Fritz442
PAL\GAL Jedec map file testers needed
Hey all,
I am in need of some PAL\GAL chip testers. I have manually decoded the following PAL's:
PAL12L6 map files for GAL16V8 chips
Corcomp_DSDD_FDC_U1_PAL.JED
Corcomp_DSDD_FDC_U2_PAL.JED
Corcomp_MES_Lower_U2_(LB1A)_w-o FDC_PAL.JED
Corcomp_MES_Lower_U2_(LB1A)_w-FDC_PAL.JED
Corcomp_MES_Upper_U10_(UB2B)_w-FDC_PAL.JED
Corcomp_RS232_(REV-F)_U8_PAL.JED
Myarc_MEXP-1_32K-128K-512K_PAL.JED
TI_PHP1220_RS232_PAL.JED
TI_PHP1240_FDC_PAL.JED
TI_PHP1260_32K_PAL.JED
TI_PHP1270_P-CODE_PAL.JED
PAL16L8 map files for GAL16V8 chips
Corcomp_MES_Upper_U9_(UB1A)_w-FDC_PAL.JED
Corcomp_Triple_Tech_U7_(2CLKA)_PAL.JED
Corcomp_Triple_Tech_U23_(2-3TA)_PAL.JED
PAL16R4 map files for GAL16V8 chips
Corcomp_MES_Upper_U11_w-FDC_(UB3A)_PAL.JED
What I need is people that can program these into some GAL16V8-25LP chips and install them on boards to test.
I have tested all them on my boards successfully but would like more board testing. I have both the
PAL and GAL converted files.
Please PM me if you can test any of these. :thumbsup:
Edited by Fritz442
  • Like 7
I would like to test, have many of the most of the cards and devices listed, but repair on them are at a stand still due to covid related unemployment. Would like the files when tested and ready, as I believe I need some to repair some of the cards.
Yeah NP RickyDean, when I get them all retested I'll release them all here. :)
Edited by Fritz442
19 hours ago, Fritz442 said:
Hey all,
What I need is people that can program these into some GAL16V8 chips and install them on boards to test.
I have some GAL16V8, can program, but I can only try the TI cards.
14 minutes ago, mizapf said:
@Fritz442Can you create equations from your JED files? I'd be really interested.
mizapf, I'm not exactly sure what you mean by equations. :?  All I'm doing is creating patterns/sequences
for the output pins from the inputs.
The boolean equations are the source code. For example, you have input pins i1 and i2, and output o1 = i1 AND i2. The output o1 is defined by this equation. I programmed GALs 30 years ago (created my speech synthesizer adapter board this way), and I don't remember all details.
Wikipedia says that the Jedec files (.jed) contain the matrix of fuses of the PAL/GAL. A compiler produces this jedec file from the equations. It seems as if you reverse-engineered these matrices, but it should be easy to derive the equations from the matrix.
Yes I see what you are saying, but no...I'm not looking at AND's, OR's or any of that. I'm simply cycling the inputs to
get an output pin to go low and write down the each input switch position. I'm not compiling anything, just entering them
into the PAL.jed file as 0's and 1's. Then converting them to GAL.jed with PALTOGAL.exe to write them to 16V8 chip.
Not a very Hi-Tech way of doing this...but it seems to work.  :) LOL :)
There seems to be a tool JED2EQN, but I have not yet found out where to get it.
I'm used to starting with WinCUPL...
I managed to desolder one of the TI chips from the board... man those are tight against the PCB... resorted to hot air after the de-soldering tool wasn't good enough... Sadly I only have one socket on hand... but I did find a stock pile of ATF16V8...  :)
JED2EQN sounds interesting... gonna have to take a look at that. ( except you need a retro computer to run it )
JED2EQN is part of National Semiconductor's OPALjr package which you can download from [http://www.brouhaha.com/~eric/retrocomputing/mmi/palasm/opaljr21.zip]. I got the link from this page: [https://www.uchobby.com/index.php/2008/03/30/gals-for-electronics-hobby/].
I use the OPALjr package (EQN2JED) to compile the GAL for the Mini Cortex. You need to either run it on an old DOS computer, or I use DOSBox under Windows. You only need to extract the DEVICE.LIB, EQN2JED.EXE (or JED2EQN.EXE) and MANUAL.TXT files from the zip file - you don't need to use the installer.
Just tried JED2EQN with a .jed file I had set up to clone a 74LS138 - wasn't entirely successful as it said the /Y0 output was connected to GND ...
Edited by Stuart
In the case of the TI cards, the original JEDEC equations are available in several of the documents on WHT (I put them there many years ago). That should give you a good comparison set to verify the four TI cards in your list.
This would be awesome, except you said it is on WHT, and years ago... which I assume is a 3 letter filesystem name for http://ftp.whtech.com... The communities very own write only memory.
(I'm only partly sorry for writing that... I dream of giving up on software development and spending a decade exploding that archive of archives out to search engine friendly content.)
Any idea, what they'd be called in the sitelist.txt?
Here's a link to the document on WHT. My original copy was pretty gnarly, as it was a very late-generation photocopy, so I retyped the entire thing before I uploaded it in 2009. It has the equations for the RS-232, P-Code, 32K, and Disk Controller cards, along with the pin assignments for each of the PALs.
