shoestring
Uridium demo.
7 hours ago, TIX said:
Since the big ships look more or less identical in 2:2 Antic5 ratio  (with little touch-up),
lets concentrate on the sprites.. things are looking pretty good either way in my opinion !
With those examples you show what I was talking about 10 years ago. There is no real loss, if a double scanline mode is used.
While it saves memory, some additional frames can give even more "live experience" to the gamplay.
11 hours ago, José Pereira said:
Here's level_1 in 4x1 that I think doesn't look all that bad (with an enemy at the left side):
1149869151_01-Zinc21charlinesGRAYin4x1.thumb.png.f0d22f379de9a0f2129d74edbbb281e3.png
So black, white & grays more 2 on the enemy ship =6
Still 2 as PMG0&1 multicolour on our ship and one more left in GR.9...
Jose has trouble accessing Atariage so has emailed me with some additional notes, and to pass this on in the thread.
Quote
GR.10 9 colours registers: our ship: PM0 white + PM1 dark pale E (glass)=yellow (multicolour);
PM2: enemy shot (same as its dark colour luminance);
PM3: its shadow dark gray (same as in gfxs)
BAK: black;
PF0: light gray;
PF1: enemy ships light colour luminance;
PF2: enemy ships middle colour luminance;
PF3: coloured squares on the large ship;
BAK black, PM1 dark gray and PF0 light gray can then change as is on
C64 for other levels.
The PMGs would be, of course, more detailed in 2:1 ratio. Also enemy
ships explosion can be same ratio and a re-use of PM2 (if it was
destroyed maybe 'clean' that line shot).
Our ship shots, like is on C64, would be then maybe white.
As in GR. 10 the borders are by PM0 register that in our case is white
but also to have more visible playing area than better going to
48 bytes wide screen.
We'll also not include stars on the large ships scanlines as they
would look ugly in 4:1 ratio but only on the up and down of them
maybe in 3 'shining' colour using GR.15 bitmap mode 2:1 ratio. Maybe
even 'blinking' would make a nice effect. On C64 also enemies and our
ship seems to not go to these scanlines.
Why now bothering with graphics 10?
People blame the lower scrolling resolution of horizontal 160 pixel, and now turn even down to 80 pixel?
And then there is the GRPIOR that doesn't allow to use all PMg over the graphics, as the colors of the PMg itself were acting in GPRIOR  with the background colors starting at 704...
I thought in that but really had a mistake on my colours distribution so here's them fixed:
11 hours ago, shoestring said:
GR.10 has 9 colours registers:
our ship: PM0 pale green (EA) + PM1 dark pale (E4) (glass)= yellow (EE) (multicolour);
PM3: ours ship shadow dark gray (also on gfxs and shadows of them);
BAK: black;
PF0: white (also on gfxs, enemys and our ship shots);
PF1: light gray (also on gfxs);
BAK black, PM3 dark gray and PF1 light gray can then change as is on
Also will look better large ships be in 4:2 then the enemys in 4:1 ratio while our ship and its shadow be in 2:1 ratio PMGs:
1901244878_01-Zinc21charlinesGRAYin4x2.thumb.png.d40590884ce15722ef39687b4328a7d5.png
And just a piece of it for you seeing better with need to 'zooming' it:
189627866_01-Zinc21charlinesGRAYin4x2_justapieceofit.png.bd4a0105fcdc8c11f975202a413203cf.png
I think it could look nice and would be a new 'way of'...
Now @emkay there's only one thing there (just a pixel) that doesn't work with priority that is Prior_1 to be used... Guess what is it?
Clues: Our ship is PMGs so goes over all gfxs whatever they are (there's only a PMG register PMG3 on gfxs) and also enemy ships are just PFs and soft sprite 'bitmap masking' over large ship gfxs so no problem and theirs shots are PMG2 so always over whatever.
But that pixel can have a simple solution just enebling an A8 Hardware register ;).
Where's the Wally?
:grin:
:thumbsup:
Edited by José Pereira
Forget solution by using a Hardware register (it'll be used for other thing...). Yes, still remains that just single pixel but could not be all that important and workable.
  • Haha 1
Gotta say this is starting to look too low res now, the details don't really look 3d any more. Dropping the vertical white highlights has really lost something.
       263148675_Screenshot2020-11-20at11_11_45.thumb.png.9cc6c3a91e91b003aad31291a5d4265c.png
It's a huge ship, I don't see why we can't have vertical white highlights..
it just needs some love !
..looking for a way to draw the little diamond shaped thingies !
edit:  done 👍
Edited by TIX
That's much better, could the dark grey be one more shade darker? Also add one more line of dark at the beginning of the narrow neck to make it look more like the is height there.
Here's a thought, if the verticals are that thick, what does it look like if the horizontals are two pixels wide? It will probably be too much but worth a try.
edit:  done 👍
You know the problem? What you see in the picture has nothing to do with the Atari's hardware.
To have any separated colored moving object over the ship, you'd need to use playfield  colors, so you're restrictes to 80 pixel width based software sprites.
You cannot set colored PMg over the ship in GTIA 10, as the colors are a part of the background.
You could do some trickery using Playfield color 4  (711)  and the missiles active set to one color.
52 minutes ago, miker said:
Has emkay shared his version of this tube? I think he should.
I don't need to be credited here, just had some 15 mins fun on this.
He shared the previous version, 1.2. But I’m sure someone can do better than this. It would be nice with some drums but I couldn’t find a way to make the bass channel sound decent after splitting it.
16 hours ago, Stephen said:
Let's really save some CPU time.  We don't get too many ANTIC mode 8 games!
Better yet, let's hookup 8 of these in parallel and really kick ass in Mode 8 with 8 colors, 8X Players and Missiles, and essentially an 8 core CPU! However one small but significant problem - we'd also need an OS capable of working with parallel processors ;) . One can always dream.
Sorry for the off topic... carry on.
  • Haha 2
I had a bit of a set back a couple of weeks ago and lost everything in a HD crash, yup.. my own fault. That includes source code for the A8 diagnostic software I wrote and all my arcade related stuff.
So I had to start this project virtually from scratch and then use the xex I uploaded here to disassemble/reverse engineer what I did which helped me get back up to speed and on track rather quickly.
I now have the Manta's bullets working ( using soft sprites ) in the attract mode with collisions to objects in place ( that includes destruction of parked ships and collisions to the obstacles on it ).  Though that didn't take much work because the original game uses soft sprites for the players bullets as well.
Uridium.atr Uridiump.xex
  • Like 6
Just reread the first post I didn't realize you were porting the c64 code at first... so I guess it would be a mess to make major changes to the graphics mode... well I'm curious how you're going to tackle the sprites
