Fritz442
PAL\GAL Jedec map file testers needed
I'll try and go through all of these tomorrow. Yes--there are some interesting differences that make sense to be opposite (I think TI was taking a signal that was considered to be a normal low and inverting it to get a high input)
22 hours ago, Fritz442 said:
Here's the TI-32K, seems to be the same.
; JED2EQN -- JEDEC file to Boolean Equations disassembler (Version V063)
; Copyright (c) National Semiconductor Corporation 1990-1993
; Disassembled from TI_32K_P.JED. Date: 11-1-120
chip TI_32K_P PAL12L6
i1=1 i2=2 i3=3 i4=4 i5=5 i6=6 i7=7 i8=8 i9=9 GND=10 i11=11 i12=12
o13=13 o14=14 o15=15 o16=16 o18=18 i19=19 VCC=20
equations
/o18 = i8
/o16 = i5 * i7
/o15 = i19 * i9
    + i12 * i11
/o14 = i2 * i1 * i3 * i4 * i5 * i6 * /i8
    + i2 * i1 * i3 * i4 * /i6 * i7 * /i8
/o13 = /i19 * i9
    + /i12 * i11
My code
32K-RAM-EXPANSI0N PHP 1260
PCBEN         * 1*    PAL    *20*    vcc
 AMC           * 2*              *19*    AD03
AMB            * 3*              *18*    MEMENB
AMA           * 4*               *17*    NC
A00           * 5*               *16*    AP02
A01           * 6*               *15*    RAS1
A02           * 7*               *14*    MESEL
/MEMEN    * 8*               *13*    RAS0
MQ2          * 9*               *12*    REFADR7
GND           *10*              *11*    REFRAS
/AP02   = A00* A02
/MEMENB = /MEMEN
/MESEL = PCBEN*AMA*AMB*AMC*MEMEN* /A01*A02 + PCBEN*AMA*AMB*AMC*MEMEN* A00* A01
/RAS0 = MQ2* /AD03 + REFRAS* /REFADR7
/RAS1 = MQ2* AD03 + REFRAS* REFADR7.
JL
Edited by humeur
error write
On 10/30/2020 at 9:22 PM, mizapf said:
I tried it, and it seems to work (in dosbox).
This is the output of JED2EQN for the RS232 PAL:
; Disassembled from rs232.jed. Date: 10-27-120
chip rs232 PAL12L6
o13=13 o14=14 o15=15 o16=16 o17=17 o18=18 i19=19 VCC=20
equations
/o18 = /i2 * /i3 * /i19 * i4 * /i5 * /i6 * i7 * i8 * i12 * /i9 * i11
/o17 = /i2 * /i3 * /i19 * i4 * /i5 * /i6 * i7 * /i8 * i12 * i9 * i11
/o16 = /i2 * /i3 * /i19 * i4 * /i5 * /i6 * i7 * /i8 * i12 * /i9 * i11
/o15 = /i2 * i1 * i3 * i4 * i12 * /i11
/o14 = /i2 * i1 * i3 * i12 * /i11
/o13 = /i2 * i1 * i3 * /i4 * i12 * /i11
 My Equation
PAL12L6
RS232/PI0  PHP 1220
AME    * 1*        *20*    vcc
A20    * 2*        *19*    CDS
A01    * 3*        *18*    UA1
A03    * 4*        *17*    UAO
A47    * 5*        *16*    CRU
AOS    * 6*        *15*    PIO
A06    * 7*        *14*    BDR
A08    * 8*        *13*    DSR
A09    * 9*        *12*    PCBEN
GND    *10*        *11*    /MEMEN
PAL12L6
RS232/PI0  PHP 1220
/DSR    =    /A20*    A01*    /A03*    MEMEN*    PCBEN*    AME
/PIO    =    /A20*    A01*    A03*    MEMEN*    PCBEN*    AME
/BDR    =    /A20*    A01*    MEMEN*    PCBEN*    AME
/CRU    =       /A20*/A01*A03*/A47*/A05*A06*/A08*/A09*/MEMEN*PCBEN*/CDS
                +    /A20*/A01*A03*/A47*A05*/A06*/A08*/A09*/MEMEN*PCBEN* CDS
/UAO    -    /A20*/A01*A03*/A47*/A05*A06*/A08*A09*/MEMEN*PCBEN*/CDS
                +      /A20*/A01*A03*/A47*A05*/A06*/A08*A09*/MEMEN*PCBEN* CDS
/UA1    -    /A20*/A01*A03*/A47*/A05*A06*A08*/A09*/MEMEN*PCBEN*/CDS
