Bill R Sullivan #76 Posted December 7, 2020 33 minutes ago, RXB said: It only resides in GROM 0, 1 and 2 and I have used GROM 0 only version that worked pretty well. SOB.zip 19.75 kB · 1 download Understood, I've downloaded the SOB.zip file, but it will probably be late afternoon tomorrow before I report back. Thanks for the download. 1 Quote Share this post Link to post Share on other sites
Bill R Sullivan #77 Posted December 8, 2020 (edited) 17 hours ago, RXB said: It only resides in GROM 0, 1 and 2 and I have used GROM 0 only version that worked pretty well. SOB.zip 19.75 kB · 5 downloads Well, I will have to admit that SOB is very impressive (OPA MICRO-MANAGER V1.10.9102.27)! Yes, I can even do a lot with it, but it won't satisfy my desire to complete TIB+. It will even load an MSAVEd TI Basic program (COLOR VISIONS), and it runs perfectly, but it cannot load TIB+ (also MSAVEd), because it does not have the E/A TI Basic support code: INIT, LOAD, LINK, PEEK, POKEV, PEEKV and CHARPAT (verified with DSRSCAN)! Should they ever add those very useful CALLs (also remember that they too must work within MSAVEd TIB+ programs, so your version of those CALLs require the Tursi fixes), let me know. Edited December 8, 2020 by Bill R Sullivan Added more info. Quote Share this post Link to post Share on other sites
+RXB #78 Posted December 8, 2020 3 hours ago, Bill R Sullivan said: Well, I will have to admit that SOB is very impressive (OPA MICRO-MANAGER V1.10.9102.27)! Yes, I can even do a lot with it, but it won't satisfy my desire to complete TIB+. It will even load an MSAVEd TI Basic program (COLOR VISIONS), and it runs perfectly, but it cannot load TIB+ (also MSAVEd), because it does not have the E/A TI Basic support code: INIT, LOAD, LINK, PEEK, POKEV, PEEKV and CHARPAT (verified with DSRSCAN)! Should they ever add those very useful CALLs (also remember that they too must work within MSAVEd TIB+ programs, so your version of those CALLs require the Tursi fixes), let me know. You mean my REA TI Basic support routines in TI Basic that Tursi fixed? Quote Share this post Link to post Share on other sites
Bill R Sullivan #79 Posted December 8, 2020 (edited) 16 minutes ago, RXB said: You mean my REA TI Basic support routines in TI Basic that Tursi fixed? Yes, I spelled them out: INIT, LOAD, LINK, PEEK, POKEV, PEEKV and CHARPAT that require Tursi's fixes. Any chance that this will happen in the next six months? They worked as is in TI Basic/TIB+ programs in VDP, but did not work from within MSAVEd TI Basic programs (GRAMs 3 - 7) that used those CALLs. Jeff White provided program tests that showed the problem, and I provided everything else needed for Tursi to find and fix the problem. I've been using his modified GK files EABASGRM & EABASGRM1 of your REA TI Basic files ever since. Edited December 8, 2020 by Bill R Sullivan Added more details. Quote Share this post Link to post Share on other sites
+RXB #80 Posted December 8, 2020 I have used XBRAMDISK myself: 100 !Saved program will stay in memory as long as you do not CALL INIT or turn memory expansion off. 110 !It will ever stay in memory when switching cartrides with a WIDGET. 200 CALL CLEAR 220 CALL CHAR(42,"AA55AA55AA55AA55",91,"7E8199A1A199817E") 230 CALL CHAR(45,RPT$("0",8)&"FF"&RPT$("0",10)&"10387CFEFE") 240 CALL CLEAR :: CALL HCHAR(2,4,42,26) 250 CALL VCHAR(3,4,42,5) :: CALL VCHAR(3,29,42,5) 260 DISPLAY AT(5,9)SIZE(12):"RAM-DISKETTE" 270 CALL HCHAR(8,4,42,26) 280 DISPLAY AT(12,4):"[ MARTIN KOTULLA 1985" 290 CALL HCHAR(13,6,45,22) :: DISPLAY AT(17,7):"DATAs CHECK? Y" 296 DISPLAY AT(22,4):"CALL LINK("&CHR$(34)&" LOAD"&CHR$(34)&") retrieve" 300 ACCEPT AT(17,22)BEEPSIZE(-1)VALIDATE("YN"):JN$ 310 IF JN$="N" THEN 360 320 FOR I=8192 TO 8458 STEP 2 :: READ A,B :: SUM=SUM+A+B :: NEXT I 330 DISPLAY AT(20,5):"THE DATA-LINES ARE" 340 IF SUM<>20638 THEN DISPLAY AT(22,10):"INCORRECT!" :: END 350 DISPLAY AT(22,11):"CORRECT!" 