Sign in to follow this
Gury
Funkheld KickC questions
hello, load data (bin) to atarixl.
how can you change that below please:
export char DATEN[].....
export char SPRITE[] = kickasm(resource "sprite.png") {{
    .var pic = LoadPicture("sprite.png", List().add($000000, $ffffff))
    .for (var y=0; y<21; y++)
        .for (var x=0;x<3; x++)
            .byte pic.getSinglecolorByte(x,y)
greeting
greeting
A few questions:
1. What's the format of the source file? (i.e. what size is it (X by Y), and how many colours does it have?)
2. What format do you need to output to be in your own file?
3. Have you read section 12.4 of http://theweb.dk/KickAssembler/KickAssembler.pdf ?
Everything kick assembler supports for loading images is explained in the pdf above.
You have several ways to get the data and convert it into bytes in your program; getSingleColorByte, getMultiColorByte and getPixel.
If you provide a List (like you have in the code copied from kickc manual) it will convert any color 0 to $000000, and color 1 to $ffffff (3 bytes for R, G, B).
There is also an example in the manual of doing 4 colors. Alternatively you can use getPixel and do the conversion yourself.
But that's where you need to do the work.
Because you're in the world of kick assembler inside the kickasm block of code, you can do anything the assembler supports.
It has a quite extensive language built into it, so you can convert every pixel you are reading into anything you need, but without knowing what format you want the output to be, it's difficult to help you any more.
Don't know Kickc personally, but it looks like your trying to load a picture file, if thats so
then you need a device spect to load from i.e. LoadPicture("D1:sprite.png",
This is during assembly, not during runtime, so D1 isn't relevent here, as it's running on his laptop/PC.
His question is actually about kick assembler, which kickc passes its ASM generated file to, but in the case of the code listed above, you can see there's a "kickasm {{ ... }}" block, which kickc passes naked to the assembler.
It supports converting graphics into assembly output for you, and lots of other great stuff.
I think he's trying to take a PM graphics file and convert it to binary .bytes for his eventual program. This is all doable in the assembler, but we need more information about the specifics to really help.
Hi, Thank You.
I just want to load a bin file into an array from atarixl here.
this is  TEST.BIN (3840 byte)
array is : char data[]
export char DATA [] ....... without converting a file in any way.
greeting
Edited by funkheld
38 minutes ago, funkheld said:
Hi, Thank You.
This is how I usually initialize a char[] to the contents of a binary file.
export char TILES[] = kickasm(resource "smb1_chr.bin") {{
   .import binary "smb1_chr.bin"
If you know the size of the file to be 3840 you can help the compiler by specifying that
export char DATA[3840] = ...
A final note: The export keyword is not needed if your code uses the DATA array. It is only needed if you want to include the data in your program even if the code does not use it.
Not to hijack the thread, but thanks for the linker definition.  I think that is what I need.  My goal is not to get a smaller XEX file.  It's not to make a program run on a 32k atari either.
I have 2 goals - and I mention in case that influences the answer,  what I do want to do, is use bank switching.  I prefer to set up the code to use bank switching from the start, then go bonkers with animations and waste memory as I see fit.
However - today, I am not testing bank switching, I just want to start my code in Bank 2, and put my screen in Bank 1.  I will then someday swap banks around in the $4000 to $7FFF window as I see fit.
The secondary goal, is just to have the memory plan set - just simple reasonable something to get started, I just really cannot spend too much time on minutia, or the project bogs down.
So, here is my plan.  Start code at $8000 Bank 2.  That's be my program code.  Put my screen data in $4000, that'll be where Antic finds stuff.
Someday I may swap those banks, but today I'm not even doing that.
Here is the ld that I created, modified the the ld that was posted earlier in this thread.  Does it look like its reasonable?  It doesn't crash.
But, why do I have to define this segment called "Data".  What goes in Data?  I'm aware is some super basic question, but it just helps to ask the simplest of questions, because it clarifies.
thanks
Edit: In case it's not clear, I'm fine with this limitation: My code will not take more than 16K (Bank 2).  My characters data/animations will not take more than 64K (16k * 4 banks).
Doesn't matter to me if it was technically possible to squeeze out more, that would be for a future project to squeeze the last bit....:). haha...anyway, thanks in advance for any help!
