xxx
im having problems loading from disks in mess
ive tried the new version (which wont recognize disks) and an older version MESS 0.37 BETA 15 (which seems better). and neither versions load carts. i can get the cassette to work, both loading and saving. ive also tried 99menu, which doesnt help.
Edited by xxx
Use the latest version of MAME it has all the latest features and bug fixes mame version 37 is ancient.
Mess and MAME were combined into one program a few years ago so if you're running mess it's probably very old as far as development is concerned.
Conveniently for you the active developer is in this forum and I'm sure he will chime in as well but I'll give you some hints.
One if you're using disk images the ti disk controller can only handle 90k and 180k sssd and dssd images that's because that controller can only handle that size disks in real life. If your disk images are larger than that then you should use a controller that supports those formats such as the Corcomp, Myarc or my favorite the Myarc HFDC.
There's a front end being made for MAME by one of the forum members here shift838. It's in current development that I expect him to release it any day he probably will be happy to let you try a beta copy if you ask
Posting details will get you a lot more help than "it just don't work" for instance you could have told us which disk controller you were using and what the size of the disk images are etc..
Greg
Stay informed about MAME progress related to the TI platform on my pages https://www.mizapf.de/en/ti99/mame. New features, bug fixes etc.: https://www.mizapf.de/en/ti99/mame/changes
The version you mentioned must be about 20 years old, much earlier than I started contributing, so I really cannot help you with that.
Greg
i'm doing a final compile of OoeyGUI v4.0 tonight.  I believe it is ready for release and will be posting in a separate thread soon.
Greg
im using 90k and 180k disks. the new version of mame and ooeygui does a similar thing. the carts dont work and the disk directories are not available in mame. it does boot if nothing is attached though. it looks like there is a driver or something that is needed as running mame on its own doesnt show disk directories.
Edited by xxx
unzip: C:\mame0212b\carts\BlastoG.Bin couldn't find ECD
Fatal error: Device TI-99 cartridge load failed: Invalid image
ive tried multiple carts
MAME does not use the "bin" cartridges but either the RPK or ZIP files. Never unzip a cartridge ZIP file (apart from the all_carts.zip, which contains all ZIP cartridges). We have them all on WHTech, https://ftp.whtech.com/Cartridges/MAME
mame ti99_4a -cart blasto
(no .rpk, no .zip, no .bin in the command line)
Put the ZIP cartridges in your roms subdirectory.
Disks will only work when you attach the hardware. You must plug in the Peripheral Expansion Box into the I/O port, and a disk controller (e.g. DDCC-1) into one slot.
mame ti99_4a -ioport peb -ioport:peb:slot8 ddcc1 -flop1 somefloppyimage.dsk
mame doesnt start when i try zip files. ive attached the disk hardware but this still wont work, sorry
QWindowsNativeFileDialogBase::onSelectionChange (QUrl("file:///C:/mame0212b/roms/alienadd.zip")) 1
ive tried multiple carts in this instance, also
Edited by xxx
2 minutes ago, mizapf said:
Please post the command line that you tried.
im not using command line im using ooeygui
Edited by xxx
OK, then Chris @Shift838 may help you better.
You could, for a start, try the command line first, just to make sure everything is in place.
im having problems with this bit of software, any chance of a little help?
I believe Ooeygui V 3.5 works on MAME V224 and below. Ooeygui 4.0 is for V225 and above (remember the Horizon emulation is broken in V225 and V226). The difference between V3.5 and 4.0 is that the Python code must be loaded separately into the folder holding MAME and Ooeygui in 3.5 but Python and Ooeygui are combined in 4.0. Also, Ooeygui 4.0 is designed only for MAME V225 and above according to the author. I am using Ooeygui 3.5 and MAME V224 since I use the Horizon emulation and it works fine - no problems at all.
I'm using the .rpk cartridge versions and .dsk for disks
Edited by atrax27407
likely you haven't put the rompath correctly for your software directory, you have to add it to the rompath or place it in the existing rom directory.. easier to add it
i just tried the correct version of mame 0.210. still does exactly the same thing. im using ooeygui 3.0. i cant seem to find 3.5
Edited by xxx
