SS
Different FujiNet performance on different machines
For people with multiple Ataris - does you FujiNet seem to work better with one machine over another?  For example, I often seem to have difficulties making a connection to various networks on my 576K/32-IN-1 800XL but rarely have the same troubles with my U1MB 800XL.  My 52K 400 made the connections most time and loaded the few games that I tried but then could not display the graphics on Weather.xex even though it all seemed to load.  My ANTONIA 600XL is mostly OK with the FujiNet but sometimes needs a reboot or two in order to connect to various servers.  My one stock 800XL has a Taiwanese made motherboard in it and seems to load everything without issue.
Has anyone else experienced different results on different machines?
The weather app requires XL/XE OS.
Maybe someone else can chime in on the other issues. Perhaps it's related to the upgrades and how they work. Can you capture some FujiNet debug output when the failures happen? Connect the FujiNet to a computer with USB, run the fujiNet flasher and click the serial debug button. You can then copy and paste the output.
If you're talking about the Internet connection to TNFS servers, then that's going to come down to WiFi performance.  There's both signal strength and, separately, interference.  I'm going to assume the different Ataris you're testing with are in the same room, so signal strength should be roughly the same (tell us if they're in different locations).  In that case, my guess would be there's different radio interference levels between the small difference in location of the different machines.  It's also possible each Atari is generating different levels of interference, although that seems less likely.
I would try this: if you're consistently having a difficult time with FN plugged in to one Atari compared to another, try switching the location of the two Ataris and see if the problem is still consistent with the machine FN is pluggeg into or with the physical location where the FN is at.
@jamm - I don't see how this could be the problem because the Ataris were literally a foot from each other on my dining room table with the router in line of sight and only about 20 feet away.  Now I'm wondering if maybe you might be on to something with the idea that the Ataris themselves might be causing interference.  The modded XLs all have their RF modulators intact and their top shielding removed and the two that are the worst FujiNet performers have their bottom shielding off as well.  The 400, of course, has it's tank-like shielding and the unmodified 800XL also has top and bottom shields; they are the two best performers with the FujiNet.
Yeah, I wondered about your shielding situation. Personally, I do almost all my work on an 800, which is as much of tank as the 400.
I have had different behaviors due to different OS. I think part of what you are observing is due to that. I have experienced weirdness regarding High speed OS, with certain pokey divisor numbers, like not connecting to my wifi access point, or having wifi problems,  the HS not working anymore, or when HS is enabled and there are other devices in the SIO chain, the Fujinet not working.
I will need to setup to capture the debug messages to really help regarding these bugs, but anyway.
I will see what I can do over the next few days and will get back to you.
FN's WiFi connectivity is entirely disconnected from the Atari and SIO communication (unless you're trying to set the WiFi password and failing due to SIO failures, but if that were the case you wouldn't even be able to boot into the CONFIG program due to the same SIO failures).
Outside of configuring the right password, the only way the Atari could affect WiFi connectivity would be by causing radio interference. And honestly that's only theoretical - I've never actually seen that happen or heard of it happening.
I've been doing some more testing with different machines, including a 600XL with a 1064 attached and the stock 800XL with a SYS-Check.  I am beginning to think that maybe what the FujiNet *really* doesn't like is the AtariMax 32-in-1 board; this seems to be the one machine that gives me consistent errors.  On attmpted boot-up, the main FujiNet screen often just locks up as it's trying to load.  This doesn't seem to be consistent behavior on any of the other machines.   Has anyone else tried using FujiNet on an AtariMax 32-in-1 upgraded machine?
Could you try syscheck with HS patch OS and FujiNet set to Pokey divisor 3?
It works but keeps asking me the wifi password after every boot. I switch the pokey divisor to 2 for example, and everything goes back to normal. I don't have a PC close to the Atari to save the debug output.
This doesn't seem to be causing any issues for me.  The Atari and FujiNet reboot fine and do not ask for a password reset.
Not exactly on topic, but maybe relevant...
I just installed a Sofia video upgrade in my 800XL and discovered that it interferes with FujiNet wireless connectivity. I mounted the DVI connector above the expansion port as this was the easiest spot to put it. The ribbon cable is long enough, which suggests that this might have been an intended location. However, when I plug in a DVI to HDMI cable, I can't load or boot any disks from the internet or my local TNFS server successfully. As soon as I unplug the DVI to HDMI cable, it works again. This suggests that some kind of WiFi interference is coming from the cable. The Sofia components alone, when the cable is not connected, don't seem to cause the problem.
It looks like I'll have to relocate the DVI port further away from the FujiNet. When I was testing the Sofia, before making a hole and mounting the connector above the expansion port, I ran the ribbon cable straight back out of the machine, just above the RF modulator. I had no interference issues with the DVI to HDMI cable when using it that way. So I believe if I relocate the DVI port somewhere on the left side of the 800XL, it should eliminate the problem. Too bad about the unsightly hole that will remain above the expansion port.
Edited by Mark Simonson
@Mark Simonson - My 600XL also has its SOPHIA DVI connector located right above the expansion port.  When I initially started trying to set up the FujiNet, I was using this machine and the FujiNet kept giving me connection errors.  It could see the Wifi signal but refused to connect to it.  I had to use another machine in order to finalize the setup process.  Once the FujiNet was configured though this machine seems to work *mostly* OK with the FujiNet, although it still occasionally times out when trying to load a program over Wifi.
My other thought is that instead of drilling a second hole in your XL case for the DVI out, you could attach your FujiNet to the SIO port via a SIO cable.  That should in theory move the FujiNet far enough away in order to keep the interference from occurring. It won't look quite as sleek but it would certainly be better than a second empty hole in your machine.
I've decided to make a second hole anyway to keep everything neat and tidy, with the FujiNet snug up against the back. I've already successfully removed the unneeded RF modulator to make room for it. I should have done it this way in the first place, but I thought I could save some time by putting it on the right.
There's probably a way to hide the first hole. Maybe a sticker or something. 🙂
@flashjazzcat 's videos have been a big help, both for showing how to cut the hole and removing the RF modulator.)
Interestingly, moving the DVI cable to the left side barely helped. I did a little experiment and placed the 800XL's RF shield (which no longer fits inside the machine) over the DVI to HDMI cable to see if it would block the interference, and it did well enough to mount disk images and so on over WiFi. It hesitates sometimes, like it's having trouble connecting, but mostly works. This isn't really a solution, but it does confirm that the cable is the problem.
I'm not sure now what can be done for this, as there is no place else to put the DVI out port. Thinking that maybe the shielding on the cable is defective, I've sent for a different one.
I guess there is always @SS's suggestion about moving the FujiNet further away. EDIT: I tried it and it does work well that way, even if it looks weird. So, thanks for that! At least I have a workaround for now.
This pretty accurately describes the behavior that I see with my SOPHIA machine too.  Sometimes it just times out and I cannot get a full load at all.  I got the cable idea when I was trying the FujiNet with a 600XL with a 1064 attached because everything simply would not fit next to each other.  The extra distance does seem to help sometimes though.
I am experiencing exactly that, and I concluded it is the Wifi. I activated the hotspot feature in my smartphone, and everything worked as expected (even with 3G speeds, it was faster than my home 2.4GHz Wifi).
I will need to figure out what the differences are, maybe it is just signal level too low, or the authentication type, etc.
Now that I have figured out that I need to move the FujiNet further away from the SOPHIA DVI output connector on my one 600XL by attaching it via SIO cable, it seems like the only consistent errors that I am seeing are on the AtariMAX 32-in-1 machine.  Sometimes it will work but with A LOT of pauses during the loading process, sometimes it will just time out completely, and sometimes I get errors like in the attached screenshot.   This has got to be caused by some incompatibility with the machines's hardware (most likely the 32-in-1), doesn't it?
Here is the entire output log from the session.  I was't sure how much of it that you actually neededUsing 'COM3' as serial port.
Showing logs:
[12:32:20]SNTP time sync event: Mon Nov 30, 17:32:20 2020 +0000
[12:32:22][12:32:22]E (692) uart: uart_write_bytes(1111): uart driver error
[12:32:22]
[12:32:22]
[12:32:22]--~--~--~--
[12:32:22]FujiNet 0.5.72ebaec0 2020-10-24 16:05:30 Started @ 32
[12:32:22]Starting heap: 4087244
[12:32:22]PsramSize 3932108
[12:32:22]himem phys 4456448
[12:32:22]himem free 4456448
[12:32:22]himem reserved 262144
[12:32:22]FujiNet Hardware v1.0
[12:32:22]SPIFFS mounted.
[12:32:22]E (1168) sdmmc_sd: sdmmc_enable_hs_mode_and_check: select_card (1) returned 0x106
[12:32:22]SD mounted.
[12:32:22]fnConfig::load
[12:32:22]Found copy of config file on SD - copying that to SPIFFS
[12:32:23]copy_file "/fnconfig.ini" -> "/fnconfig.ini"
[12:32:23]copy_file copied 528 bytes
[12:32:23]fnConfig::load read 528 bytes from config file
[12:32:23]WIFI_EVENT_STA_START
[12:32:23]WiFi connect attempt to SSID "e46f1399d57d"
[12:32:23]esp_wifi_connect returned 0
[12:32:23]disk MOUNT
[12:32:23]ATR MOUNT
[12:32:23]mounted ATR: paragraphs=5760, sect_size=128, sect_count=720, disk_size=0
[12:32:23]Creating a default printer using FS_SDFAT storage and type 1
[12:32:23]SIO SETUP
[12:32:23]Set HSIO baud from 0 to 67431 (index 6), alt=68209
[12:32:23]Available heap: 3964148
[12:32:23]Setup complete @ 579 (547ms)
[12:32:23]WIFI_EVENT_STA_CONNECTED
[12:32:27]IP_EVENT_STA_GOT_IP
[12:32:27]Obtained IP address: 192.168.1.7
[12:32:27]SNTP client start
[12:32:27]Starting web server on port 80
[12:32:31]SNTP time sync event: Mon Nov 30, 17:32:31 2020 +0000
[12:32:38]
[12:32:39]CF: 31 53 00 00 84
[12:32:39]FujiNet CONFIG boot
[12:32:39]disk sio_process()
[12:32:39]ignoring status command
[12:32:39]
[12:32:39]
[12:32:39]
[12:32:39]
[12:32:39]
[12:32:39]ACK!
[12:32:39]disk STATUS
[12:32:39]response: 0x00, 0xff, 0xfe
[12:32:39]->SIO write 4 bytes
[12:32:39]COMPLETE!
[12:32:39]
[12:32:39]CF: 31 52 01 00 84
[12:32:39]ACK!
[12:32:39]ATR READ
[12:32:39]->SIO write 128 bytes
[12:32:39]COMPLETE!
[12:32:39]
[12:32:39]CF: 31 52 02 00 85
[12:32:39]ACK!
[12:32:39]ATR READ
[12:32:39]COMPLETE!
[12:32:39]
[12:32:39]CF: 31 52 03 00 86
[12:32:39]ACK!
[12:32:39]ATR READ
[12:32:39]COMPLETE!
[12:32:39]
[12:32:39]CF: 31 52 69 01 ed
[12:32:39]ACK!
[12:32:39]ATR READ
[12:32:39]COMPLETE!
[12:32:39]
[12:32:39]CF: 31 52 04 00 87
[12:32:39]ACK!
[12:32:39]ATR READ
[12:32:39]COMPLETE!
[12:32:39]
[12:32:39]CF: 31 52 05 00 88
[12:32:39]ACK!
[12:32:39]ATR READ
[12:32:39]COMPLETE!
[12:32:39]
[12:32:39]CF: 31 52 06 00 89
[12:32:39]ACK!
[12:32:39]ATR READ
[12:32:39]COMPLETE!
[12:32:39]
[12:32:39]CF: 31 52 07 00 8a
[12:32:39]ACK!
[12:32:39]ATR READ
[12:32:39]COMPLETE!
[12:32:39]
[12:32:39]CF: 31 52 08 00 8b
[12:32:39]ACK!
[12:32:39]ATR READ
[12:32:39]COMPLETE!
[12:32:39]
[12:32:39]CF: 31 52 09 00 8c
[12:32:39]ACK!
[12:32:39]ATR READ
[12:32:39]COMPLETE!
[12:32:40]
[12:32:40]CF: 31 52 0a 00 8d
[12:32:40]FujiNet CONFIG boot
[12:32:40]disk sio_process()
[12:32:40]ACK!
[12:32:40]ATR READ
[12:32:40]->SIO write 128 bytes
[12:32:40]COMPLETE!
[12:32:40]
[12:32:40]CF: 31 52 0b 00 8e
[12:32:40]ACK!
[12:32:40]ATR READ
[12:32:40]COMPLETE!
[12:32:40]
[12:32:40]CF: 31 52 0c 00 8f
[12:32:40]ACK!
[12:32:40]ATR READ
[12:32:40]COMPLETE!
[12:32:40]
[12:32:40]CF: 31 52 0d 00 90
[12:32:40]ACK!
[12:32:40]ATR READ
[12:32:40]COMPLETE!
[12:32:40]
[12:32:40]CF: 31 52 0e 00 91
[12:32:40]ACK!
[12:32:40]ATR READ
[12:32:40]COMPLETE!
[12:32:40]
[12:32:40]CF: 31 52 0f 00 92
[12:32:40]ACK!
[12:32:40]ATR READ
[12:32:40]COMPLETE!
[12:32:40]
[12:32:40]CF: 31 52 10 00 93
[12:32:40]ACK!
[12:32:40]ATR READ
[12:32:40]COMPLETE!
[12:32:40]
[12:32:40]CF: 31 52 11 00 94
[12:32:40]ACK!
[12:32:40]ATR READ
[12:32:40]COMPLETE!
[12:32:40]
[12:32:40]CF: 31 52 12 00 95
[12:32:40]ACK!
[12:32:40]ATR READ
[12:32:40]COMPLETE!
[12:32:40]
[12:32:40]CF: 31 52 13 00 96
[12:32:40]ACK!
[12:32:40]ATR READ
[12:32:40]COMPLETE!
[12:32:40]
[12:32:40]CF: 31 52 14 00 97
[12:32:40]ACK!
[12:32:40]ATR READ
[12:32:40]COMPLETE!
[12:32:40]
[12:32:40]CF: 31 52 15 00 98
[12:32:40]ACK!
[12:32:40]ATR READ
[12:32:40]COMPLETE!
[12:32:40]
[12:32:40]CF: 31 52 16 00 99
[12:32:40]ACK!
[12:32:40]ATR READ
[12:32:40]COMPLETE!
[12:32:41]
[12:32:41]CF: 31 52 17 00 9a
[12:32:41]FujiNet CONFIG boot
[12:32:41]disk sio_process()
[12:32:41]ACK!
[12:32:41]ATR READ
[12:32:41]->SIO write 128 bytes
[12:32:41]COMPLETE!