360 CALL INIT :: RESTORE 370 FOR I=8192 TO 8458 STEP 2 :: READ A,B :: CALL LOAD(I,A,B) :: NEXT I 380 CALL CLEAR :: STOP 390 DATA 032,068,255,255,000,000,170,085,000,000,041,097,032,056,033,126 400 DATA 032,056,033,226,032,056,035,076,032,056,036,050,032,056,036,110 410 DATA 032,056,036,132,032,056,036,144,247,147,248,118,255,231,247,146 420 DATA 255,255,076,079,065,068,032,032,032,196,083,065,086,069,032,032 430 DATA 032,122,000,000,002,001,032,050,002,129,032,066,027,014,192,001 440 DATA 002,002,131,074,140,176,022,006,140,176,022,004,140,176,022,002 450 DATA 192,048,004,080,002,033,000,008,016,239,002,000,037,000,200,000 460 DATA 131,034,002,224,131,224,004,096,000,206,002,224,032,008,192,032 470 DATA 131,132,096,032,131,048,002,032,033,012,002,128,064,000,026,003 480 DATA 002,000,011,000,016,236,007,032,032,048,192,032,131,048,002,001 490 DATA 033,012,220,112,136,000,131,132,018,252,200,032,131,048,032,040 500 DATA 200,032,131,050,032,042,200,032,131,132,032,044,200,032,131,134 510 DATA 032,046,016,029,002,224,032,008,200,032,032,048,032,048,022,003 520 DATA 002,000,029,000,016,204,192,032,032,040,002,001,033,012,220,049 530 DATA 136,000,032,044,018,252,200,032,032,040,131,048,200,032,032,042 540 DATA 131,050,200,032,032,044,131,132,200,032,032,046,131,134,004,192 550 DATA 216,000,131,124,002,224,131,224,004,096,000,112 560 END Quote Share this post Link to post Share on other sites
Bill R Sullivan #81 Posted December 8, 2020 19 minutes ago, RXB said: I have used XBRAMDISK myself: 100 !Saved program will stay in memory as long as you do not CALL INIT or turn memory expansion off. 110 !It will ever stay in memory when switching cartrides with a WIDGET. 200 CALL CLEAR 220 CALL CHAR(42,"AA55AA55AA55AA55",91,"7E8199A1A199817E") 230 CALL CHAR(45,RPT$("0",8)&"FF"&RPT$("0",10)&"10387CFEFE") 240 CALL CLEAR :: CALL HCHAR(2,4,42,26) 250 CALL VCHAR(3,4,42,5) :: CALL VCHAR(3,29,42,5) 260 DISPLAY AT(5,9)SIZE(12):"RAM-DISKETTE" 270 CALL HCHAR(8,4,42,26) 280 DISPLAY AT(12,4):"[ MARTIN KOTULLA 1985" 290 CALL HCHAR(13,6,45,22) :: DISPLAY AT(17,7):"DATAs CHECK? Y" 296 DISPLAY AT(22,4):"CALL LINK("&CHR$(34)&" LOAD"&CHR$(34)&") retrieve" 300 ACCEPT AT(17,22)BEEPSIZE(-1)VALIDATE("YN"):JN$ 310 IF JN$="N" THEN 360 320 FOR I=8192 TO 8458 STEP 2 :: READ A,B :: SUM=SUM+A+B :: NEXT I 330 DISPLAY AT(20,5):"THE DATA-LINES ARE" 340 IF SUM<>20638 THEN DISPLAY AT(22,10):"INCORRECT!" :: END 350 DISPLAY AT(22,11):"CORRECT!" 360 CALL INIT :: RESTORE 370 FOR I=8192 TO 8458 STEP 2 :: READ A,B :: CALL LOAD(I,A,B) :: NEXT I 380 CALL CLEAR :: STOP 390 DATA 032,068,255,255,000,000,170,085,000,000,041,097,032,056,033,126 400 DATA 032,056,033,226,032,056,035,076,032,056,036,050,032,056,036,110 410 DATA 032,056,036,132,032,056,036,144,247,147,248,118,255,231,247,146 420 DATA 255,255,076,079,065,068,032,032,032,196,083,065,086,069,032,032 430 DATA 032,122,000,000,002,001,032,050,002,129,032,066,027,014,192,001 440 DATA 002,002,131,074,140,176,022,006,140,176,022,004,140,176,022,002 450 DATA 192,048,004,080,002,033,000,008,016,239,002,000,037,000,200,000 460 DATA 131,034,002,224,131,224,004,096,000,206,002,224,032,008,192,032 470 DATA 131,132,096,032,131,048,002,032,033,012,002,128,064,000,026,003 480 DATA 002,000,011,000,016,236,007,032,032,048,192,032,131,048,002,001 490 DATA 033,012,220,112,136,000,131,132,018,252,200,032,131,048,032,040 500 DATA 200,032,131,050,032,042,200,032,131,132,032,044,200,032,131,134 510 DATA 032,046,016,029,002,224,032,008,200,032,032,048,032,048,022,003 520 DATA 002,000,029,000,016,204,192,032,032,040,002,001,033,012,220,049 530 DATA 136,000,032,044,018,252,200,032,032,040,131,048,200,032,032,042 540 DATA 131,050,200,032,032,044,131,132,200,032,032,046,131,134,004,192 550 DATA 216,000,131,124,002,224,131,224,004,096,000,112 560 END I don't understand the purpose of this as I don't run XB programs. I do occasionally use Super-XB loaded from FG99, when I have a major re-arrangement of code to do, but before and afterwards it will not run in XB! Therefore, it is necessary to select Editor/Assembler or Assembler/Editor by Winfred Winkler from FG99 or insert my SuperCart in the TI port. Right now I have my 80K MG GramKracker in the TI port with SOB and a few MSAVEd programs which work well if they don't contain any of the CALLs that this topic thread is about. Which I must also report that SOB operations and features are not well documented. So how about a manual for OPA MICRO-MANAGER V1.10.9102.27? Quote Share this post Link to post Share on other sites
