issue. The mouse now just goes to the right and stays there unusable. I think this happened when I updated to version 2.8. It used to work. I have tried it with two USB mice. Has anyone else reported this issue? Quote Share this post Link to post Share on other sites
+arcadeshopper #33 Posted October 15, 2020 2 minutes ago, Keneg said: Thanks. Also, I have another issue. The mouse now just goes to the right and stays there unusable. I think this happened when I updated to version 2.8. It used to work. I have tried it with two USB mice. Has anyone else reported this issue? report it here please Quote Share this post Link to post Share on other sites
jedimatt42 #34 Posted October 16, 2020 TIPI mapped DSK1 lvl3 IO access will return 0 for missing files, and let other devices try and service the request. The game works fine from TIPI at crubase >1000, and a real floppy controller, with no disk in the floppy drive. With the DSK1 mapped to whatever directory you have the disk extracted to on your TIPI run the following TI BASIC code: 10 OPEN #1:"DSK1.LT:SC",OUTPUT 20 CLOSE #1 Then it works for me without ever trying to reach out to the real floppy controller... Doesn't matter what crubase your TIPI is at for this game. However, if you don't have a floppy controller, your TIPI really should be at >1100 so that VDP stack is initialized the same as if you had a floppy controller, and the same that is assumed by some other software. See the thread about getting TML to work with TIPI. Quote Share this post Link to post Share on other sites
+arcadeshopper #35 Posted October 16, 2020 Yup works here too thanks Matt!Sent from my LM-V600 using Tapatalk 1 Quote Share this post Link to post Share on other sites
Keneg #36 Posted October 16, 2020 Ok, I will set CRU base to 1100, run the BASIC program and try it tomorrow. Thanks Matt. Quote Share this post Link to post Share on other sites
Keneg #37 Posted October 16, 2020 I was going to try this first think this morning. TIPI not working, RPI0 very hot. Tested power supply, 5.16 volts. Managed to hook up my RPI3B using a bunch of jumper wires. Not easy to connect all of the wires, but it is working again! I did want to try this eventually for the speed increase, so I guess it is OK. Will try the game later. Life in retro computing is so interesting. Quote Share this post Link to post Share on other sites
Keneg #38 Posted October 16, 2020 (edited) Ok it works and only has to be done once. Once the file “LT:SC” is in the directory, it will auto load from extended BASIC if the directory is set as DSK1. Now I just have to figure out how to survive more than 30 seconds. LOL. I wonder if this was somehow a hidden file on the original disk that doesn’t copy correctly as a form of copy protection. I think this file should be added to the packages at the sites this can be downloaded from. Edited October 16, 2020 by Keneg 1 Quote Share this post Link to post Share on other sites
GDMike #39 Posted October 16, 2020 (edited) I found a little fan that operates on 5-12vdc, so I piped 5 to it from a seperate power source, and the fan has rubber padding around it's case and it squeezes in nicely between pins that are standing up and the other side but sits on top of the cpu, and keeps my pi cool. I also have desktop running on my pi so I can watch the temp AND it's convenient when moving files. Edited October 16, 2020 by GDMike Quote Share this post Link to post Share on other sites
Keneg #40 Posted October 16, 2020 2 hours ago, GDMike said: I found a little fan that operates on 5-12vdc, so I piped 5 to it from a seperate power source, and the fan has rubber padding around it's case and it squeezes in nicely between pins that are standing up and the other side but sits on top of the cpu, and keeps my pi cool. I also have desktop running on my pi so I can watch the temp AND it's convenient when moving files. The RPI3B has a fan on it. I like the increased speed so will leave it alone. I have a Win10 machine nearby that I use for downloading. If I had more room on the desk, using the PI would be nice. 1 Quote Share this post Link to post Share on other sites
Keneg #41 Posted October 17, 2020 I had to re-image my SD card today. The LT:SC file came back in as a different file name! So I am thinking that was part of the copy protection. Re-created the file and it works again. 2 Quote Share this post Link to post Share on other sites
+arcadeshopper #42 Posted October 17, 2020 17 hours ago, Keneg said: I had to re-image my SD card today. The LT:SC file came back in as a different file name! So I am thinking that was part of the copy protection. Re-created the file and it works again. it's likely a filename rule on the linux computer that renamed the file to be "allowed" but the tifiles header shouldn't have changed Quote Share this post Link to post Share on other sites
jedimatt42 #43 Posted October 18, 2020 9 hours ago, arcadeshopper said: it's likely a filename rule on the linux computer that renamed the file to be "allowed" but the tifiles header shouldn't have changed ':' is a perfectly legal linux file name character... never seen a linux system rename anything automatically. TIPI will populate the name in the TIFILES header, but never consumes it. On 10/16/2020 at 9:12 AM, Keneg said: Ok it works and only has to be done once. Once the file “LT:SC” is in the directory, it will auto load from extended BASIC if the directory is set as DSK1. Now I just have to figure out how to survive more than 30 seconds. LOL. I wonder if this was somehow a hidden file on the original disk that doesn’t copy correctly as a form of copy protection. I think this file should be added to the packages at the sites this can be downloaded from. I don't think the DSK on gameshelf should be modified. The game works fine with that disk image, if a regular floppy controller is available. It even works from TIPI if a regular floppy controller is available to error correctly. It comes to a design decision in TIPI that is incompatible with this software's expectations of original hardware. This is the first problem with this decision that the community has reported. I could probably set a config flag in TIPI to respond differently for systems that have no other storage devices, but it would have to be manually set. I will keep an eye on the value of that. 2 Quote Share this post Link to post Share on other sites
jrhodes #44 Posted October 18, 2020 6 hours ago, jedimatt42 said: I could probably set a config flag in TIPI to respond differently for systems that have no other storage devices, but it would have to be manually set. +1 to that. Quote Share this post Link to post Share on other sites