[12:32:41]
[12:32:41]CF: 31 52 18 00 9b
[12:32:41]ACK!
[12:32:41]ATR READ
[12:32:41]COMPLETE!
[12:32:41]
[12:32:41]CF: 31 52 19 00 9c
[12:32:41]ACK!
[12:32:41]ATR READ
[12:32:41]COMPLETE!
[12:32:41]
[12:32:41]CF: 31 52 1a 00 9d
[12:32:41]ACK!
[12:32:41]ATR READ
[12:32:41]COMPLETE!
[12:32:41]
[12:32:41]CF: 31 52 1b 00 9e
[12:32:41]ACK!
[12:32:41]ATR READ
[12:32:41]COMPLETE!
[12:32:41]
[12:32:41]CF: 31 52 1c 00 9f
[12:32:41]ACK!
[12:32:41]ATR READ
[12:32:41]COMPLETE!
[12:32:41]
[12:32:41]CF: 31 52 1d 00 a0
[12:32:41]ACK!
[12:32:41]ATR READ
[12:32:41]COMPLETE!
[12:32:41]
[12:32:41]CF: 31 52 1e 00 a1
[12:32:41]ACK!
[12:32:41]ATR READ
[12:32:41]COMPLETE!
[12:32:41]
[12:32:41]CF: 31 52 1f 00 a2
[12:32:41]ACK!
[12:32:41]ATR READ
[12:32:41]COMPLETE!
[12:32:41]
[12:32:41]CF: 31 52 20 00 a3
[12:32:41]ACK!
[12:32:41]ATR READ
[12:32:41]COMPLETE!
[12:32:41]
[12:32:41]CF: 31 52 21 00 a4
[12:32:41]ACK!
[12:32:41]ATR READ
[12:32:41]COMPLETE!
[12:32:41]
[12:32:41]CF: 31 52 22 00 a5
[12:32:41]ACK!
[12:32:41]ATR READ
[12:32:41]COMPLETE!
[12:32:41]
[12:32:41]CF: 31 52 23 00 a6
[12:32:42]ACK!
[12:32:42]ATR READ
[12:32:42]->SIO write 128 bytes
[12:32:42]COMPLETE!
[12:32:42]
[12:32:42]CF: 31 52 24 00 a7
[12:32:42]FujiNet CONFIG boot
[12:32:42]disk sio_process()
[12:32:42]ACK!
[12:32:42]ATR READ
[12:32:42]COMPLETE!
[12:32:42]
[12:32:42]CF: 31 52 25 00 a8
[12:32:42]ACK!
[12:32:42]ATR READ
[12:32:42]COMPLETE!
[12:32:42]
[12:32:42]CF: 31 52 26 00 a9
[12:32:42]ACK!
[12:32:42]ATR READ
[12:32:42]COMPLETE!
[12:32:42]
[12:32:42]CF: 31 52 27 00 aa
[12:32:42]ACK!
[12:32:42]ATR READ
[12:32:42]COMPLETE!
[12:32:42]
[12:32:42]CF: 31 52 28 00 ab
[12:32:42]ACK!
[12:32:42]ATR READ
[12:32:42]COMPLETE!
[12:32:42]
[12:32:42]CF: 31 52 29 00 ac
[12:32:42]ACK!
[12:32:42]ATR READ
[12:32:42]COMPLETE!
[12:32:42]
[12:32:42]CF: 31 52 2a 00 ad
[12:32:42]ACK!
[12:32:42]ATR READ
[12:32:42]COMPLETE!
[12:32:42]
[12:32:42]CF: 31 52 2b 00 ae
[12:32:42]ACK!
[12:32:42]ATR READ
[12:32:42]COMPLETE!
[12:32:42]
[12:32:42]CF: 31 52 2c 00 af
[12:32:42]ACK!
[12:32:42]ATR READ
[12:32:42]COMPLETE!
[12:32:42]
[12:32:42]CF: 31 52 2d 00 b0
[12:32:42]ACK!
[12:32:42]ATR READ
[12:32:42]COMPLETE!
[12:32:42]
[12:32:42]CF: 31 52 2e 00 b1
[12:32:42]ACK!
[12:32:42]ATR READ
[12:32:42]COMPLETE!
[12:32:42]
[12:32:42]CF: 31 52 2f 00 b2
[12:32:42]ACK!
[12:32:42]ATR READ
[12:32:42]COMPLETE!
[12:32:43]
[12:32:43]CF: 31 52 30 00 b3
[12:32:43]FujiNet CONFIG boot
[12:32:43]disk sio_process()
[12:32:43]ACK!
[12:32:43]ATR READ
[12:32:43]->SIO write 128 bytes
[12:32:43]COMPLETE!
[12:32:43]
[12:32:43]CF: 31 52 31 00 b4
[12:32:43]ACK!
[12:32:43]ATR READ
[12:32:43]COMPLETE!
[12:32:43]
[12:32:43]CF: 31 52 32 00 b5
[12:32:43]ACK!
[12:32:43]ATR READ
[12:32:43]COMPLETE!
[12:32:43]
[12:32:43]CF: 31 52 33 00 b6
[12:32:43]ACK!
[12:32:43]ATR READ
[12:32:43]COMPLETE!
[12:32:43]
[12:32:43]CF: 31 52 34 00 b7
[12:32:43]ACK!
[12:32:43]ATR READ
[12:32:43]COMPLETE!
[12:32:43]
[12:32:43]CF: 31 52 35 00 b8
[12:32:43]ACK!
[12:32:43]ATR READ
[12:32:43]COMPLETE!
[12:32:43]
[12:32:43]CF: 31 52 36 00 b9
[12:32:43]ACK!
[12:32:43]ATR READ
[12:32:43]COMPLETE!
[12:32:43]
[12:32:43]CF: 31 52 37 00 ba
[12:32:43]ACK!
[12:32:43]ATR READ
[12:32:43]COMPLETE!
[12:32:43]
[12:32:43]CF: 31 52 38 00 bb
[12:32:43]ACK!
[12:32:43]ATR READ
[12:32:43]COMPLETE!
[12:32:43]
[12:32:43]CF: 31 52 39 00 bc
[12:32:43]ACK!
[12:32:43]ATR READ
[12:32:43]COMPLETE!
[12:32:43]
[12:32:43]CF: 31 52 3a 00 bd
[12:32:43]ACK!
[12:32:43]ATR READ
[12:32:43]COMPLETE!
[12:32:43]
[12:32:43]CF: 31 52 3b 00 be
[12:32:43]ACK!
[12:32:43]ATR READ
[12:32:43]COMPLETE!
[12:32:43]
[12:32:43]CF: 31 52 3c 00 bf
[12:32:43]ACK!
[12:32:43]ATR READ
[12:32:43]COMPLETE!
[12:32:44]
[12:32:44]CF: 31 52 3d 00 c0
[12:32:44]FujiNet CONFIG boot
[12:32:44]disk sio_process()
[12:32:44]ACK!
[12:32:44]ATR READ
[12:32:44]->SIO write 128 bytes
[12:32:44]COMPLETE!
[12:32:44]
[12:32:44]CF: 31 52 3e 00 c1
[12:32:44]ACK!
[12:32:44]ATR READ
[12:32:44]COMPLETE!
[12:32:44]
[12:32:44]CF: 31 52 3f 00 c2
[12:32:44]ACK!
[12:32:44]ATR READ
[12:32:44]COMPLETE!
[12:32:44]
[12:32:44]CF: 31 52 40 00 c3
[12:32:44]ACK!
[12:32:44]ATR READ
[12:32:44]COMPLETE!
[12:32:44]
[12:32:44]CF: 31 52 41 00 c4
[12:32:44]ACK!
[12:32:44]ATR READ
[12:32:44]COMPLETE!
[12:32:44]
[12:32:44]CF: 31 52 42 00 c5
[12:32:44]ACK!
[12:32:44]ATR READ
[12:32:44]COMPLETE!
[12:32:44]
[12:32:44]CF: 31 52 43 00 c6
[12:32:44]ACK!
[12:32:44]ATR READ
[12:32:44]COMPLETE!
[12:32:44]
[12:32:44]CF: 31 52 44 00 c7
[12:32:44]ACK!
[12:32:44]ATR READ
[12:32:44]COMPLETE!
[12:32:44]
[12:32:44]CF: 31 52 45 00 c8
[12:32:44]ACK!
[12:32:44]ATR READ
[12:32:44]COMPLETE!
[12:32:44]
[12:32:44]CF: 31 52 46 00 c9
[12:32:44]ACK!
[12:32:44]ATR READ
[12:32:44]COMPLETE!
[12:32:44]
[12:32:44]CF: 31 52 47 00 ca
[12:32:44]ACK!
[12:32:44]ATR READ
[12:32:44]COMPLETE!
[12:32:44]
[12:32:44]CF: 31 52 48 00 cb
[12:32:44]ACK!
[12:32:44]ATR READ
[12:32:44]COMPLETE!
[12:32:44]
[12:32:44]CF: 31 52 49 00 cc
[12:32:44]ACK!
[12:32:44]ATR READ
[12:32:44]COMPLETE!
[12:32:45]
[12:32:45]CF: 31 52 4a 00 cd
[12:32:45]FujiNet CONFIG boot
[12:32:45]disk sio_process()
[12:32:45]ACK!
[12:32:45]ATR READ
[12:32:45]->SIO write 128 bytes
[12:32:45]COMPLETE!
[12:32:45]
[12:32:45]CF: 31 52 4b 00 ce
[12:32:45]ACK!
[12:32:45]ATR READ
[12:32:45]COMPLETE!
[12:32:45]
[12:32:45]CF: 31 52 4c 00 cf
[12:32:45]ACK!
[12:32:45]ATR READ
[12:32:45]COMPLETE!
[12:32:45]
[12:32:45]CF: 31 52 4d 00 d0
[12:32:45]ACK!
[12:32:45]ATR READ
[12:32:45]COMPLETE!
[12:32:45]
[12:32:45]CF: 31 52 4e 00 d1
[12:32:45]ACK!
[12:32:45]ATR READ
[12:32:45]COMPLETE!
[12:32:45]
[12:32:45]CF: 31 52 4f 00 d2
[12:32:45]ACK!
[12:32:45]ATR READ
[12:32:45]COMPLETE!
[12:32:45]
[12:32:45]CF: 31 52 50 00 d3
[12:32:45]ACK!
[12:32:45]ATR READ
[12:32:45]COMPLETE!
[12:32:45]
[12:32:45]CF: 31 52 51 00 d4
[12:32:45]ACK!
[12:32:45]ATR READ
[12:32:45]COMPLETE!
[12:32:45]
[12:32:45]CF: 31 52 52 00 d5
[12:32:45]ACK!
[12:32:45]ATR READ
[12:32:45]COMPLETE!
[12:32:45]
[12:32:45]CF: 31 52 53 00 d6
[12:32:45]ACK!
[12:32:45]ATR READ
[12:32:45]COMPLETE!
[12:32:45]
[12:32:45]CF: 31 52 54 00 d7
[12:32:45]ACK!
[12:32:45]ATR READ
[12:32:45]COMPLETE!
[12:32:45]
[12:32:45]CF: 31 52 55 00 d8
[12:32:45]ACK!
[12:32:45]ATR READ
[12:32:45]COMPLETE!
[12:32:45]
[12:32:46]CF: 31 52 56 00 d9
[12:32:46]FujiNet CONFIG boot
[12:32:46]disk sio_process()
[12:32:46]ACK!
[12:32:46]ATR READ
[12:32:46]->SIO write 128 bytes
[12:32:46]COMPLETE!
[12:32:46]
[12:32:46]CF: 31 52 57 00 da
[12:32:46]ACK!
[12:32:46]ATR READ
[12:32:46]COMPLETE!
[12:32:46]
[12:32:46]CF: 31 52 58 00 db
[12:32:46]ACK!
[12:32:46]ATR READ
[12:32:46]COMPLETE!
[12:32:46]
[12:32:46]CF: 31 52 59 00 dc
[12:32:46]ACK!
[12:32:46]ATR READ
[12:32:46]COMPLETE!
[12:32:46]
[12:32:46]CF: 31 52 5a 00 dd
[12:32:46]ACK!
[12:32:46]ATR READ
[12:32:46]COMPLETE!
[12:32:46]
[12:32:46]CF: 31 52 5b 00 de
[12:32:46]ACK!
[12:32:46]ATR READ
[12:32:46]COMPLETE!
[12:32:46]
[12:32:46]CF: 31 52 5c 00 df
[12:32:46]ACK!
[12:32:46]ATR READ
[12:32:46]COMPLETE!
[12:32:46]
[12:32:46]CF: 31 52 5d 00 e0
[12:32:46]ACK!
[12:32:46]ATR READ
[12:32:46]COMPLETE!
[12:32:46]
[12:32:46]CF: 31 52 5e 00 e1
[12:32:46]ACK!
[12:32:46]ATR READ
[12:32:46]COMPLETE!
[12:32:46]
[12:32:46]CF: 31 52 5f 00 e2
[12:32:46]ACK!
[12:32:46]ATR READ
[12:32:46]COMPLETE!
[12:32:46]
[12:32:46]CF: 31 52 60 00 e3
[12:32:46]ACK!
[12:32:46]ATR READ
[12:32:46]COMPLETE!
[12:32:46]
[12:32:46]CF: 31 52 61 00 e4
[12:32:46]ACK!
[12:32:46]ATR READ
[12:32:46]COMPLETE!
[12:32:46]
[12:32:46]CF: 31 52 62 00 e5
[12:32:46]ACK!
[12:32:46]ATR READ
[12:32:46]COMPLETE!
[12:32:47]
[12:32:47]CF: 31 52 63 00 e6
[12:32:47]FujiNet CONFIG boot
[12:32:47]disk sio_process()
[12:32:47]ACK!
[12:32:47]ATR READ
[12:32:47]->SIO write 128 bytes
[12:32:47]COMPLETE!
[12:32:47]
[12:32:47]CF: 31 52 64 00 e7
[12:32:47]ACK!
[12:32:47]ATR READ
[12:32:47]COMPLETE!
[12:32:47]
[12:32:47]CF: 31 52 65 00 e8
[12:32:47]ACK!
[12:32:47]ATR READ
[12:32:47]COMPLETE!
[12:32:47]
[12:32:47]CF: 31 52 66 00 e9
[12:32:47]ACK!
[12:32:47]ATR READ
[12:32:47]COMPLETE!
[12:32:47]
[12:32:47]CF: 31 52 67 00 ea
[12:32:47]ACK!
[12:32:47]ATR READ
[12:32:47]COMPLETE!
[12:32:47]
[12:32:47]CF: 31 52 68 00 eb
[12:32:47]ACK!
[12:32:47]ATR READ
[12:32:47]COMPLETE!
[12:32:47]
[12:32:47]CF: 31 52 69 00 ec
[12:32:47]ACK!
[12:32:47]ATR READ
[12:32:47]COMPLETE!