Bill R Sullivan #82 Posted December 8, 2020 (edited) On 12/6/2020 at 4:20 AM, ralphb said: The SuperCarts are not compatible with the FinalGROM, because they have their RAM at a different address than the FG99 (even with options R, G, X). Hey Ralph, another thought crossed my mind as I was browsing though this topic thread; What addresses are used by FG99 for default, "R" and "X"? I can change the address for BCART in source or object code. Edited December 8, 2020 by Bill R Sullivan Fixed typo Quote Share this post Link to post Share on other sites
Bill R Sullivan #83 Posted December 8, 2020 On 11/24/2020 at 6:47 PM, HOME AUTOMATION said: There are different references as to how to create TI BASIC sub-programs, to be found here and there ...here is a somewhat useful one: http://www.nouspikel.com/ti99/titechpages.htm This would probably mean programming in assy. ...but that might not be what you want to do. I don't know how MSAVE works... I'm guessing it can load a saved file into GRAM? Setting up GRAM on FG99 shouldn't be too difficult... just need to create the desired size file, set the RAM byte, and perhaps set-up a header, using a hex-editor ...then end the filename with G.bin. So, we could make an image similar to that of the Super Space II, but using virtual ROM pages instead of RAM. Does TIB+, truly require RAM, or is RAM needed only to load??? Perhaps we could find an alternate way to load instead. Page switching would be through writes to ROM, rather than CRU switching, but could still be done through CALL LINK or CALL LOAD. Hey Alex, since Ralphb's response negated any chance of actually doing SuperCart/SuperSpaceI/II emulation I've reconsidered your idea: "Page switching would be through writes to ROM, rather than CRU switching, but could still be done through CALL LINK or CALL LOAD." Is this something you would still be willing to explore? If not I'll understand, as I don't want to waste your time. Quote Share this post Link to post Share on other sites
HOME AUTOMATION #84 Posted December 8, 2020 31 minutes ago, Bill R Sullivan said: Is this something you would still be willing to explore? Sure😃 ...however, I can't promise I'll be much help. Plus, it seems that my time is my own, less and less these days. I don't think you'll need an assy. subroutine to switch pages, as I believe you can just poke the addresses directly from BASIC, unlike with the SUPER SPACE II. I think the "R" or "X" need to be in the header, in order for FG99 to recognize them. That means that if your image includes GROM, then they should be specified there, instead of from the ROM's/RAM's .BIN. Although I have experimented with using 2 separate headers in such a case, usually there is only one... I think that is the way FG99, sees it ...Dunno for sure right now though. Quote Share this post Link to post Share on other sites
Bill R Sullivan #85 Posted December 8, 2020 6 minutes ago, HOME AUTOMATION said: Sure😃 ...however, I can't promise I'll be much help. Plus, it seems that my time is my own, less and less these days. I don't think you'll need an assy. subroutine to switch pages, as I believe you can just poke the addresses directly from BASIC, unlike with the SUPER SPACE II. I think the "R" or "X" need to be in the header, in order for FG99 to recognize them. That means that if your image includes GROM, then they should be specified there, instead of from the ROM's/RAM's .BIN. Although I have experimented with using 2 separate headers in such a case, usually there