Hello guys! I need your help Atari 800, ATARI 800XL/600XL owners!
If you guys own a caliber I urgently need to know which size in millimeters (or even better in keycaps unit 1U) the following keys:
ATARI 800:
  - CONTROL key (to my measurements using pictures found on internet) 1.5U
  - LSHIFT key 1.75U as well as the RSHIFT
  - FUNCTION KEYS (Select, Start...) 1.5U
  - CLR SET TAB key 1.5U
  - RETURN key 1.5U
ATARI 800XL
  - CONTROL key 2.0U
  - LSHIFT key 2.25U
  - RSHIFT key 2.0U
  - CAPS LOWR key 1.25U
  - RETURN key 1.75U
  - ESC key 1.25U
  - FUNCTION KEYS are spaced as 1U keysize.
The only correct keyboard I can check is the Atari 130XE style...
In attachment the PDF layouts of those keycaps (used by MaxKeyboard) and the keysize in keycap units.
Please help me,
Gianluca
atari-800-xl-style-maxkeyboard.pdf atari-xe-style-maxkeyboard.pdf
I have an 1983 ATARI 800.  Key sizes are:
CTRL, TAB, RETURN are all 1.5U
Left SHIFT key is 2U, right SHIFT key is 1.5U
Spacebar is 9U
Function keys are 1.5U
Row 1 is 15U wide overall
Row 2 is 15U wide
Row 3 is 14U wide and is offset 0.25U from the left side of rows 1 and 2.
Row 4 is 14U wide
Row 5 (spacebar) is 9U wide and is offset 2.5U from the left side of row 4
It would certainly still work to make the shift keys the same size at 1.75U and possibly eliminate the need for a stabilizer bar on the left shift key.
 Do you know where I could order a cherry mx keycap set for my 800 keyboard project like what you've designed here?
Edited by Krenath