[12:32:47]
[12:32:47]CF: 31 52 6a 00 ed
[12:32:47]ACK!
[12:32:47]ATR READ
[12:32:47]COMPLETE!
[12:32:47]
[12:32:47]CF: 31 52 6b 00 ee
[12:32:47]ACK!
[12:32:47]ATR READ
[12:32:47]COMPLETE!
[12:32:47]
[12:32:47]CF: 31 52 6c 00 ef
[12:32:47]ACK!
[12:32:47]ATR READ
[12:32:47]COMPLETE!
[12:32:47]
[12:32:47]CF: 31 52 6d 00 f0
[12:32:47]ACK!
[12:32:47]ATR READ
[12:32:47]COMPLETE!
[12:32:47]
[12:32:47]CF: 31 52 6e 00 f1
[12:32:47]ACK!
[12:32:47]ATR READ
[12:32:47]COMPLETE!
[12:32:47]
[12:32:47]CF: 31 52 6f 00 f2
[12:32:47]ACK!
[12:32:47]ATR READ
[12:32:47]COMPLETE!
[12:32:48]
[12:32:48]CF: 31 52 70 00 f3
[12:32:48]FujiNet CONFIG boot
[12:32:48]disk sio_process()
[12:32:48]ACK!
[12:32:48]ATR READ
[12:32:48]->SIO write 128 bytes
[12:32:48]COMPLETE!
[12:32:48]
[12:32:48]CF: 31 52 71 00 f4
[12:32:48]ACK!
[12:32:48]ATR READ
[12:32:48]COMPLETE!
[12:32:48]
[12:32:48]CF: 31 52 72 00 f5
[12:32:48]ACK!
[12:32:48]ATR READ
[12:32:48]COMPLETE!
[12:32:48]
[12:32:48]CF: 31 52 73 00 f6
[12:32:48]ACK!
[12:32:48]ATR READ
[12:32:48]COMPLETE!
[12:32:48]
[12:32:48]CF: 31 52 74 00 f7
[12:32:48]ACK!
[12:32:48]ATR READ
[12:32:48]COMPLETE!
[12:32:48]
[12:32:48]CF: 31 52 75 00 f8
[12:32:48]ACK!
[12:32:48]ATR READ
[12:32:48]COMPLETE!
[12:32:48]
[12:32:48]CF: 31 52 76 00 f9
[12:32:48]ACK!
[12:32:48]ATR READ
[12:32:48]COMPLETE!
[12:32:48]
[12:32:48]CF: 31 52 77 00 fa
[12:32:48]ACK!
[12:32:48]ATR READ
[12:32:48]COMPLETE!
[12:32:48]
[12:32:48]CF: 31 52 78 00 fb
[12:32:48]ACK!
[12:32:48]ATR READ
[12:32:48]COMPLETE!
[12:32:48]
[12:32:48]CF: 31 52 79 00 fc
[12:32:48]ACK!
[12:32:48]ATR READ
[12:32:48]COMPLETE!
[12:32:48]
[12:32:48]CF: 31 52 7a 00 fd
[12:32:48]ACK!
[12:32:48]ATR READ
[12:32:48]COMPLETE!
[12:32:48]
[12:32:48]CF: 31 52 7b 00 fe
[12:32:48]ACK!
[12:32:48]ATR READ
[12:32:48]COMPLETE!
[12:32:48]
[12:32:48]CF: 31 52 7c 00 ff
[12:32:49]disk sio_process()
[12:32:49]ACK!
[12:32:49]ATR READ
[12:32:49]->SIO write 128 bytes
[12:32:49]COMPLETE!
[12:32:49]
[12:32:49]CF: 31 52 7d 00 01
[12:32:49]FujiNet CONFIG boot
[12:32:49]ACK!
[12:32:49]ATR READ
[12:32:49]COMPLETE!
[12:32:49]
[12:32:49]CF: 31 52 7e 00 02
[12:32:49]ACK!
[12:32:49]ATR READ
[12:32:49]COMPLETE!
[12:32:49]
[12:32:49]CF: 31 52 7f 00 03
[12:32:49]ACK!
[12:32:49]ATR READ
[12:32:49]COMPLETE!
[12:32:49]
[12:32:49]CF: 31 52 80 00 04
[12:32:49]ACK!
[12:32:49]ATR READ
[12:32:49]COMPLETE!
[12:32:49]
[12:32:49]CF: 31 52 81 00 05
[12:32:49]ACK!
[12:32:49]ATR READ
[12:32:49]COMPLETE!
[12:32:49]
[12:32:49]CF: 31 52 82 00 06
[12:32:49]ACK!
[12:32:49]ATR READ
[12:32:49]COMPLETE!
[12:32:49]
[12:32:49]CF: 31 52 83 00 07
[12:32:49]ACK!
[12:32:49]ATR READ
[12:32:49]COMPLETE!
[12:32:49]
[12:32:49]CF: 31 52 84 00 08
[12:32:49]ACK!
[12:32:49]ATR READ
[12:32:49]COMPLETE!
[12:32:49]
[12:32:49]CF: 31 52 85 00 09
[12:32:49]ACK!
[12:32:49]ATR READ
[12:32:49]COMPLETE!
[12:32:49]
[12:32:49]CF: 31 52 86 00 0a
[12:32:49]ACK!
[12:32:49]ATR READ
[12:32:49]COMPLETE!
[12:32:49]
[12:32:49]CF: 31 52 87 00 0b
[12:32:49]ACK!
[12:32:49]ATR READ
[12:32:49]COMPLETE!
[12:32:49]
[12:32:49]CF: 31 52 88 00 0c
[12:32:49]ACK!
[12:32:49]ATR READ
[12:32:49]COMPLETE!
[12:32:50]
[12:32:50]CF: 31 52 89 00 0d
[12:32:50]FujiNet CONFIG boot
[12:32:50]disk sio_process()
[12:32:50]ACK!
[12:32:50]ATR READ
[12:32:50]->SIO write 128 bytes
[12:32:50]COMPLETE!
[12:32:50]
[12:32:50]CF: 31 52 8a 00 0e
[12:32:50]ACK!
[12:32:50]ATR READ
[12:32:50]COMPLETE!
[12:32:50]
[12:32:50]CF: 31 52 8b 00 0f
[12:32:50]ACK!
[12:32:50]ATR READ
[12:32:50]COMPLETE!
[12:32:50]
[12:32:50]CF: 31 52 8c 00 10
[12:32:50]ACK!
[12:32:50]ATR READ
[12:32:50]COMPLETE!
[12:32:50]
[12:32:50]CF: 31 52 8d 00 11
[12:32:50]ACK!
[12:32:50]ATR READ
[12:32:50]COMPLETE!
[12:32:50]
[12:32:50]CF: 31 52 8e 00 12
[12:32:50]ACK!
[12:32:50]ATR READ
[12:32:50]COMPLETE!
[12:32:50]
[12:32:50]CF: 31 52 8f 00 13
[12:32:50]ACK!
[12:32:50]ATR READ
[12:32:50]COMPLETE!
[12:32:50]
[12:32:50]CF: 31 52 90 00 14
[12:32:50]ACK!
[12:32:50]ATR READ
[12:32:50]COMPLETE!
[12:32:50]
[12:32:50]CF: 31 52 91 00 15
[12:32:50]ACK!
[12:32:50]ATR READ
[12:32:50]COMPLETE!
[12:32:50]
[12:32:50]CF: 31 52 92 00 16
[12:32:50]ACK!
[12:32:50]ATR READ
[12:32:50]COMPLETE!
[12:32:50]
[12:32:50]CF: 31 52 93 00 17
[12:32:50]ACK!
[12:32:50]ATR READ
[12:32:50]COMPLETE!
[12:32:50]
[12:32:50]CF: 31 52 94 00 18
[12:32:50]ACK!
[12:32:50]ATR READ
[12:32:50]COMPLETE!
[12:32:50]
[12:32:50]CF: 31 52 95 00 19
[12:32:50]ACK!
[12:32:50]ATR READ
[12:32:50]COMPLETE!
[12:32:51]
[12:32:51]CF: 31 52 96 00 1a
[12:32:51]FujiNet CONFIG boot
[12:32:51]disk sio_process()
[12:32:51]ACK!
[12:32:51]ATR READ
[12:32:51]->SIO write 128 bytes
[12:32:51]COMPLETE!
[12:32:51]
[12:32:51]CF: 31 52 97 00 1b
[12:32:51]ACK!
[12:32:51]ATR READ
[12:32:51]COMPLETE!
[12:32:51]
[12:32:51]CF: 31 52 98 00 1c
[12:32:51]ACK!
[12:32:51]ATR READ
[12:32:51]COMPLETE!
[12:32:51]
[12:32:51]CF: 31 52 99 00 1d
[12:32:51]ACK!
[12:32:51]ATR READ
[12:32:51]COMPLETE!
[12:32:51]
[12:32:51]CF: 70 fe 00 00 6f
[12:32:51]sioFuji::sio_process() called
[12:32:51]ACK!
[12:32:51]Fuji cmd: GET SSID
[12:32:51]->SIO write 96 bytes
[12:32:51]COMPLETE!
[12:32:51]
[12:32:51]ACK!
[12:32:51]COMPLETE!
[12:32:51]
[12:32:51]CF: 70 fb 00 00 6c
[12:32:51]ACK!
[12:32:51]Fuji cmd: SET SSID
[12:32:51]<-SIO read 96 bytes
[12:32:51]ACK!
[12:32:51]Connecting to net: e46f1399d57d password: P5CEXTB5M2SDPIKE
[12:32:51]WiFi connect attempt to SSID "e46f1399d57d"
[12:32:51]esp_wifi_connect returned 0
[12:32:51]COMPLETE!
[12:32:51]
[12:32:51]CF: 70 fa 00 00 6b
[12:32:51]ACK!
[12:32:51]Fuji cmd: GET WIFI STATUS
[12:32:51]->SIO write 1 bytes
[12:32:51]COMPLETE!
[12:32:51]
[12:32:51]CF: 70 fb 01 00 6d
[12:32:51]ACK!
[12:32:51]ACK!
[12:32:51]fnConfig::save
[12:32:51]fnConfig::save not dirty, not saving
[12:32:51]COMPLETE!
[12:32:53]
[12:32:53]CF: 70 f4 00 00 65
[12:32:53]sioFuji::sio_process() called
[12:32:53]ACK!
[12:32:53]Fuji cmd: READ HOST SLOTS
[12:32:53]->SIO write 256 bytes
[12:32:53]COMPLETE!
[12:32:54]
[12:32:54]CF: 70 f2 00 00 63
[12:32:54]sioFuji::sio_process() called
[12:32:54]ACK!
[12:32:54]Fuji cmd: READ DEVICE SLOTS
[12:32:54]->SIO write 304 bytes
[12:32:54]COMPLETE!
[12:32:58]
[12:32:58]CF: 70 e9 00 00 5a
[12:32:58]sioFuji::sio_process() called
[12:32:58]ACK!
[12:32:58]Fuji cmd: UNMOUNT IMAGE 0x00
[12:32:58]disk UNMOUNT
[12:32:58]ERROR!
[12:32:58]
[12:32:58]ACK!
[12:32:58]ERROR!
[12:32:58]
[12:32:58]CF: 70 f1 00 00 62
[12:32:58]ACK!
[12:32:58]Fuji cmd: WRITE DEVICE SLOTS
[12:32:58]<-SIO read 304 bytes
[12:32:58]ACK!
[12:32:58]fnConfig::save
[12:32:58]fnConfig::save wrote 446 bytes
[12:32:58]Attemptiong config copy to SD
[12:32:58]copy_file "/fnconfig.ini" -> "/fnconfig.ini"
[12:32:58]copy_file copied 446 bytes
[12:32:58]COMPLETE!
[12:33:01]
[12:33:01]CF: 70 f9 01 00 6b
[12:33:01]sioFuji::sio_process() called
[12:33:01]ACK!
[12:33:01]Fuji cmd: MOUNT HOST
[12:33:01]::mount {1} "fujinet.online"
[12:33:01]::mount_local Attempting mount of "fujinet.online"
[12:33:01]::mount_tnfs {1:0} "fujinet.online"
[12:33:01]Calling TNFS::begin
[12:33:01]Resolving hostname "fujinet.online"
[12:33:01]Resoled to address 157.245.127.133
[12:33:01]TNFS mount fujinet.online[157.245.127.133]:16384
[12:33:01]TNFS mount successful. session: 0x8454, version: 0x0102, min_retry: 1000ms
[12:33:01]vfs_tnfs_register "/tnfs0x3ffeb534" @ 0x3ffeb534 = 0 "ESP_OK"
[12:33:01]COMPLETE!
[12:33:02]
[12:33:02]CF: 70 f7 01 00 69
[12:33:02]sioFuji::sio_process() called
[12:33:02]ACK!
[12:33:02]Fuji cmd: OPEN DIRECTORY
[12:33:02]<-SIO read 256 bytes
[12:33:02]ACK!
[12:33:02]Opening directory: "/", pattern: ""
[12:33:02]::dir_open {1:2} "/", pattern ""
[12:33:02]::dir_open actual path = "/"
[12:33:02]TNFS open directory: sortopts=0x00 diropts=0x00 maxresults=0x0000 pattern="" path="/"
[12:33:02]Directory opened, handle ID: 0, entries: 11
[12:33:02]COMPLETE!
[12:33:02]
[12:33:02]CF: 70 e4 00 00 55
[12:33:02]ACK!
[12:33:02]Fuji cmd: SET DIRECTORY POSITION
[12:33:02]::dir_seek {1:2} 0
[12:33:02]COMPLETE!
[12:33:02]
[12:33:02]CF: 70 f6 24 00 8b
[12:33:02]ACK!
[12:33:02]Fuji cmd: READ DIRECTORY ENTRY (max=36)
[12:33:02]::dir_nextfile {1:2}
[12:33:02]tnfs_readdirx resp_count=11, dirpos=0, status=1
[12:33:02]tnfs_readdirx cached 11 entries
[12:33:02]    _readdirx_fill_response: dir: Yes, size: 4096, mtime: 2020-07-29 00:29:48, ctime: 2020-11-14 16:14:05 "DOS"
[12:33:02]::read_direntry "DOS"
[12:33:02]->SIO write 36 bytes
[12:33:02]COMPLETE!
[12:33:02]
[12:33:02]ACK!
[12:33:02]tnfs_readdirx responding from cached entry
[12:33:02]    _readdirx_fill_response: dir: Yes, size: 4096, mtime: 2020-11-20 01:42:41, ctime: 2020-11-20 01:42:41 "games"
[12:33:02]::read_direntry "games"
[12:33:02]COMPLETE!
[12:33:02]
[12:33:02]ACK!