is only one... I think that is the way FG99, sees it ...Dunno for sure right now though. Yes, this is the idea, and I have asked Ralphb for the default, "R" and "X" addresses, so that aspect can be handled. RXB has put me onto SOB, OPA MICRO-MANAGER" that is helpful to TI Basic users/programmers, but is NOT a replacement for my TIB+ by any degree. My AL is much better when done in forth, which was the first computer programming language I learned back in the mid-70's, about 7 years before we got our first TI-99/4A for Christmas 1982. Let me know how you think we should begin, and when you might have a little time to do so, as I'm in the same boat, because my daughter wants to sell this house and move into a smaller house ASAP, and it's my house for as long as I'm alive. I wonder if I need to watch my back?🤨 Quote Share this post Link to post Share on other sites
Bill R Sullivan #86 Posted Wednesday at 07:30 PM On 11/10/2020 at 6:26 PM, acadiel said: Bill, @FALCOR4 is here on the forums and can likely help troubleshoot your GK. We also have the test utilities (burn in) that I uploaded to Whtech that can help diagnose what’s malfunctioning. I just want to thank you for putting FALCOR4 the Master MG GramKracker Repairman in touch with me, as he received my MG 80K GramKracker one day and the next day it was fixed (two problems, at least one caused by me), and then put into an overnight auto test, and will be shipped back to me today. Truly amazing! So thanks again, and all my best to you. RetroBill (fdos) 5 Quote Share this post Link to post Share on other sites
+acadiel #87 Posted Wednesday at 08:56 PM 1 hour ago, Bill R Sullivan said: I just want to thank you for putting FALCOR4 the Master MG GramKracker Repairman in touch with me, as he received my MG 80K GramKracker one day and the next day it was fixed (two problems, at least one caused by me), and then put into an overnight auto test, and will be shipped back to me today. Truly amazing! So thanks again, and all my best to you. RetroBill (fdos) He's an amazing guy. I really am thankful we got him back in touch with the community! 3 Quote Share this post Link to post Share on other sites
Bill R Sullivan #88 Posted Wednesday at 09:24 PM 28 minutes ago, acadiel said: He's an amazing guy. I really am thankful we got him back in touch with the community! Me toooooooooooooooooooooooooooooooooooooooooooooooooooo! 1 Quote Share this post Link to post Share on other sites
Bill R Sullivan #89 Posted 2 hours ago I've totally checked out my 80K MG GramKracker, and all aspects are working as they should, so I'm a very satisfied customer. I still need to find someone willing to fix my SNUG EVPC, then all my systems that I kept will be operational. Quote Share this post Link to post Share on other sites
Bill R Sullivan #90 Posted 2 hours ago On 11/9/2020 at 2:56 PM, Bill R Sullivan said: A couple of years ago I requested GROM0, GROM1 & GROM2 be made available as GRAM0, GRAM1 & GRAM2, which would not only be very useful for my TIB+ project, but also to XB users (4ADOS,OS99 and others). Nothing came of it, so this request is for Super Space II, as I don't know if I'll ever get my actual Super Space II to ever work again, even for just BANK 0 (SuperCart) only operation. RetroBill (fdos) I'm glad to report that I myself found the actual Super Space II problem and fixed it, as I can now select all four banks and save BCART Basic programs in each using HOME AUTOMATION'S FDOS or just CALL LINK the object file. So my plan for this module will succeed. And a huge thank you to FALCOR4 for finding all the problems in my 80K MG GramKracker and fixing them in less than two days. There are some really great guys, and probably gals, here. Unfortunately, it is not possible to BCART save Basic programs in the MG GramKracker RAM banks, so I will have to make do with 40K of MSAVE space by avoiding RESTORE line numbers which do work in BCART. Quote Share this post Link to post Share on other sites