//https://atariage.com/forums/topic/313212-funkheld-kickc-questions/
.file [name="%O", type="bin", segments="XexFile"]
.segmentdef XexFile
.segment XexFile
// Binary File Header
.byte $ff, $ff
// Program segment [start address, end address, data]
.word ProgramStart, ProgramEnd-1
.segmentout [ segments="Program" ]
// RunAd - Run Address Segment [start address, end address, data]
.word $02e0, $02e1
.word %E
.segmentdef Program [segments="ProgramStart, Code, Data, Screen, ProgramEnd"]
.segmentdef ProgramStart [start=$8000]
.segment ProgramStart
ProgramStart:
.segmentdef Code [startAfter="ProgramStart"]
.segmentdef Data [startAfter="Code"]
.segmentdef Screen [start=$4000]
.segmentdef ProgramEnd [startAfter="ProgramStart"]
.segment ProgramEnd
ProgramEnd:
Edited by Dmitry
P.s. I understand in Assembler, including KickAssembler, that I would use a * directive to tell the assembler where to place output, e.g. *=$4000 “Data”.   And I know that from reading the manual.  However, I didn't label a memory area called Data in my program.  I know of no reason why it's required, except I cannot remove it, or the compile fails.
Hi good afternoon.
years ago i had tested the compy-ram 512kb in altirra.
7680 byte shifted to $4000 and switched.
no further idea came to me to do something different.
your idea is great from $4000 to $7fff use as a program.
here is my simple demo of action!
greeting
MODULE
BYTE ARRAY COMPY =
[$23 $27 $2B $2F $63 $67 $6B $6F
 $61 $29 $65 $25 $69 $2D $6D $21
 $A1 $A3 $A5 $A7 $A9 $AB $AD $AF
 $E1 $E3 $E5 $E7 $E9 $EB $ED $EF]
PROC DELAY(CARD Z)
     CARD I
     FOR I=0 TO Z
     DO
     OD
RETURN
PROC MAIN ()
  CARD SAVMSC=$58, CO, I
  BYTE C, K, CO1
  CO=54017
  GRAPHICS (24)
  COLOR=1
  ZERO(SAVMSC,7680)
  PLOT(0,0)
  DRAWTO(159,95)
  C=PEEK(COMPY)
  POKE(CO,C)
  ZERO(16384,7680)
  MOVEBLOCK(16384,SAVMSC,7680)
  POKE(CO,253)
  ZERO(SAVMSC,7680)
  PLOT(159,0)
  DRAWTO(0,95)
  C=PEEK(COMPY+1)
  POKE(CO,C)
  ZERO(16384,7680)
  POKE(CO,253)
  ZERO(SAVMSC,7680)
  DELAY(50000)
  DELAY(50000)
  C=PEEK(COMPY)
  POKE(CO,C)
  MOVEBLOCK (SAVMSC,16384,7680)
  POKE(CO,253)
  DELAY(50000)
  DELAY(50000)
  C=PEEK(COMPY+1)
  POKE(CO,C)
  POKE(CO,253)
  DO
  OD
RETURN
Edited by funkheld
my program always starts at $ 8000 and the screen is at $ 4000.
if I have a simple dos-dsk, I can put the screen for $ 2000.
greeting
#pragma target(atarixl)
#pragma emulator("65XEDebugger")
#include <atari-xl.h>
char* SCREEN = $4000;
int zahl;
void main() {
 *SDMCTL = 0x21;
 *SDLST = DISPLAY_LIST;
    for(zahl=0;zahl<3600;zahl++) {
    SCREEN[zahl]=129;
    while (1) ;
char DISPLAY_LIST[] = {
  $70 , $70 , $70 , $4D ,
  $00 , $40 ,
  $0D , $0D , $0D , $0D , $0D , $0D , $0D , $0D , $0D , $0D ,
  $0D , $0D , $0D , $0D , $0D , $41
.segmentdef XexFile
.segment XexFile
.byte $ff, $ff
.word $02e0, $02e1
.word %E
ProgramStart:
.segment ProgramEnd
ProgramEnd:
I don't think this will work, as you're setting the ProgramEnd to be right after the ProgramStart.
Building XeX files has become much simpler in the latest version of kickC.
You can now use a loader file like this:
.plugin "dk.camelot64.kickass.xexplugin.AtariXex"
.file [name="%O", type="bin", segments="File"]
.segmentdef File [segments="Program", modify="XexFormat", _RunAddr=main]
.segmentdef Program [segments="Code, Data, Screen, DList, Fonts"]
.segmentdef Code [start=$8000]
.segmentdef DList [start=$5000]
.segmentdef Fonts [start=$7000]
All the old way of having $ff, and ProgramStart / ProgramEnd has been removed in place of the AtariXex plugin.
I've posted a full application build of your code at
This breaks the application up into different segments that load into different memory locations correctly.
It has the bonus of getting the file size down without you having to do anything, so consider that a gift :)