[12:33:02]    _readdirx_fill_response: dir: Yes, size: 4096, mtime: 2020-09-01 01:05:56, ctime: 2020-11-14 16:14:05 "Holmes_CD1"
[12:33:02]::read_direntry "Holmes_CD1"
[12:33:02]COMPLETE!
[12:33:02]
[12:33:02]ACK!
[12:33:02]    _readdirx_fill_response: dir: Yes, size: 4096, mtime: 2020-10-25 00:50:14, ctime: 2020-11-14 16:14:05 "netgames"
[12:33:02]::read_direntry "netgames"
[12:33:02]COMPLETE!
[12:33:02]
[12:33:02]ACK!
[12:33:02]    _readdirx_fill_response: dir: Yes, size: 4096, mtime: 2020-11-15 16:44:10, ctime: 2020-11-15 16:44:10 "networking"
[12:33:02]::read_direntry "networking"
[12:33:02]COMPLETE!
[12:33:02]
[12:33:02]ACK!
[12:33:02]    _readdirx_fill_response: dir: Yes, size: 4096, mtime: 2020-11-25 00:20:51, ctime: 2020-11-25 00:20:51 "printing"
[12:33:02]::read_direntry "printing"
[12:33:02]COMPLETE!
[12:33:02]
[12:33:02]ACK!
[12:33:02]    _readdirx_fill_response: dir: Yes, size: 4096, mtime: 2020-10-25 00:48:54, ctime: 2020-11-14 16:14:05 "tools"
[12:33:02]::read_direntry "tools"
[12:33:02]COMPLETE!
[12:33:02]
[12:33:02]ACK!
[12:33:02]    _readdirx_fill_response: dir: no, size: 92176, mtime: 2020-10-21 21:12:45, ctime: 2020-11-14 16:14:05 "config.atr"
[12:33:02]::read_direntry "config.atr"
[12:33:02]COMPLETE!
[12:33:02]
[12:33:02]ACK!
[12:33:02]    _readdirx_fill_response: dir: no, size: 92176, mtime: 2020-11-14 02:43:44, ctime: 2020-11-14 16:14:05 "fnc-tools.atr"
[12:33:02]::read_direntry "fnc-tools.atr"
[12:33:02]COMPLETE!
[12:33:02]
[12:33:02]ACK!
[12:33:02]    _readdirx_fill_response: dir: no, size: 42535, mtime: 2020-07-29 00:31:28, ctime: 2020-11-14 16:14:05 "index.php"
[12:33:02]::read_direntry "index.php"
[12:33:02]COMPLETE!
[12:33:02]
[12:33:02]ACK!
[12:33:02]    _readdirx_fill_response: dir: no, size: 133136, mtime: 2020-09-25 22:30:00, ctime: 2020-11-14 16:14:05 "SAM-Test.atr"
[12:33:02]::read_direntry "SAM-Test.atr"
[12:33:02]COMPLETE!
[12:33:02]
[12:33:02]ACK!
[12:33:02]tnfs_readdirx returning EOF based on cached value
[12:33:02]Reached end of of directory
[12:33:02]COMPLETE!
[12:33:02]
[12:33:02]CF: 70 f5 01 00 67
[12:33:02]ACK!
[12:33:02]Fuji cmd: CLOSE DIRECTORY
[12:33:02]COMPLETE!
[12:33:05]
[12:33:05]CF: 70 f7 01 00 69
[12:33:05]sioFuji::sio_process() called
[12:33:05]ACK!
[12:33:05]Fuji cmd: OPEN DIRECTORY
[12:33:05]<-SIO read 256 bytes
[12:33:05]ACK!
[12:33:05]Opening directory: "/", pattern: ""
[12:33:05]::dir_open {1:2} "/", pattern ""
[12:33:05]::dir_open actual path = "/"
[12:33:05]TNFS open directory: sortopts=0x00 diropts=0x00 maxresults=0x0000 pattern="" path="/"
[12:33:05]Directory opened, handle ID: 0, entries: 11
[12:33:05]COMPLETE!
[12:33:05]
[12:33:05]CF: 70 e4 04 00 59
[12:33:05]ACK!
[12:33:05]Fuji cmd: SET DIRECTORY POSITION
[12:33:05]::dir_seek {1:2} 4
[12:33:05]COMPLETE!
[12:33:05]
[12:33:05]CF: 70 f6 80 00 e7
[12:33:05]ACK!
[12:33:05]Fuji cmd: READ DIRECTORY ENTRY (max=128)
[12:33:05]::dir_nextfile {1:2}
[12:33:05]tnfs_readdirx resp_count=7, dirpos=4, status=1
[12:33:05]tnfs_readdirx cached 7 entries
[12:33:05]    _readdirx_fill_response: dir: Yes, size: 4096, mtime: 2020-11-15 16:44:10, ctime: 2020-11-15 16:44:10 "networking"
[12:33:05]::read_direntry "networking"
[12:33:05]->SIO write 128 bytes
[12:33:05]COMPLETE!
[12:33:05]
[12:33:05]CF: 70 f5 01 00 67
[12:33:05]ACK!
[12:33:05]Fuji cmd: CLOSE DIRECTORY
[12:33:05]COMPLETE!
[12:33:05]
[12:33:05]ACK!
[12:33:05]ACK!
[12:33:05]Opening directory: "/networking", pattern: ""
[12:33:05]::dir_open {1:2} "/networking", pattern ""
[12:33:05]::dir_open actual path = "/networking"
[12:33:05]TNFS open directory: sortopts=0x00 diropts=0x00 maxresults=0x0000 pattern="" path="/networking"
[12:33:05]Directory opened, handle ID: 0, entries: 9
[12:33:05]COMPLETE!
[12:33:05]
[12:33:05]CF: 70 e4 00 00 55
[12:33:05]ACK!
[12:33:05]::dir_seek {1:2} 0
[12:33:05]COMPLETE!
[12:33:05]
[12:33:05]CF: 70 f6 24 00 8b
[12:33:05]ACK!
[12:33:05]Fuji cmd: READ DIRECTORY ENTRY (max=36)
[12:33:05]tnfs_readdirx resp_count=9, dirpos=0, status=1
[12:33:05]tnfs_readdirx cached 9 entries
[12:33:05]    _readdirx_fill_response: dir: no, size: 92176, mtime: 2020-07-29 00:07:19, ctime: 2020-11-14 16:13:34 "850-express-3.00p-B.atr"
[12:33:05]::read_direntry "850-express-3.00p-B.atr"
[12:33:05]->SIO write 36 bytes
[12:33:05]COMPLETE!
[12:33:05]
[12:33:05]ACK!
[12:33:05]tnfs_readdirx responding from cached entry
[12:33:05]    _readdirx_fill_response: dir: no, size: 23324, mtime: 2020-11-14 16:10:15, ctime: 2020-11-14 16:13:34 "covid.xex"
[12:33:05]::read_direntry "covid.xex"
[12:33:05]COMPLETE!
[12:33:05]
[12:33:05]ACK!
[12:33:06]    _readdirx_fill_response: dir: no, size: 92176, mtime: 2020-11-05 19:53:33, ctime: 2020-11-14 16:14:15 "election-test.atr"
[12:33:06]::read_direntry "election-test.atr"
[12:33:06]->SIO write 36 bytes
[12:33:06]COMPLETE!
[12:33:06]
[12:33:06]CF: 70 f6 24 00 8b
[12:33:06]sioFuji::sio_process() called
[12:33:06]ACK!
[12:33:06]Fuji cmd: READ DIRECTORY ENTRY (max=36)
[12:33:06]::dir_nextfile {1:2}
[12:33:06]tnfs_readdirx responding from cached entry
[12:33:06]    _readdirx_fill_response: dir: no, size: 92176, mtime: 2020-11-07 17:30:41, ctime: 2020-11-14 16:14:15 "election.atr"
[12:33:06]::read_direntry "election.atr"
[12:33:06]COMPLETE!
[12:33:06]
[12:33:06]ACK!
[12:33:06]    _readdirx_fill_response: dir: no, size: 736912, mtime: 2020-11-15 16:41:18, ctime: 2020-11-15 16:44:02 "Flickerterm.atr"
[12:33:06]::read_direntry "Flickerterm.atr"
[12:33:06]COMPLETE!
[12:33:06]
[12:33:06]ACK!
[12:33:06]    _readdirx_fill_response: dir: no, size: 133136, mtime: 2020-11-15 16:41:35, ctime: 2020-11-15 16:44:10 "modem-programs.atr"
[12:33:06]::read_direntry "modem-programs.atr"
[12:33:06]COMPLETE!
[12:33:06]
[12:33:06]ACK!
[12:33:06]    _readdirx_fill_response: dir: no, size: 92176, mtime: 2020-10-25 00:52:33, ctime: 2020-11-14 16:13:34 "Platoterm.atr"
[12:33:06]::read_direntry "Platoterm.atr"
[12:33:06]COMPLETE!
[12:33:06]
[12:33:06]ACK!
[12:33:06]    _readdirx_fill_response: dir: no, size: 26939, mtime: 2020-10-25 00:33:07, ctime: 2020-11-14 16:13:34 "weather-old_20201024.xex"
[12:33:06]::read_direntry "weather-old_20201024.xex"
[12:33:06]COMPLETE!
[12:33:06]
[12:33:06]ACK!
[12:33:06]    _readdirx_fill_response: dir: no, size: 92176, mtime: 2020-11-14 16:10:41, ctime: 2020-11-14 16:13:34 "weather.atr"
[12:33:06]::read_direntry "weather.atr"
[12:33:06]COMPLETE!
[12:33:06]
[12:33:06]ACK!
[12:33:06]tnfs_readdirx returning EOF based on cached value
[12:33:06]Reached end of of directory
[12:33:06]COMPLETE!
[12:33:06]
[12:33:06]ACK!
[12:33:06]COMPLETE!
[12:33:06]
[12:33:06]CF: 70 f5 01 00 67
[12:33:06]ACK!
[12:33:06]Fuji cmd: CLOSE DIRECTORY
[12:33:08]Timeout after 2000 milliseconds. Retrying
[12:33:09]COMPLETE!
[12:34:08]
[12:34:08]CF: 70 f7 01 00 69
[12:34:08]sioFuji::sio_process() called
[12:34:08]ACK!
[12:34:08]Fuji cmd: OPEN DIRECTORY
[12:34:08]<-SIO read 256 bytes
[12:34:08]ACK!
[12:34:08]Opening directory: "/networking", pattern: ""
[12:34:08]::dir_open {1:2} "/networking", pattern ""
[12:34:08]::dir_open actual path = "/networking"
[12:34:08]TNFS open directory: sortopts=0x00 diropts=0x00 maxresults=0x0000 pattern="" path="/networking"
[12:34:08]Directory opened, handle ID: 0, entries: 9
[12:34:08]COMPLETE!
[12:34:08]
[12:34:08]CF: 70 e4 08 00 5d
[12:34:08]ACK!
[12:34:08]Fuji cmd: SET DIRECTORY POSITION
[12:34:08]::dir_seek {1:2} 8
[12:34:08]COMPLETE!
[12:34:08]
[12:34:08]CF: 70 f6 80 00 e7
[12:34:08]ACK!
[12:34:08]Fuji cmd: READ DIRECTORY ENTRY (max=128)
[12:34:08]::dir_nextfile {1:2}
[12:34:08]tnfs_readdirx resp_count=1, dirpos=8, status=1
[12:34:08]tnfs_readdirx cached 1 entries
[12:34:08]    _readdirx_fill_response: dir: no, size: 92176, mtime: 2020-11-14 16:10:41, ctime: 2020-11-14 16:13:34 "weather.atr"
[12:34:08]::read_direntry "weather.atr"
[12:34:08]->SIO write 128 bytes
[12:34:08]COMPLETE!
[12:34:08]
[12:34:08]CF: 70 f5 01 00 67
[12:34:08]ACK!
[12:34:08]Fuji cmd: CLOSE DIRECTORY
[12:34:08]COMPLETE!
[12:34:08]
[12:34:08]CF: 70 f2 00 00 63
[12:34:08]ACK!
[12:34:08]Fuji cmd: READ DEVICE SLOTS
[12:34:08]->SIO write 304 bytes
[12:34:08]COMPLETE!
[12:34:10]
[12:34:10]CF: 70 f1 00 00 62
[12:34:10]sioFuji::sio_process() called
[12:34:10]ACK!
[12:34:10]Fuji cmd: WRITE DEVICE SLOTS
[12:34:10]<-SIO read 304 bytes
[12:34:10]ACK!
[12:34:10]fnConfig::save
[12:34:10]fnConfig::save wrote 448 bytes
[12:34:10]Attemptiong config copy to SD
[12:34:10]copy_file "/fnconfig.ini" -> "/fnconfig.ini"
[12:34:10]copy_file copied 448 bytes
[12:34:10]COMPLETE!
[12:34:10]
[12:34:10]CF: 70 e2 00 00 53
[12:34:10]ACK!
[12:34:10]<-SIO read 256 bytes
[12:34:10]ACK!
[12:34:10]Fuji cmd: SET DEVICE SLOT 0x00/00/00 FILENAME: /networking/weather.atr
[12:34:10]fnConfig::save wrote 510 bytes
[12:34:10]copy_file copied 510 bytes
[12:34:10]COMPLETE!
[12:34:10]
[12:34:10]CF: 70 f7 01 00 69
[12:34:10]ACK!
[12:34:10]Fuji cmd: OPEN DIRECTORY
[12:34:11]ACK!
[12:34:11]Opening directory: "/networking", pattern: ""
[12:34:11]::dir_open {1:2} "/networking", pattern ""
[12:34:11]::dir_open actual path = "/networking"
[12:34:11]TNFS open directory: sortopts=0x00 diropts=0x00 maxresults=0x0000 pattern="" path="/networking"
[12:34:11]Directory opened, handle ID: 0, entries: 9
[12:34:11]COMPLETE!
[12:34:11]
[12:34:11]CF: 70 e4 00 00 55
[12:34:11]sioFuji::sio_process() called
[12:34:11]ACK!
[12:34:11]Fuji cmd: SET DIRECTORY POSITION
[12:34:11]::dir_seek {1:2} 0
[12:34:11]COMPLETE!
[12:34:11]
[12:34:11]CF: 70 f6 24 00 8b
[12:34:11]ACK!
[12:34:11]Fuji cmd: READ DIRECTORY ENTRY (max=36)
[12:34:11]::dir_nextfile {1:2}
[12:34:11]tnfs_readdirx resp_count=9, dirpos=0, status=1
[12:34:11]tnfs_readdirx cached 9 entries
[12:34:11]    _readdirx_fill_response: dir: no, size: 92176, mtime: 2020-07-29 00:07:19, ctime: 2020-11-14 16:13:34 "850-express-3.00p-B.atr"
[12:34:11]::read_direntry "850-express-3.00p-B.atr"
[12:34:11]->SIO write 36 bytes
[12:34:11]COMPLETE!
[12:34:11]
[12:34:11]ACK!
