Macross_VF1 #1 Posted November 23, 2020 So I might be able to score a pal Atari 800 computer in just a few days but it is missing the power supply. I have a pal Atari 400 with PSU and from my research it would seem that it should work with the 800 as well, but just to be on the safe side I figured I should confirm that it actually is compatible? Quote Share this post Link to post Share on other sites
xrbrevin #2 Posted November 23, 2020 here is the info you need, courtesy of Atarimania http://www.atarimania.com/faq-atari-400-800-xl-xe-what-are-the-power-requirements-for-my-atari-components_59.html but yes i the same Atari 9VAC PSU with my 1050, 400 and 800 1 Quote Share this post Link to post Share on other sites
Macross_VF1 #3 Posted November 23, 2020 Yup, that's exactly the site I have been using. Thanks for confirming! Quote Share this post Link to post Share on other sites
sup8pdct #4 Posted November 26, 2020 Only thing to watch is the VA rateing. The 800 takes more power then a 400. My pal 400 psu is a small brick, one for 800 was a much larger brick. It will run the 800 but may get a lot hotter. James Quote Share this post Link to post Share on other sites
BillC #5 Posted November 27, 2020 12 hours ago, sup8pdct said: Only thing to watch is the VA rateing. The 800 takes more power then a 400. My pal 400 psu is a small brick, one for 800 was a much larger brick. It will run the 800 but may get a lot hotter. It's also likely to blow the fuse inside the 15VA version as well, I had this happen to my 400 power supply after I had it upgraded with a Mosaic 64K RAM card. Quote Share this post Link to post Share on other sites
+slx #6 Posted November 27, 2020 9V AC PSUs seem to be required for some musical equipment, so you might want to check musical equipment stores. I found this on Amazon but I think the plug might need to be changed for a 5/2,5mm one. Amazon used to sell a 2.1A Rockpower brand PSU that fit without changing the plug and should work for floppy drives as well but I couldn't find them on Amazon any more. Quote Share this post Link to post Share on other sites
Fox-1 / mnx #7 Posted November 29, 2020 (edited) If you're confident enough to do it, you can built your own with a generic 10V transformer like this one: Toroidal mains transformer This example is 100VA, enough to power 5 800's, but smaller versions exist. Edited November 29, 2020 by Fox-1 / mnx Quote Share this post Link to post Share on other sites
