NinSEGA Posted November 14, 2020 Share Posted November 14, 2020 (edited) I managed to snag a copy, but it's not booting up on either converter, and I don't have an actual Master System to try it on. I read somewhere that it's either because it's an 8-meg cartridge or only compatible with PAL or Brazilian machines, but the posters on those forums weren't 100% sure and had conflicting info. Does anyone here know for sure? EDIT: I tested it out in a Sega Game Gear 2110G using a Master Gear Converter (Model G-233), and it worked perfectly. Edited November 14, 2020 by NinSEGA 1 Quote Link to comment Share on other sites More sharing options...
stringfellow Posted November 14, 2020 Share Posted November 14, 2020 as far as I know the master system is region free. It is possible that it won't play through a converter since a couple games don't. I would try giving it one last good cleaning. Sometimes I think I have cleaned a game well but I try again and it isn't. If you still can't get it to work I would be happy to test it for you on my master system. I actually would like a copy for myself as well. Quote Link to comment Share on other sites More sharing options...
NinSEGA Posted November 15, 2020 Author Share Posted November 15, 2020 8 minutes ago, stringfellow said: as far as I know the master system is region free. It is possible that it won't play through a converter since a couple games don't. I would try giving it one last good cleaning. Sometimes I think I have cleaned a game well but I try again and it isn't. If you still can't get it to work I would be happy to test it for you on my master system. I actually would like a copy for myself as well. I managed to get it to work on my Game Gear 2110G using a Master Gear Converter (Model: G-233)- Quote Link to comment Share on other sites More sharing options...
stringfellow Posted November 16, 2020 Share Posted November 16, 2020 glad you got it to work Quote Link to comment Share on other sites More sharing options...
MojoJoJo Posted December 26, 2020 Share Posted December 26, 2020 With the bigger Brazilian carts, they won't work on a regular Master System. However, they will work on a Power Base converter (you may need to hit the reset button on the Genesis console to get it to work). I had similar issues with Street Fighter 2 for the Brazilian Master System. And of course, as you experienced, it will work on a Game Gear with the adapter. Quote Link to comment Share on other sites More sharing options...
stringfellow Posted December 26, 2020 Share Posted December 26, 2020 1 hour ago, MojoJoJo said: With the bigger Brazilian carts, they won't work on a regular Master System. However, they will work on a Power Base converter (you may need to hit the reset button on the Genesis console to get it to work). I had similar issues with Street Fighter 2 for the Brazilian Master System. And of course, as you experienced, it will work on a Game Gear with the adapter. wow good to know. I was considering buying a couple of those. I did get Street Fighter 2 to work on the master system via everdrive though Quote Link to comment Share on other sites More sharing options...
MojoJoJo Posted December 26, 2020 Share Posted December 26, 2020 There was a guide that I have to dig up but I believe he said the Master System 2 had no issues. Quote Link to comment Share on other sites More sharing options...
MojoJoJo Posted December 30, 2020 Share Posted December 30, 2020 Sorry for the delay but I hope this helps: https://www.smspower.org/forums/12093-ListOfIncompatibilitiesAmongSMSGamesHardware 1 Quote Link to comment Share on other sites More sharing options...
zetastrike Posted December 31, 2020 Share Posted December 31, 2020 I've always liked Sonic Blast. The hate that it gets is so ridiculous, it's just like the other 8-bit Sonic games, just with a different art style. "Sonic Blast is a horrible game" has just become the accepted canon for the hivemind for some reason. I'd say the level design is better than most of them, as there's some meat on the bone and you can't just hold right and finish them in 12 seconds. I would easily call Sonic 2 and Chaos worse than Blast. I'd probably rather play Blast than Sonic 1 most days. 1 Quote Link to comment Share on other sites More sharing options...
stringfellow Posted July 16, 2022 Share Posted July 16, 2022 I forgot all about this problem and purchased virtua fighter animation for the master system. I was begining to think I got a bad cartridge when I remembered this thread. Checked out the above link and sure enough it is one of the incompatible games for my system variation Quote Link to comment Share on other sites More sharing options...
M-S Posted July 16, 2022 Share Posted July 16, 2022 On 11/14/2020 at 8:01 PM, NinSEGA said: I managed to snag a copy, but it's not booting up on either converter, and I don't have an actual Master System to try it on. I read somewhere that it's either because it's an 8-meg cartridge or only compatible with PAL or Brazilian machines, but the posters on those forums weren't 100% sure and had conflicting info. Many people think Brazil used the same PAL system as Europe that had 50hz for the speed, but here we used PAL-M, ran at 60Hz but with a different color pallete. Quote Link to comment Share on other sites More sharing options...
stringfellow Posted July 19, 2022 Share Posted July 19, 2022 On 7/15/2022 at 9:52 PM, M-S said: Many people think Brazil used the same PAL system as Europe that had 50hz for the speed, but here we used PAL-M, ran at 60Hz but with a different color pallete. I believe I read that if I had a different bios version it might work. Either way it is cool to have in my collection. I have played a couple of the incompatible games using an everdrive Quote Link to comment Share on other sites More sharing options...