[12:34:11]tnfs_readdirx responding from cached entry
[12:34:11]    _readdirx_fill_response: dir: no, size: 23324, mtime: 2020-11-14 16:10:15, ctime: 2020-11-14 16:13:34 "covid.xex"
[12:34:11]::read_direntry "covid.xex"
[12:34:11]COMPLETE!
[12:34:11]
[12:34:11]ACK!
[12:34:11]    _readdirx_fill_response: dir: no, size: 92176, mtime: 2020-11-05 19:53:33, ctime: 2020-11-14 16:14:15 "election-test.atr"
[12:34:11]::read_direntry "election-test.atr"
[12:34:11]COMPLETE!
[12:34:11]
[12:34:11]ACK!
[12:34:11]    _readdirx_fill_response: dir: no, size: 92176, mtime: 2020-11-07 17:30:41, ctime: 2020-11-14 16:14:15 "election.atr"
[12:34:11]::read_direntry "election.atr"
[12:34:11]COMPLETE!
[12:34:11]
[12:34:11]ACK!
[12:34:11]    _readdirx_fill_response: dir: no, size: 736912, mtime: 2020-11-15 16:41:18, ctime: 2020-11-15 16:44:02 "Flickerterm.atr"
[12:34:11]::read_direntry "Flickerterm.atr"
[12:34:11]COMPLETE!
[12:34:11]
[12:34:11]ACK!
[12:34:11]    _readdirx_fill_response: dir: no, size: 133136, mtime: 2020-11-15 16:41:35, ctime: 2020-11-15 16:44:10 "modem-programs.atr"
[12:34:11]::read_direntry "modem-programs.atr"
[12:34:11]COMPLETE!
[12:34:11]
[12:34:11]ACK!
[12:34:11]    _readdirx_fill_response: dir: no, size: 92176, mtime: 2020-10-25 00:52:33, ctime: 2020-11-14 16:13:34 "Platoterm.atr"
[12:34:11]::read_direntry "Platoterm.atr"
[12:34:11]COMPLETE!
[12:34:11]
[12:34:11]ACK!
[12:34:11]    _readdirx_fill_response: dir: no, size: 26939, mtime: 2020-10-25 00:33:07, ctime: 2020-11-14 16:13:34 "weather-old_20201024.xex"
[12:34:11]::read_direntry "weather-old_20201024.xex"
[12:34:11]COMPLETE!
[12:34:11]
[12:34:11]ACK!
[12:34:11]    _readdirx_fill_response: dir: no, size: 92176, mtime: 2020-11-14 16:10:41, ctime: 2020-11-14 16:13:34 "weather.atr"
[12:34:11]::read_direntry "weather.atr"
[12:34:11]COMPLETE!
[12:34:11]
[12:34:11]ACK!
[12:34:11]tnfs_readdirx returning EOF based on cached value
[12:34:11]Reached end of of directory
[12:34:11]COMPLETE!
[12:34:11]
[12:34:11]CF: 70 f5 01 00 67
[12:34:11]ACK!
[12:34:11]Fuji cmd: CLOSE DIRECTORY
[12:34:11]COMPLETE!
[12:34:13]
[12:34:13]CF: 70 f4 00 00 65
[12:34:13]sioFuji::sio_process() called
[12:34:13]ACK!
[12:34:13]Fuji cmd: READ HOST SLOTS
[12:34:13]->SIO write 256 bytes
[12:34:13]COMPLETE!
[12:34:13]
[12:34:13]CF: 70 f2 00 00 63
[12:34:13]ACK!
[12:34:13]Fuji cmd: READ DEVICE SLOTS
[12:34:13]->SIO write 304 bytes
[12:34:13]COMPLETE!
[12:34:16]
[12:34:16]CF: 70 f2 00 00 63
[12:34:16]sioFuji::sio_process() called
[12:34:16]ACK!
[12:34:16]Fuji cmd: READ DEVICE SLOTS
[12:34:16]->SIO write 304 bytes
[12:34:16]COMPLETE!
[12:34:16]
[12:34:16]CF: 70 f4 00 00 65
[12:34:16]ACK!
[12:34:16]Fuji cmd: READ HOST SLOTS
[12:34:16]->SIO write 256 bytes
[12:34:16]COMPLETE!
[12:34:16]
[12:34:16]ACK!
[12:34:16]COMPLETE!
[12:34:16]
[12:34:16]CF: 70 f9 01 00 6b
[12:34:16]ACK!
[12:34:16]Fuji cmd: MOUNT HOST
[12:34:16]::mount {1} "fujinet.online"
[12:34:16]::mount_local Attempting mount of "fujinet.online"
[12:34:16]::mount_tnfs {1:2} "fujinet.online"
[12:34:16]::mount_tnfs Currently connected to host "fujinet.online"
[12:34:16]COMPLETE!
[12:34:16]
[12:34:16]CF: 70 f8 00 01 6a
[12:34:16]ACK!
[12:34:16]Fuji cmd: MOUNT IMAGE
[12:34:16]Selecting '/networking/weather.atr' from host #1 as r on D1:
[12:34:16]fujiHost #1 opening file path "/networking/weather.atr"
[12:34:16]TNFS open file: "/networking/weather.atr" (0x0001, 0x01b6)
[12:34:16]File opened, handle ID: 0, size: 92176, pos: 0
[12:34:16]::get_filesize
[12:34:16]tnfs_lseek currpos=0, pos=0, typ=1
[12:34:16]tnfs_lseek success, new pos=0, response pos=0
[12:34:16]tnfs_lseek currpos=0, pos=0, typ=2
[12:34:16]tnfs_lseek success, new pos=92176, response pos=92176
[12:34:16]tnfs_lseek currpos=92176, pos=0, typ=0
[12:34:16]disk MOUNT
[12:34:16]ATR MOUNT
[12:34:16]tnfs_lseek currpos=0, pos=0, typ=0
[12:34:16]mounted ATR: paragraphs=5760, sect_size=128, sect_count=720, disk_size=92176
[12:34:16]COMPLETE!
[12:34:18]
[12:34:18]CF: 31 53 00 00 84
[12:34:18]disk sio_process()
[12:34:18]ACK!
[12:34:18]disk STATUS
[12:34:18]response: 0x00, 0xff, 0xfe
[12:34:18]->SIO write 4 bytes
[12:34:18]COMPLETE!
[12:34:18]
[12:34:18]CF: 31 52 01 00 84
[12:34:18]ACK!
[12:34:18]ATR READ
[12:34:18]->SIO write 128 bytes
[12:34:18]COMPLETE!
[12:34:18]
[12:34:18]CF: 31 52 02 00 85
[12:34:18]ACK!
[12:34:18]ATR READ
[12:34:18]COMPLETE!
[12:34:18]
[12:34:18]CF: 31 52 03 00 86
[12:34:18]ACK!
[12:34:18]ATR READ
[12:34:18]COMPLETE!
[12:34:18]
[12:34:18]CF: 31 52 e6 00 6a
[12:34:18]ACK!
[12:34:18]ATR READ
[12:34:18]tnfs_lseek currpos=512, pos=28672, typ=0
[12:34:18]_tnfs_cache_seek current=512, destination=28672, cache_start=0, cache_end=512
[12:34:18]_tnfs_cache_seek outside cached region
[12:34:18]tnfs_lseek success, new pos=28672, response pos=28672
[12:34:18]tnfs_lseek currpos=28800, pos=28672, typ=0
[12:34:18]_tnfs_cache_seek current=28800, destination=28672, cache_start=28672, cache_end=29184
[12:34:18]_tnfs_cache_seek within cached region
[12:34:18]tnfs_lseek currpos=28672, pos=29328, typ=0
[12:34:18]_tnfs_cache_seek current=28672, destination=29328, cache_start=28672, cache_end=29184
[12:34:19]tnfs_lseek success, new pos=29328, response pos=29328
[12:34:19]->SIO write 128 bytes
[12:34:19]COMPLETE!
[12:34:19]
[12:34:19]CF: 31 52 e7 00 6b
[12:34:19]disk sio_process()
[12:34:19]ACK!
[12:34:19]ATR READ
[12:34:19]COMPLETE!
[12:34:19]
[12:34:19]CF: 31 52 e8 00 6c
[12:34:19]ACK!
[12:34:19]ATR READ
[12:34:19]COMPLETE!
[12:34:19]
[12:34:19]CF: 31 52 e9 00 6d
[12:34:19]ACK!
[12:34:19]ATR READ
[12:34:19]COMPLETE!
[12:34:19]
[12:34:19]CF: 31 52 ea 00 6e
[12:34:19]ACK!
[12:34:19]ATR READ
[12:34:19]COMPLETE!
[12:34:19]
[12:34:19]CF: 31 52 eb 00 6f
[12:34:19]ACK!
[12:34:19]ATR READ
[12:34:19]COMPLETE!
[12:34:19]
[12:34:19]CF: 31 52 ec 00 70
[12:34:19]ACK!
[12:34:19]ATR READ
[12:34:19]COMPLETE!
[12:34:19]
[12:34:19]CF: 31 52 ed 00 71
[12:34:19]ACK!
[12:34:19]ATR READ
[12:34:19]COMPLETE!
[12:34:19]
[12:34:19]CF: 31 52 ee 00 72
[12:34:19]ACK!
[12:34:19]ATR READ
[12:34:19]COMPLETE!
[12:34:19]
[12:34:19]CF: 31 52 ef 00 73
[12:34:19]ACK!
[12:34:19]ATR READ
[12:34:19]COMPLETE!
[12:34:19]
[12:34:19]CF: 31 52 f0 00 74
[12:34:19]ACK!
[12:34:19]ATR READ
[12:34:19]COMPLETE!
[12:34:20]
[12:34:20]CF: 31 52 f1 00 75
[12:34:20]disk sio_process()
[12:34:20]ACK!
[12:34:20]ATR READ
[12:34:20]->SIO write 128 bytes
[12:34:20]COMPLETE!
[12:34:20]
[12:34:20]CF: 31 52 f2 00 76
[12:34:20]ACK!
[12:34:20]ATR READ
[12:34:20]COMPLETE!
[12:34:20]
[12:34:20]CF: 31 52 f3 00 77
[12:34:20]ACK!
[12:34:20]ATR READ
[12:34:20]COMPLETE!
[12:34:20]
[12:34:20]CF: 31 52 f4 00 78
[12:34:20]ACK!
[12:34:20]ATR READ
[12:34:20]COMPLETE!
[12:34:20]
[12:34:20]CF: 31 52 f5 00 79
[12:34:20]ACK!
[12:34:20]ATR READ
[12:34:20]COMPLETE!
[12:34:20]
[12:34:20]CF: 31 52 f6 00 7a
[12:34:20]ACK!
[12:34:20]ATR READ
[12:34:20]COMPLETE!
[12:34:20]
[12:34:20]CF: 31 52 f7 00 7b
[12:34:20]ACK!
[12:34:20]ATR READ
[12:34:20]COMPLETE!
[12:34:20]
[12:34:20]CF: 31 52 f8 00 7c
[12:34:20]ACK!
[12:34:20]ATR READ
[12:34:20]COMPLETE!
[12:34:20]
[12:34:20]CF: 31 52 f9 00 7d
[12:34:20]ACK!
[12:34:20]ATR READ
[12:34:20]COMPLETE!
[12:34:20]
[12:34:20]CF: 31 52 fa 00 7e
[12:34:20]ACK!
[12:34:20]ATR READ
[12:34:20]COMPLETE!
[12:34:20]
[12:34:20]CF: 31 52 fb 00 7f
[12:34:20]ACK!
[12:34:21]ATR READ
[12:34:21]->SIO write 128 bytes
[12:34:21]COMPLETE!
[12:34:21]
[12:34:21]CF: 31 52 fc 00 80
[12:34:21]disk sio_process()
[12:34:21]ACK!
[12:34:21]ATR READ
[12:34:21]COMPLETE!
[12:34:21]
[12:34:21]CF: 31 52 fd 00 81
[12:34:21]ACK!
[12:34:21]ATR READ
[12:34:21]COMPLETE!
[12:34:21]
[12:34:21]CF: 31 52 fe 00 82
[12:34:21]ACK!
[12:34:21]ATR READ
[12:34:21]COMPLETE!
[12:34:21]
[12:34:21]CF: 31 52 ff 00 83
[12:34:21]ACK!
[12:34:21]ATR READ
[12:34:21]COMPLETE!
[12:34:21]
[12:34:21]CF: 31 52 00 01 84
[12:34:21]ACK!
[12:34:21]ATR READ
[12:34:21]COMPLETE!
[12:34:21]
[12:34:21]CF: 31 52 01 01 85
[12:34:21]ACK!
[12:34:21]ATR READ
[12:34:21]COMPLETE!
[12:34:21]
[12:34:21]CF: 31 52 02 01 86
[12:34:21]ACK!
[12:34:21]ATR READ
[12:34:21]COMPLETE!
[12:34:21]
[12:34:21]CF: 31 52 03 01 87
[12:34:21]ACK!
[12:34:21]ATR READ
[12:34:21]COMPLETE!
[12:34:21]
[12:34:21]CF: 31 52 04 01 88
[12:34:21]ACK!
[12:34:21]ATR READ
[12:34:21]COMPLETE!
[12:34:21]
[12:34:21]CF: 31 52 05 01 89
[12:34:21]ACK!
[12:34:21]ATR READ
[12:34:21]COMPLETE!
[12:34:21]
[12:34:21]CF: 31 52 06 01 8a
[12:34:21]ACK!
[12:34:21]ATR READ
[12:34:21]COMPLETE!
[12:34:22]
[12:34:22]CF: 31 52 07 01 8b
[12:34:22]disk sio_process()
[12:34:22]ACK!
[12:34:22]ATR READ
[12:34:22]->SIO write 128 bytes
[12:34:22]COMPLETE!
[12:34:22]
[12:34:22]CF: 31 52 08 01 8c
[12:34:22]ACK!
[12:34:22]ATR READ
[12:34:22]COMPLETE!
[12:34:22]
[12:34:22]CF: 31 52 09 01 8d
[12:34:22]ACK!
[12:34:22]ATR READ
[12:34:22]COMPLETE!
[12:34:22]
[12:34:22]CF: 31 52 0a 01 8e
[12:34:22]ACK!
[12:34:22]ATR READ
[12:34:22]COMPLETE!
[12:34:22]
[12:34:22]CF: 31 52 69 01 ed
[12:34:22]ACK!
[12:34:22]ATR READ
[12:34:22]tnfs_lseek currpos=34064, pos=46080, typ=0
[12:34:22]_tnfs_cache_seek current=34064, destination=46080, cache_start=33936, cache_end=34448
[12:34:22]_tnfs_cache_seek outside cached region
[12:34:22]tnfs_lseek success, new pos=46080, response pos=46080
[12:34:22]COMPLETE!
[12:34:22]
[12:34:22]CF: 31 52 6a 01 ee
[12:34:22]ACK!