                + /A20*/A01*A03*/A47*A05*/A06*A08*/A09*/MEMEN*PCBEN* CDS
23 hours ago, Fritz442 said:
here's the TI-FDC
; Disassembled from TIFDC_P.JED. Date: 11-1-120
chip TIFDC_P PAL12L6
i1=1 i2=2 i3=3 i4=4 i5=5 i6=6 i7=7 i8=8 i9=9 GND=10 i12=12 o13=13
o14=14 o15=15 o16=16 o17=17 i19=19 VCC=20
equations
/o17 = /i2 * /i3 * /i4 * i5 * i7 * i8 * i12 * i9
/o16 = /i2 * i1 * i3 * /i19 * /i4 * i5 * i6 * /i8 * i9
/o15 = /i2 * i1 * i3 * /i4 * i6 * /i8 * i9
/o14 = /i2 * i1 * i3 * i19 * /i4 * i5 * i6 * /i8 * i9
/o13 = /i2 * i1 * i3 * /i4 * /i5 * i6 * /i8 * i9
Look at output 17, I have i8 as HIGH, the PDF has i8 as LOW.
I wrote a GAL with input 8 LOW and it does not detect any drives.
My Equation PHP1240
AME         * 1*         *20*    vcc
A00          * 2*        *19*    A411
A01          * 3*        *18*    NC
A02          * 4*        *17*    CRU
A03          * 5*        *16*    WDSEL
DEN          * 6*        *15*    BDR
A07          * 7*        *14*    U27
/MEMEN    * 8*        *13*    U26
PCBEN       * 9*        *12*    A46
GND          *10*        *11*    nc
/U26        =    /A00*    A01*    /A02*    /A03*    DEN*MEMEN*PCBEN*AME
/U27        =    /A00*    A01*    /A02*    A03*    A411*DEN*MEMEN*PCBEN*AME
/BDR        =    /A00*    A01*    /A02*    DEN*    MEMEN*PCBEN*AME
/UDSEL    =    /A00*    A01*    /A02*    A03*/A411*DEN*MEMEN*PCBEN*AME
/CRU        =    /A00*    /A01*    /A02*    A03*    A46*    A07*/MEMEN*PCBEN
Edited by humeur
1 hour ago, humeur said:
My code
 AMC           * 2*              *19*    AD03
AMA           * 4*               *17*    NC
A00           * 5*               *16*    AP02
A01           * 6*               *15*    RAS1
A02           * 7*               *14*    MESEL
/AP02   = A00* A02
/MEMENB = /MEMEN
JL
This matches the new JEDEC equations for the 32K card.
There have been several versions of pal for the 32 K ?
jl
We need to put the Hexbus sidecar ones on here too as soon as we figure them out.
jl
Not at all. The JEDEC file from the reverse-engineered PAL matches the TI equation set you posted. I saw no differences, so his new equation set is good.
Yes I agree, but someone with one has to do it. :thumbsup:
I am looking to repair the revision E and F SCSI cards for programming the GAL 16v8 and MACH211 if you have the jedec files, or any other documents such as diagrams.
  Thank
Je recherche pour réparer des carte SCSI révision E et F  la programmation de la GAL 16v8 et du MACH211 si vous avez les fichier jedec, ou tous autre documents comme les schémas.
Merci
@Ksarul has several prototypes - we just need very clear pictures of where the PAL lines go.  I think I posted some previously, but they were older pictures and not too clear.  https://atariage.com/forums/topic/306514-hexbus-jedimatt-compatible-sidecar/?do=findComment&comment=4531730
Here's the chips on board:
74LS259
74LS251
74LS74
1052911-X (TI Hexbus chip - @Ksarul has tons)
F4049BPC - Not sure.  Appears to be a Fairchild chip.
2532JL - 4K DSR (we have a dump)
PAL12L6 - the PAL
  Thank
Merci
Sorry humeur, I don't have any SCSI cards to get them from. :(
Thank you for your answer, whatever I will be patient.
JL