  • Like 4
  • Thanks 2
http://ftp.whtech.com/datasheets and manuals/Specifications/Peripheral Expansion System Theory Of Operation and Technical Traning Guide 1982-09-03.pdf
Oh, I have never looked in that one before... Always assumed it was just about a power supply and backplane.
That is a rich doc! About all of the individual peripherals from TI in great detail.
I'm glad you like it. Restoring that one was a lot of slow work, as the original was nearly illegible at various points.
This is all part of the OPAL programs used with some GAL programmer described in Elektor some where in the 1990.s. I have these programs and still use it  and run it in DosBox. Never used JED2EQN myself ... didn't know I had it until I looked just now.
Opal.zip
I tried it, and it seems to work (in dosbox).
This is the output of JED2EQN for the RS232 PAL:
; JED2EQN -- JEDEC file to Boolean Equations disassembler (Version V063)
; Copyright (c) National Semiconductor Corporation 1990-1993
; Disassembled from rs232.jed. Date: 10-27-120
chip rs232 PAL12L6
i1=1 i2=2 i3=3 i4=4 i5=5 i6=6 i7=7 i8=8 i9=9 GND=10 i11=11 i12=12
o13=13 o14=14 o15=15 o16=16 o17=17 o18=18 i19=19 VCC=20
equations
/o18 = /i2 * /i3 * /i19 * i4 * /i5 * /i6 * i7 * i8 * i12 * /i9 * i11
/o17 = /i2 * /i3 * /i19 * i4 * /i5 * /i6 * i7 * /i8 * i12 * i9 * i11
/o16 = /i2 * /i3 * /i19 * i4 * /i5 * /i6 * i7 * /i8 * i12 * /i9 * i11
/o15 = /i2 * i1 * i3 * i4 * i12 * /i11
/o14 = /i2 * i1 * i3 * i12 * /i11
/o13 = /i2 * i1 * i3 * /i4 * i12 * /i11
I just looked at the RS-232 equations. Outputs O13, O14, and O15 are correct. O16, O17, and O18 are half right. There are two separate sets of logical conditions for each of these last three outputs (an OR state), and the equation only identifies the first one. See page 5-16 of the document I linked to earlier. Note also that TI expected the input to be active low for some of the signals, so you have to pay attention to the states on those inputs/outputs in the document.
Yes TY Jim, I will be going back over these files again and have repaired the TI RS232 files.
Many I have done have multiple conditions\patterns that I have seen. This is why I NEED testers
before we post these files. :)
I have also added the 2 Triple Tech PAL's to the list.
here's the TI-FDC
; Disassembled from TIFDC_P.JED. Date: 11-1-120
chip TIFDC_P PAL12L6
i1=1 i2=2 i3=3 i4=4 i5=5 i6=6 i7=7 i8=8 i9=9 GND=10 i12=12 o13=13
o14=14 o15=15 o16=16 o17=17 i19=19 VCC=20
equations
/o17 = /i2 * /i3 * /i4 * i5 * i7 * i8 * i12 * i9
/o16 = /i2 * i1 * i3 * /i19 * /i4 * i5 * i6 * /i8 * i9
/o15 = /i2 * i1 * i3 * /i4 * i6 * /i8 * i9
/o14 = /i2 * i1 * i3 * i19 * /i4 * i5 * i6 * /i8 * i9
/o13 = /i2 * i1 * i3 * /i4 * /i5 * i6 * /i8 * i9
Look at output 17, I have i8 as HIGH, the PDF has i8 as LOW.
I wrote a GAL with input 8 LOW and it does not detect any drives.
Here's the TI-32K, seems to be the same.
; Disassembled from TI_32K_P.JED. Date: 11-1-120
chip TI_32K_P PAL12L6
o13=13 o14=14 o15=15 o16=16 o18=18 i19=19 VCC=20
equations
/o18 = i8
/o16 = i5 * i7
/o15 = i19 * i9
    + i12 * i11
/o14 = i2 * i1 * i3 * i4 * i5 * i6 * /i8
    + i2 * i1 * i3 * i4 * /i6 * i7 * /i8
/o13 = /i19 * i9
    + /i12 * i11
Edited by Fritz442
And the P-code. :)
; Disassembled from TI_PCD_P.JED. Date: 11-1-120
chip TI_PCD_P PAL12L6
o13=13 o14=14 o15=15 o16=16 o17=17 i19=19 VCC=20
equations
/o17 = /i2 * /i3 * i4 * i5 * /i6 * /i8 * i12 * i11
/o16 = /i2 * i1 * i3 * /i19 * i4 * i6 * /i7 * i12 * i9 * /i11
    + /i2 * i1 * i3 * i19 * i4 * i6 * /i7 * i12 * /i9 * /i11
/o15 = /i2 * i1 * i3 * i12 * /i11
/o14 = /i2 * i1 * i3 * /i4 * i12 * i9 * /i11
/o13 = /i2 * i1 * i3 * i4 * /i6 * i12 * i9 * /i11
    + /i2 * i1 * i3 * i4 * i7 * i12 * i9 * /i11