[12:34:22]ATR READ
[12:34:22]COMPLETE!
[12:34:22]
[12:34:22]ACK!
[12:34:22]ATR READ
[12:34:22]tnfs_lseek currpos=46464, pos=46080, typ=0
[12:34:22]_tnfs_cache_seek current=46464, destination=46080, cache_start=46080, cache_end=46592
[12:34:22]_tnfs_cache_seek within cached region
[12:34:22]COMPLETE!
[12:34:22]
[12:34:22]CF: 31 52 04 00 87
[12:34:22]ACK!
[12:34:22]ATR READ
[12:34:22]tnfs_lseek currpos=46336, pos=0, typ=0
[12:34:22]_tnfs_cache_seek current=46336, destination=0, cache_start=46080, cache_end=46592
[12:34:22]tnfs_lseek success, new pos=0, response pos=0
[12:34:22]tnfs_lseek currpos=128, pos=0, typ=0
[12:34:22]_tnfs_cache_seek current=128, destination=0, cache_start=0, cache_end=512
[12:34:22]tnfs_lseek currpos=0, pos=400, typ=0
[12:34:22]_tnfs_cache_seek current=0, destination=400, cache_start=0, cache_end=512
[12:34:22]COMPLETE!
[12:34:23]
[12:34:23]CF: 31 52 05 00 88
[12:34:23]disk sio_process()
[12:34:23]ACK!
[12:34:23]ATR READ
[12:34:23]->SIO write 128 bytes
[12:34:23]COMPLETE!
[12:34:23]
[12:34:23]CF: 31 52 06 00 89
[12:34:23]ACK!
[12:34:23]ATR READ
[12:34:23]COMPLETE!
[12:34:23]
[12:34:23]CF: 31 52 07 00 8a
[12:34:23]ACK!
[12:34:23]ATR READ
[12:34:23]COMPLETE!
[12:34:23]
[12:34:23]CF: 31 52 08 00 8b
[12:34:23]ACK!
[12:34:23]ATR READ
[12:34:23]COMPLETE!
[12:34:23]
[12:34:23]CF: 31 52 09 00 8c
[12:34:23]ACK!
[12:34:23]ATR READ
[12:34:23]COMPLETE!
[12:34:23]
[12:34:23]CF: 31 52 0a 00 8d
[12:34:23]ACK!
[12:34:23]ATR READ
[12:34:23]COMPLETE!
[12:34:23]
[12:34:23]CF: 31 52 0b 00 8e
[12:34:23]ACK!
[12:34:23]ATR READ
[12:34:23]COMPLETE!
[12:34:23]
[12:34:23]CF: 31 52 0c 00 8f
[12:34:23]ACK!
[12:34:23]ATR READ
[12:34:23]COMPLETE!
[12:34:23]
[12:34:23]CF: 31 52 0d 00 90
[12:34:23]ACK!
[12:34:23]ATR READ
[12:34:23]COMPLETE!
[12:34:24]
[12:34:24]CF: 31 52 0e 00 91
[12:34:24]disk sio_process()
[12:34:24]ACK!
[12:34:24]ATR READ
[12:34:24]->SIO write 128 bytes
[12:34:24]COMPLETE!
[12:34:24]
[12:34:24]CF: 31 52 0f 00 92
[12:34:24]ACK!
[12:34:24]ATR READ
[12:34:24]COMPLETE!
[12:34:24]
[12:34:24]CF: 31 52 10 00 93
[12:34:24]ACK!
[12:34:24]ATR READ
[12:34:24]COMPLETE!
[12:34:24]
[12:34:24]CF: 31 52 11 00 94
[12:34:24]ACK!
[12:34:24]ATR READ
[12:34:24]COMPLETE!
[12:34:24]
[12:34:24]CF: 31 52 12 00 95
[12:34:24]ACK!
[12:34:24]ATR READ
[12:34:24]COMPLETE!
[12:34:24]
[12:34:24]CF: 31 52 13 00 96
[12:34:24]ACK!
[12:34:24]ATR READ
[12:34:24]COMPLETE!
[12:34:24]
[12:34:24]CF: 31 52 14 00 97
[12:34:24]ACK!
[12:34:24]ATR READ
[12:34:24]COMPLETE!
[12:34:24]
[12:34:24]CF: 31 52 15 00 98
[12:34:24]ACK!
[12:34:24]ATR READ
[12:34:24]COMPLETE!
[12:34:24]
[12:34:24]CF: 31 52 16 00 99
[12:34:24]ACK!
[12:34:24]ATR READ
[12:34:24]COMPLETE!
[12:34:24]
[12:34:24]CF: 31 52 17 00 9a
[12:34:24]ACK!
[12:34:24]ATR READ
[12:34:24]COMPLETE!
[12:34:24]
[12:34:24]CF: 31 52 18 00 9b
[12:34:24]ACK!
[12:34:24]ATR READ
[12:34:24]COMPLETE!
[12:34:25]
[12:34:25]CF: 31 52 19 00 9c
[12:34:25]disk sio_process()
[12:34:25]ACK!
[12:34:25]ATR READ
[12:34:25]->SIO write 128 bytes
[12:34:25]COMPLETE!
[12:34:25]
[12:34:25]CF: 31 52 1a 00 9d
[12:34:25]ACK!
[12:34:25]ATR READ
[12:34:25]COMPLETE!
[12:34:25]
[12:34:25]CF: 31 52 1b 00 9e
[12:34:25]ACK!
[12:34:25]ATR READ
[12:34:25]COMPLETE!
[12:34:25]
[12:34:25]CF: 31 52 1c 00 9f
[12:34:25]ACK!
[12:34:25]ATR READ
[12:34:25]COMPLETE!
[12:34:25]
[12:34:25]CF: 31 52 1d 00 a0
[12:34:25]ACK!
[12:34:25]ATR READ
[12:34:25]COMPLETE!
[12:34:25]
[12:34:25]CF: 31 52 1e 00 a1
[12:34:25]ACK!
[12:34:25]ATR READ
[12:34:25]COMPLETE!
[12:34:25]
[12:34:25]CF: 31 52 1f 00 a2
[12:34:25]ACK!
[12:34:25]ATR READ
[12:34:25]COMPLETE!
[12:34:25]
[12:34:25]CF: 31 52 20 00 a3
[12:34:25]ACK!
[12:34:25]ATR READ
[12:34:25]COMPLETE!
[12:34:25]
[12:34:25]CF: 31 52 21 00 a4
[12:34:25]ACK!
[12:34:25]ATR READ
[12:34:25]COMPLETE!
[12:34:25]
[12:34:25]CF: 31 52 22 00 a5
[12:34:25]ACK!
[12:34:25]ATR READ
[12:34:25]COMPLETE!
[12:34:25]
[12:34:25]CF: 31 52 23 00 a6
[12:34:25]ACK!
[12:34:25]ATR READ
[12:34:25]COMPLETE!
[12:34:26]
[12:34:26]CF: 31 52 24 00 a7
[12:34:26]disk sio_process()
[12:34:26]ACK!
[12:34:26]ATR READ
[12:34:26]->SIO write 128 bytes
[12:34:26]COMPLETE!
[12:34:26]
[12:34:26]CF: 31 52 25 00 a8
[12:34:26]ACK!
[12:34:26]ATR READ
[12:34:26]COMPLETE!
[12:34:26]
[12:34:26]CF: 31 52 26 00 a9
[12:34:26]ACK!
[12:34:26]ATR READ
[12:34:26]COMPLETE!
[12:34:26]
[12:34:26]CF: 31 52 27 00 aa
[12:34:26]ACK!
[12:34:26]ATR READ
[12:34:26]COMPLETE!
[12:34:26]
[12:34:26]CF: 31 52 28 00 ab
[12:34:26]ACK!
[12:34:26]ATR READ
[12:34:26]COMPLETE!
[12:34:26]
[12:34:26]CF: 31 52 29 00 ac
[12:34:26]ACK!
[12:34:26]ATR READ
[12:34:26]COMPLETE!
[12:34:26]
[12:34:26]CF: 31 52 2a 00 ad
[12:34:26]ACK!
[12:34:26]ATR READ
[12:34:26]COMPLETE!
[12:34:26]
[12:34:26]CF: 31 52 2b 00 ae
[12:34:26]ACK!
[12:34:26]ATR READ
[12:34:26]COMPLETE!
[12:34:26]
[12:34:26]CF: 31 52 2c 00 af
[12:34:26]ACK!
[12:34:26]ATR READ
[12:34:26]COMPLETE!
[12:34:26]
[12:34:26]CF: 31 52 2d 00 b0
[12:34:26]ACK!
[12:34:26]ATR READ
[12:34:26]COMPLETE!
[12:34:26]
[12:34:26]CF: 31 52 2e 00 b1
[12:34:26]ACK!
[12:34:26]ATR READ
[12:34:26]COMPLETE!
[12:34:27]
[12:34:27]CF: 31 52 2f 00 b2
[12:34:27]disk sio_process()
[12:34:27]ACK!
[12:34:27]ATR READ
[12:34:27]->SIO write 128 bytes
[12:34:27]COMPLETE!
[12:34:27]
[12:34:27]CF: 31 52 30 00 b3
[12:34:27]ACK!
[12:34:27]ATR READ
[12:34:27]COMPLETE!
[12:34:27]
[12:34:27]CF: 31 52 31 00 b4
[12:34:27]ACK!
[12:34:27]ATR READ
[12:34:27]COMPLETE!
[12:34:27]
[12:34:27]CF: 31 52 32 00 b5
[12:34:27]ACK!
[12:34:27]ATR READ
[12:34:27]COMPLETE!
[12:34:27]
[12:34:27]CF: 31 52 33 00 b6
[12:34:27]ACK!
[12:34:27]ATR READ
[12:34:27]COMPLETE!
[12:34:27]
[12:34:27]CF: 31 52 34 00 b7
[12:34:27]ACK!
[12:34:27]ATR READ
[12:34:27]COMPLETE!
[12:34:27]
[12:34:27]CF: 31 52 35 00 b8
[12:34:27]ACK!
[12:34:27]ATR READ
[12:34:27]COMPLETE!
[12:34:27]
[12:34:27]CF: 31 52 36 00 b9
[12:34:27]ACK!
[12:34:27]ATR READ
[12:34:27]COMPLETE!
[12:34:27]
[12:34:27]CF: 31 52 37 00 ba
[12:34:27]ACK!
[12:34:27]ATR READ
[12:34:27]COMPLETE!
[12:34:27]
[12:34:27]CF: 31 52 38 00 bb
[12:34:27]ACK!
[12:34:27]ATR READ
[12:34:27]COMPLETE!
[12:34:27]
[12:34:28]CF: 31 52 39 00 bc
[12:34:28]disk sio_process()
[12:34:28]ACK!
[12:34:28]ATR READ
[12:34:28]->SIO write 128 bytes
[12:34:28]COMPLETE!
[12:34:28]
[12:34:28]CF: 31 52 3a 00 bd
[12:34:28]ACK!
[12:34:28]ATR READ
[12:34:28]COMPLETE!
[12:34:28]
[12:34:28]CF: 31 52 3b 00 be
[12:34:28]ACK!
[12:34:28]ATR READ
[12:34:28]COMPLETE!
[12:34:28]
[12:34:28]CF: 31 52 3c 00 bf
[12:34:28]ACK!
[12:34:28]ATR READ
[12:34:28]COMPLETE!
[12:34:28]
[12:34:28]CF: 31 52 3d 00 c0
[12:34:28]ACK!
[12:34:28]ATR READ
[12:34:28]COMPLETE!
[12:34:28]
[12:34:28]CF: 31 52 3e 00 c1
[12:34:28]ACK!
[12:34:28]ATR READ
[12:34:28]COMPLETE!
[12:34:28]
[12:34:28]CF: 31 52 3f 00 c2
[12:34:28]ACK!
[12:34:28]ATR READ
[12:34:28]COMPLETE!
[12:34:28]
[12:34:28]CF: 31 52 40 00 c3
[12:34:28]ACK!
[12:34:28]ATR READ
[12:34:28]COMPLETE!
[12:34:28]
[12:34:28]CF: 31 52 41 00 c4
[12:34:28]ACK!
[12:34:28]ATR READ
[12:34:28]COMPLETE!
[12:34:28]
[12:34:28]CF: 31 52 42 00 c5
[12:34:28]ACK!
[12:34:28]ATR READ
[12:34:28]COMPLETE!
[12:34:28]
[12:34:28]CF: 31 52 43 00 c6
[12:34:28]ACK!
[12:34:28]ATR READ
[12:34:28]COMPLETE!
[12:34:28]
[12:34:28]CF: 31 52 44 00 c7
[12:34:28]ACK!
[12:34:28]ATR READ
[12:34:29]->SIO write 128 bytes
[12:34:29]COMPLETE!
[12:34:29]
[12:34:29]CF: 31 52 45 00 c8
[12:34:29]disk sio_process()
[12:34:29]ACK!
[12:34:29]ATR READ
[12:34:29]COMPLETE!
[12:34:29]
[12:34:29]CF: 31 52 46 00 c9
[12:34:29]ACK!
[12:34:29]ATR READ
[12:34:29]COMPLETE!
[12:34:29]
[12:34:29]CF: 31 52 47 00 ca
[12:34:29]ACK!
[12:34:29]ATR READ
[12:34:29]COMPLETE!
[12:34:29]
[12:34:29]CF: 31 52 48 00 cb
[12:34:29]ACK!
[12:34:29]ATR READ
[12:34:29]COMPLETE!
[12:34:29]
[12:34:29]CF: 31 52 49 00 cc
[12:34:29]ACK!
[12:34:29]ATR READ
[12:34:29]COMPLETE!
[12:34:29]
[12:34:29]CF: 31 52 4a 00 cd
[12:34:29]ACK!
[12:34:29]ATR READ
[12:34:29]COMPLETE!
[12:34:29]
[12:34:29]CF: 31 52 4b 00 ce
[12:34:29]ACK!
[12:34:29]ATR READ
[12:34:29]COMPLETE!
[12:34:29]
[12:34:29]CF: 31 52 4c 00 cf
[12:34:29]ACK!
[12:34:29]ATR READ
[12:34:29]COMPLETE!
[12:34:29]
[12:34:29]CF: 31 52 4d 00 d0
[12:34:29]ACK!
[12:34:29]ATR READ
[12:34:29]COMPLETE!
[12:34:29]
[12:34:29]CF: 31 52 4e 00 d1
[12:34:29]ACK!
[12:34:29]ATR READ
[12:34:29]COMPLETE!
[12:34:30]
[12:34:30]CF: 31 52 4f 00 d2
[12:34:30]disk sio_process()
[12:34:30]ACK!
[12:34:30]ATR READ
[12:34:30]->SIO write 128 bytes
[12:34:30]COMPLETE!
[12:34:30]
[12:34:30]CF: 31 52 50 00 d3
[12:34:30]ACK!
[12:34:30]ATR READ
[12:34:30]COMPLETE!
[12:34:30]
[12:34:30]CF: 31 52 51 00 d4
[12:34:30]ACK!
[12:34:30]ATR READ
[12:34:30]COMPLETE!
[12:34:30]
[12:34:30]CF: 31 52 52 00 d5
[12:34:30]ACK!
[12:34:30]ATR READ
[12:34:30]COMPLETE!
[12:34:30]
[12:34:30]CF: 31 52 53 00 d6
[12:34:30]ACK!
[12:34:30]ATR READ
[12:34:30]COMPLETE!
[12:34:30]
[12:34:30]CF: 31 52 54 00 d7
[12:34:30]ACK!
[12:34:30]ATR READ
[12:34:30]COMPLETE!
[12:34:30]
[12:34:30]CF: 31 52 55 00 d8
[12:34:30]ACK!
[12:34:30]ATR READ
[12:34:30]COMPLETE!
[12:34:30]
[12:34:30]CF: 31 52 56 00 d9
[12:34:30]ACK!
[12:34:30]ATR READ
[12:34:30]COMPLETE!
[12:34:30]
[12:34:30]CF: 31 52 57 00 da
[12:34:30]ACK!
[12:34:30]ATR READ
[12:34:30]COMPLETE!
[12:34:30]
[12:34:30]CF: 31 52 58 00 db
[12:34:30]ACK!
[12:34:30]ATR READ
[12:34:30]COMPLETE!
[12:34:30]
[12:34:30]CF: 31 52 59 00 dc
[12:34:30]ACK!
[12:34:31]ATR READ
[12:34:31]->SIO write 128 bytes
[12:34:31]COMPLETE!
[12:34:31]
[12:34:31]CF: 31 52 5a 00 dd
[12:34:31]disk sio_process()
[12:34:31]ACK!
[12:34:31]ATR READ
[12:34:31]COMPLETE!
[12:34:31]
[12:34:31]CF: 31 52 5b 00 de
[12:34:31]ACK!
[12:34:31]ATR READ
[12:34:31]COMPLETE!
[12:34:31]
[12:34:31]CF: 31 52 5c 00 df
[12:34:31]ACK!
[12:34:31]ATR READ
[12:34:31]COMPLETE!
[12:34:31]
[12:34:31]CF: 31 52 5d 00 e0
[12:34:31]ACK!
[12:34:31]ATR READ
[12:34:31]COMPLETE!
[12:34:31]
[12:34:31]CF: 31 52 5e 00 e1
[12:34:31]ACK!
[12:34:31]ATR READ
[12:34:31]COMPLETE!
[12:34:31]
[12:34:31]CF: 31 52 5f 00 e2
[12:34:31]ACK!
[12:34:31]ATR READ
[12:34:31]COMPLETE!
[12:34:31]
[12:34:31]CF: 31 52 60 00 e3
[12:34:31]ACK!
[12:34:31]ATR READ
[12:34:31]COMPLETE!
[12:34:31]
[12:34:31]CF: 31 52 61 00 e4
[12:34:31]ACK!
[12:34:31]ATR READ
[12:34:31]COMPLETE!
[12:34:31]
[12:34:31]CF: 31 52 62 00 e5
[12:34:31]ACK!
[12:34:31]ATR READ
[12:34:31]COMPLETE!
[12:34:31]
[12:34:31]CF: 31 52 63 00 e6
[12:34:31]ACK!
[12:34:31]ATR READ
[12:34:31]COMPLETE!
[12:34:31]
[12:34:31]CF: 31 52 64 00 e7
[12:34:31]ACK!
[12:34:31]ATR READ
[12:34:31]COMPLETE!
[12:34:32]
[12:34:32]CF: 31 52 65 00 e8
[12:34:32]disk sio_process()
[12:34:32]ACK!
[12:34:32]ATR READ
[12:34:32]->SIO write 128 bytes
[12:34:32]COMPLETE!
[12:34:32]
[12:34:32]CF: 31 52 66 00 e9
[12:34:32]ACK!
[12:34:32]ATR READ
[12:34:32]COMPLETE!
[12:34:32]
[12:34:32]CF: 31 52 67 00 ea
[12:34:32]ACK!
[12:34:32]ATR READ
[12:34:32]COMPLETE!
[12:34:32]
[12:34:32]CF: 31 52 68 00 eb
[12:34:32]ACK!
[12:34:32]ATR READ
[12:34:32]COMPLETE!
[12:34:32]
[12:34:32]CF: 31 52 69 00 ec
[12:34:32]ACK!
[12:34:32]ATR READ
[12:34:32]COMPLETE!
[12:34:32]
[12:34:32]CF: 31 52 6a 00 ed
[12:34:32]ACK!
[12:34:32]ATR READ
[12:34:32]COMPLETE!
[12:34:32]
[12:34:32]CF: 31 52 6b 00 ee
[12:34:32]ACK!
[12:34:32]ATR READ
[12:34:32]COMPLETE!
[12:34:32]
[12:34:32]CF: 31 52 6c 00 ef
[12:34:32]ACK!
[12:34:32]ATR READ
[12:34:32]COMPLETE!
[12:34:32]
[12:34:32]CF: 31 52 6d 00 f0
[12:34:32]ACK!
[12:34:32]ATR READ
[12:34:32]COMPLETE!
[12:34:32]
[12:34:32]CF: 31 52 6e 00 f1
[12:34:32]ACK!
[12:34:32]ATR READ
[12:34:32]COMPLETE!
[12:34:32]
[12:34:32]CF: 31 52 6f 00 f2
[12:34:32]ACK!
[12:34:32]ATR READ
[12:34:32]COMPLETE!
[12:34:33]
[12:34:33]CF: 31 52 70 00 f3
[12:34:33]disk sio_process()
[12:34:33]ACK!
[12:34:33]ATR READ
[12:34:33]->SIO write 128 bytes
[12:34:33]COMPLETE!
[12:34:33]
[12:34:33]CF: 31 52 71 00 f4
[12:34:33]ACK!
[12:34:33]ATR READ
[12:34:33]COMPLETE!
[12:34:33]
[12:34:33]CF: 31 52 72 00 f5
[12:34:33]ACK!
[12:34:33]ATR READ
[12:34:33]COMPLETE!
[12:34:33]
[12:34:33]CF: 31 52 73 00 f6
[12:34:33]ACK!
[12:34:33]ATR READ
[12:34:33]COMPLETE!
[12:34:33]
[12:34:33]CF: 31 52 74 00 f7
[12:34:33]ACK!
[12:34:33]ATR READ
[12:34:33]COMPLETE!
[12:34:33]
[12:34:33]CF: 31 52 75 00 f8
[12:34:33]ACK!
[12:34:33]ATR READ
[12:34:33]COMPLETE!
[12:34:33]
[12:34:33]CF: 31 52 76 00 f9
[12:34:33]ACK!
[12:34:33]ATR READ
[12:34:33]COMPLETE!
[12:34:33]
[12:34:33]CF: 31 52 77 00 fa
[12:34:33]ACK!
[12:34:33]ATR READ
[12:34:33]COMPLETE!
[12:34:33]
[12:34:33]CF: 31 52 78 00 fb
[12:34:33]ACK!
[12:34:33]ATR READ
[12:34:33]COMPLETE!
[12:34:33]
[12:34:33]CF: 31 52 79 00 fc
[12:34:33]ACK!
[12:34:33]ATR READ
[12:34:33]COMPLETE!
[12:34:34]
[12:34:34]CF: 31 52 7a 00 fd
[12:34:34]disk sio_process()
[12:34:34]ACK!
[12:34:34]ATR READ
[12:34:34]->SIO write 128 bytes
[12:34:34]COMPLETE!
[12:34:34]
[12:34:34]CF: 31 52 7b 00 fe
[12:34:34]ACK!
[12:34:34]ATR READ
[12:34:34]COMPLETE!
[12:34:34]
[12:34:34]CF: 31 52 7c 00 ff
[12:34:34]ACK!
[12:34:34]ATR READ
[12:34:34]COMPLETE!
[12:34:34]
[12:34:34]CF: 31 52 7d 00 01
[12:34:34]ACK!
[12:34:34]ATR READ
[12:34:34]COMPLETE!
[12:34:34]
[12:34:34]CF: 31 52 7e 00 02
[12:34:34]ACK!
[12:34:34]ATR READ
[12:34:34]COMPLETE!
[12:34:34]
[12:34:34]CF: 31 52 7f 00 03
[12:34:34]ACK!
[12:34:34]ATR READ
[12:34:34]COMPLETE!
[12:34:34]
[12:34:34]CF: 31 52 80 00 04
[12:34:34]ACK!
[12:34:34]ATR READ
[12:34:34]COMPLETE!
[12:34:34]
[12:34:34]CF: 31 52 81 00 05
[12:34:34]ACK!
[12:34:34]ATR READ
[12:34:34]COMPLETE!
[12:34:34]
[12:34:34]CF: 31 52 82 00 06
[12:34:34]ACK!
[12:34:34]ATR READ
[12:34:34]COMPLETE!
[12:34:34]
[12:34:34]CF: 31 52 83 00 07
[12:34:34]ACK!
[12:34:34]ATR READ
[12:34:34]COMPLETE!
[12:34:34]
[12:34:34]CF: 31 52 84 00 08
[12:34:34]ACK!
[12:34:34]ATR READ
[12:34:34]COMPLETE!
[12:34:35]
[12:34:35]CF: 31 52 85 00 09
[12:34:35]disk sio_process()
[12:34:35]ACK!
[12:34:35]ATR READ
[12:34:35]->SIO write 128 bytes
[12:34:35]COMPLETE!
[12:34:35]
[12:34:35]CF: 31 52 86 00 0a
[12:34:35]ACK!
[12:34:35]ATR READ
[12:34:35]COMPLETE!
[12:34:35]
[12:34:35]CF: 31 52 87 00 0b
[12:34:35]ACK!
[12:34:35]ATR READ
[12:34:35]COMPLETE!
[12:34:35]
[12:34:35]CF: 31 52 88 00 0c
[12:34:35]ACK!
[12:34:35]ATR READ
[12:34:35]COMPLETE!
[12:34:35]
[12:34:35]CF: 31 52 89 00 0d
[12:34:35]ACK!
[12:34:35]ATR READ
[12:34:35]COMPLETE!
[12:34:35]
[12:34:35]CF: 31 52 8a 00 0e
[12:34:35]ACK!
[12:34:35]ATR READ
[12:34:35]COMPLETE!
[12:34:35]
[12:34:35]CF: 31 52 8b 00 0f
[12:34:35]ACK!
[12:34:35]ATR READ
[12:34:35]COMPLETE!
[12:34:35]
[12:34:35]CF: 31 52 8c 00 10
[12:34:35]ACK!
[12:34:35]ATR READ
[12:34:35]COMPLETE!
[12:34:35]
[12:34:35]CF: 31 52 8d 00 11
[12:34:35]ACK!
[12:34:35]ATR READ
[12:34:35]COMPLETE!
[12:34:35]
[12:34:35]CF: 31 52 8e 00 12
[12:34:35]ACK!
[12:34:35]ATR READ
[12:34:35]COMPLETE!
[12:34:35]
[12:34:35]CF: 31 52 8f 00 13
[12:34:35]ACK!
[12:34:35]ATR READ
[12:34:35]COMPLETE!
[12:34:36]
[12:34:36]CF: 31 52 90 00 14
[12:34:36]disk sio_process()
[12:34:36]ACK!
[12:34:36]ATR READ
[12:34:36]->SIO write 128 bytes
[12:34:36]COMPLETE!
[12:34:36]
[12:34:36]CF: 31 52 91 00 15
[12:34:36]ACK!
[12:34:36]ATR READ
[12:34:36]COMPLETE!
[12:34:36]
[12:34:36]CF: 31 52 92 00 16
[12:34:36]ACK!
[12:34:36]ATR READ
[12:34:36]COMPLETE!
[12:34:36]
[12:34:36]CF: 31 52 93 00 17
[12:34:36]ACK!
[12:34:36]ATR READ
[12:34:36]COMPLETE!
[12:34:36]
[12:34:36]CF: 31 52 94 00 18
[12:34:36]ACK!
[12:34:36]ATR READ
[12:34:36]COMPLETE!
[12:34:36]
[12:34:36]CF: 31 52 95 00 19
[12:34:36]ACK!
[12:34:36]ATR READ
[12:34:36]COMPLETE!
[12:34:36]
[12:34:36]CF: 31 52 96 00 1a
[12:34:36]ACK!
[12:34:36]ATR READ
[12:34:36]COMPLETE!
[12:34:36]
[12:34:36]CF: 31 52 97 00 1b
[12:34:36]ACK!
[12:34:36]ATR READ
[12:34:36]COMPLETE!
[12:34:36]
[12:34:36]CF: 31 52 98 00 1c
[12:34:36]ACK!
[12:34:36]ATR READ
[12:34:36]COMPLETE!
[12:34:36]
[12:34:36]CF: 31 52 99 00 1d
[12:34:36]ACK!
[12:34:36]ATR READ
[12:34:36]COMPLETE!
[12:34:36]
[12:34:36]CF: 31 52 9a 00 1e
[12:34:36]ACK!
[12:34:36]ATR READ
[12:34:36]COMPLETE!
[12:34:37]
[12:34:37]CF: 31 52 9b 00 1f
[12:34:37]disk sio_process()
[12:34:37]ACK!
[12:34:37]ATR READ
[12:34:37]->SIO write 128 bytes
[12:34:37]COMPLETE!
[12:34:37]
[12:34:37]CF: 31 52 9c 00 20
[12:34:37]ACK!
[12:34:37]ATR READ
[12:34:37]COMPLETE!
[12:34:37]
[12:34:37]CF: 31 52 9d 00 21
[12:34:37]ACK!
[12:34:37]ATR READ
[12:34:37]COMPLETE!
[12:34:37]
[12:34:37]CF: 31 52 9e 00 22
[12:34:37]ACK!
[12:34:37]ATR READ
[12:34:37]COMPLETE!
[12:34:37]
[12:34:37]CF: 31 52 9f 00 23
[12:34:37]ACK!
[12:34:37]ATR READ
[12:34:37]COMPLETE!
[12:34:37]
[12:34:37]CF: 31 52 a0 00 24
[12:34:37]ACK!
[12:34:37]ATR READ
[12:34:37]COMPLETE!
[12:34:37]
[12:34:37]CF: 31 52 a1 00 25
[12:34:37]ACK!
[12:34:37]ATR READ
[12:34:37]COMPLETE!
[12:34:37]
[12:34:37]CF: 31 52 a2 00 26
[12:34:37]ACK!
[12:34:37]ATR READ
[12:34:37]COMPLETE!
[12:34:37]
[12:34:37]CF: 31 52 a3 00 27
[12:34:37]ACK!
[12:34:37]ATR READ
[12:34:37]COMPLETE!
[12:34:37]
[12:34:37]CF: 31 52 a4 00 28
[12:34:37]ACK!
[12:34:37]ATR READ
[12:34:37]COMPLETE!
[12:34:38]
[12:34:38]CF: 31 52 a5 00 29
[12:34:38]disk sio_process()
[12:34:38]ACK!
[12:34:38]ATR READ
[12:34:38]->SIO write 128 bytes
[12:34:38]COMPLETE!
[12:34:38]
[12:34:38]CF: 31 52 a6 00 2a
[12:34:38]ACK!
[12:34:38]ATR READ
[12:34:38]COMPLETE!
[12:34:38]
[12:34:38]CF: 31 52 a7 00 2b
[12:34:38]ACK!
[12:34:38]ATR READ
[12:34:38]COMPLETE!
[12:34:38]
[12:34:38]CF: 31 52 a8 00 2c
[12:34:38]ACK!
[12:34:38]ATR READ
[12:34:38]COMPLETE!
[12:34:38]
[12:34:38]CF: 31 52 a9 00 2d
[12:34:38]ACK!
[12:34:38]ATR READ
[12:34:38]COMPLETE!
[12:34:38]
[12:34:38]CF: 31 52 aa 00 2e
[12:34:38]ACK!
[12:34:38]ATR READ
[12:34:38]COMPLETE!
[12:34:38]
[12:34:38]CF: 31 52 ab 00 2f
[12:34:38]ACK!
[12:34:38]ATR READ
[12:34:38]COMPLETE!
[12:34:38]
[12:34:38]CF: 31 52 ac 00 30
[12:34:38]ACK!
[12:34:38]ATR READ
[12:34:38]COMPLETE!
[12:34:38]
[12:34:38]CF: 31 52 ad 00 31
[12:34:38]ACK!
[12:34:38]ATR READ
[12:34:38]COMPLETE!
[12:34:38]
[12:34:38]CF: 31 52 ae 00 32
[12:34:38]ACK!
[12:34:38]ATR READ
[12:34:38]COMPLETE!
[12:34:38]
[12:34:38]CF: 31 52 af 00 33
[12:34:38]ACK!
[12:34:38]ATR READ
[12:34:38]COMPLETE!
[12:34:38]
[12:34:38]CF: 31 52 b0 00 34
[12:34:38]ACK!
[12:34:38]ATR READ
[12:34:39]->SIO write 128 bytes
[12:34:39]COMPLETE!
[12:34:39]
[12:34:39]CF: 31 52 b1 00 35
[12:34:39]disk sio_process()
[12:34:39]ACK!
[12:34:39]ATR READ
[12:34:39]COMPLETE!
[12:34:39]
[12:34:39]CF: 31 52 b2 00 36
[12:34:39]ACK!
[12:34:39]ATR READ
[12:34:39]COMPLETE!
[12:34:39]
[12:34:39]CF: 31 52 b3 00 37
[12:34:39]ACK!
[12:34:39]ATR READ
[12:34:39]COMPLETE!
[12:34:39]
[12:34:39]CF: 31 52 b4 00 38
[12:34:39]ACK!
[12:34:39]ATR READ
[12:34:39]COMPLETE!
[12:34:39]
[12:34:39]CF: 31 52 b5 00 39
[12:34:39]ACK!
[12:34:39]ATR READ
[12:34:39]COMPLETE!
[12:34:39]
[12:34:39]CF: 31 52 b6 00 3a
[12:34:39]ACK!
[12:34:39]ATR READ
[12:34:39]COMPLETE!
[12:34:39]
[12:34:39]CF: 31 52 b7 00 3b
[12:34:39]ACK!
[12:34:39]ATR READ
[12:34:39]COMPLETE!
[12:34:39]
[12:34:39]CF: 31 52 b8 00 3c
[12:34:39]ACK!
[12:34:39]ATR READ
[12:34:39]COMPLETE!
[12:34:39]
[12:34:39]CF: 31 52 b9 00 3d
[12:34:39]ACK!
[12:34:39]ATR READ
[12:34:39]COMPLETE!
[12:34:39]
[12:34:39]CF: 31 52 ba 00 3e
[12:34:39]ACK!
[12:34:39]ATR READ
[12:34:39]COMPLETE!
[12:34:40]
[12:34:40]CF: 31 52 bb 00 3f
[12:34:40]disk sio_process()
[12:34:40]ACK!
[12:34:40]ATR READ
[12:34:40]->SIO write 128 bytes
[12:34:40]COMPLETE!
[12:34:40]
[12:34:40]CF: 31 52 bc 00 40
[12:34:40]ACK!
[12:34:40]ATR READ
[12:34:40]COMPLETE!
[12:34:40]
[12:34:40]CF: 31 52 bd 00 41
[12:34:40]ACK!
[12:34:40]ATR READ
[12:34:40]COMPLETE!
[12:34:40]
[12:34:40]CF: 31 52 be 00 42
[12:34:40]ACK!
[12:34:40]ATR READ
[12:34:40]COMPLETE!
[12:34:40]
[12:34:40]CF: 31 52 bf 00 43
[12:34:40]ACK!
[12:34:40]ATR READ
[12:34:40]COMPLETE!
[12:34:40]
[12:34:40]CF: 31 52 c0 00 44
[12:34:40]ACK!
[12:34:40]ATR READ
[12:34:40]COMPLETE!
[12:34:40]
[12:34:40]CF: 31 52 c1 00 45
[12:34:40]ACK!
[12:34:40]ATR READ
[12:34:40]COMPLETE!
[12:34:40]
[12:34:40]CF: 31 52 c2 00 46
[12:34:40]ACK!
[12:34:40]ATR READ
[12:34:40]COMPLETE!
[12:34:40]
[12:34:40]CF: 31 52 c3 00 47
[12:34:40]ACK!
[12:34:40]ATR READ
[12:34:40]COMPLETE!
[12:34:40]
[12:34:40]CF: 31 52 c4 00 48
[12:34:40]ACK!
[12:34:40]ATR READ
[12:34:40]COMPLETE!
[12:34:40]
[12:34:41]CF: 31 52 c5 00 49
[12:34:41]disk sio_process()
[12:34:41]ACK!
[12:34:41]ATR READ
[12:34:41]->SIO write 128 bytes
[12:34:41]COMPLETE!
[12:34:41]
[12:34:41]CF: 31 52 c6 00 4a
[12:34:41]ACK!
[12:34:41]ATR READ
[12:34:41]COMPLETE!
[12:34:41]
[12:34:41]CF: 31 52 c7 00 4b
[12:34:41]ACK!
[12:34:41]ATR READ
[12:34:41]COMPLETE!
[12:34:41]
[12:34:41]CF: 31 52 c8 00 4c
[12:34:41]ACK!
[12:34:41]ATR READ
[12:34:41]COMPLETE!
[12:34:41]
[12:34:41]CF: 31 52 c9 00 4d
[12:34:41]ACK!
[12:34:41]ATR READ
[12:34:41]COMPLETE!
[12:34:41]
[12:34:41]CF: 31 52 ca 00 4e
[12:34:41]ACK!
[12:34:41]ATR READ
[12:34:41]COMPLETE!
[12:34:41]
[12:34:41]CF: 31 52 cb 00 4f
[12:34:41]ACK!
[12:34:41]ATR READ
[12:34:41]COMPLETE!
[12:34:41]
[12:34:41]CF: 31 52 cc 00 50
[12:34:41]ACK!
[12:34:41]ATR READ
[12:34:41]COMPLETE!
[12:34:41]
[12:34:41]CF: 31 52 cd 00 51
[12:34:41]ACK!
[12:34:41]ATR READ
[12:34:41]COMPLETE!
[12:34:41]
[12:34:41]CF: 31 52 ce 00 52
[12:34:41]ACK!
[12:34:41]ATR READ
[12:34:41]COMPLETE!
[12:34:41]
[12:34:41]CF: 31 52 cf 00 53
[12:34:41]ACK!
[12:34:41]ATR READ
[12:34:41]COMPLETE!
[12:34:41]
[12:34:41]CF: 31 52 d0 00 54
[12:34:41]ACK!
[12:34:41]ATR READ
[12:34:42]->SIO write 128 bytes
[12:34:42]COMPLETE!
[12:34:42]
[12:34:42]CF: 31 52 d1 00 55
[12:34:42]disk sio_process()
[12:34:42]ACK!
[12:34:42]ATR READ
[12:34:42]COMPLETE!
[12:34:42]
[12:34:42]CF: 31 52 d2 00 56
[12:34:42]ACK!
[12:34:42]ATR READ
[12:34:42]COMPLETE!
[12:34:42]
[12:34:42]CF: 31 52 d3 00 57
[12:34:42]ACK!
[12:34:42]ATR READ
[12:34:42]COMPLETE!
[12:34:42]
[12:34:42]CF: 31 52 d4 00 58
[12:34:42]ACK!
[12:34:42]ATR READ
[12:34:42]COMPLETE!
[12:34:42]
[12:34:42]CF: 31 52 d5 00 59
[12:34:42]ACK!
[12:34:42]ATR READ
[12:34:42]COMPLETE!
[12:34:42]
[12:34:42]CF: 31 52 d6 00 5a
[12:34:42]ACK!
[12:34:42]ATR READ
[12:34:42]COMPLETE!
[12:34:42]
[12:34:42]CF: 31 52 d7 00 5b
[12:34:42]ACK!
[12:34:42]ATR READ
[12:34:42]COMPLETE!
[12:34:42]
[12:34:42]CF: 31 52 d8 00 5c
[12:34:42]ACK!
[12:34:42]ATR READ
[12:34:42]COMPLETE!
[12:34:42]
[12:34:42]CF: 31 52 d9 00 5d
[12:34:42]ACK!
[12:34:42]ATR READ
[12:34:42]COMPLETE!
[12:34:42]
[12:34:42]CF: 31 52 da 00 5e
[12:34:42]ACK!
[12:34:42]ATR READ
[12:34:42]COMPLETE!
[12:34:43]
[12:34:43]CF: 31 52 db 00 5f
[12:34:43]disk sio_process()
[12:34:43]ACK!
[12:34:43]ATR READ
[12:34:43]->SIO write 128 bytes
[12:34:43]COMPLETE!
[12:34:43]
[12:34:43]CF: 31 52 dc 00 60
[12:34:43]ACK!
[12:34:43]ATR READ
[12:34:43]COMPLETE!
[12:34:43]
[12:34:43]CF: 31 52 dd 00 61
[12:34:43]ACK!
[12:34:43]ATR READ
[12:34:43]COMPLETE!
[12:34:43]
[12:34:43]CF: 31 52 de 00 62
[12:34:43]ACK!
[12:34:43]ATR READ
[12:34:43]COMPLETE!
[12:34:43]
[12:34:43]CF: 31 52 df 00 63
[12:34:43]ACK!
[12:34:43]ATR READ
[12:34:43]COMPLETE!
[12:34:43]
[12:34:43]CF: 31 52 e0 00 64
[12:34:43]ACK!
[12:34:43]ATR READ
[12:34:43]COMPLETE!
[12:34:43]
[12:34:43]CF: 31 52 e1 00 65
[12:34:43]ACK!
[12:34:43]ATR READ
[12:34:43]COMPLETE!
[12:34:43]
[12:34:43]CF: 31 52 e2 00 66
[12:34:43]ACK!
[12:34:43]ATR READ
[12:34:43]COMPLETE!
[12:34:43]
[12:34:43]CF: 31 52 e3 00 67
[12:34:43]ACK!
[12:34:43]ATR READ
[12:34:43]COMPLETE!
[12:34:43]
[12:34:43]CF: 31 52 e4 00 68
[12:34:43]ACK!
[12:34:43]ATR READ
[12:34:43]COMPLETE!
[12:34:44]
[12:34:44]CF: 70 dc 00 00 4d
[12:34:44]sioFuji::sio_process() called
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]CF: 70 dd 00 00 4e
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]CF: 70 db 00 00 4c
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:44]NAK!
[12:34:44]
[12:34:45]sioFuji::sio_process() called
[12:34:45]NAK!
[12:34:45]
[12:34:45]CF: 70 dc 00 00 4d
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]CF: 70 de 32 00 81
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]CF: 70 db 00 00 4c
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]NAK!
[12:34:45]
[12:34:45]CF: 31 52 69 01 ed
[12:34:45]disk sio_process()
[12:34:45]ACK!
[12:34:45]ATR READ
[12:34:45]tnfs_lseek currpos=29200, pos=46080, typ=0
[12:34:45]_tnfs_cache_seek current=29200, destination=46080, cache_start=29184, cache_end=29696
[12:34:45]_tnfs_cache_seek outside cached region
[12:34:45]tnfs_lseek success, new pos=46080, response pos=46080
[12:34:45]->SIO write 128 bytes
[12:34:45]COMPLETE!
[12:34:45]
[12:34:45]CF: 31 52 e5 00 69
[12:34:45]ACK!
[12:34:45]ATR READ
[12:34:45]tnfs_lseek currpos=46336, pos=28672, typ=0
[12:34:45]_tnfs_cache_seek current=46336, destination=28672, cache_start=46080, cache_end=46592
[12:34:45]tnfs_lseek success, new pos=28672, response pos=28672
[12:34:45]tnfs_lseek currpos=28800, pos=28672, typ=0
[12:34:45]_tnfs_cache_seek current=28800, destination=28672, cache_start=28672, cache_end=29184
[12:34:45]_tnfs_cache_seek within cached region
[12:34:45]tnfs_lseek currpos=28672, pos=29200, typ=0
[12:34:45]_tnfs_cache_seek current=28672, destination=29200, cache_start=28672, cache_end=29184
[12:34:45]tnfs_lseek success, new pos=29200, response pos=29200
[12:34:46]->SIO write 128 bytes
[12:34:46]COMPLETE!
[12:34:46]
[12:34:46]CF: 31 52 69 01 ed
[12:34:46]disk sio_process()
[12:34:46]ACK!
[12:34:46]ATR READ
[12:34:46]tnfs_lseek currpos=29328, pos=46080, typ=0
[12:34:46]_tnfs_cache_seek current=29328, destination=46080, cache_start=29200, cache_end=29712
[12:34:46]_tnfs_cache_seek outside cached region
[12:34:46]tnfs_lseek success, new pos=46080, response pos=46080
[12:34:46]COMPLETE!
[12:34:46]
[12:34:46]CF: 31 52 6a 01 ee
[12:34:46]ACK!
[12:34:46]ATR READ
[12:34:46]COMPLETE!
[12:34:46]
[12:34:46]CF: 31 52 87 01 0c
[12:34:46]ACK!
[12:34:46]ATR READ
[12:34:46]tnfs_lseek currpos=46464, pos=49152, typ=0
[12:34:46]_tnfs_cache_seek current=46464, destination=49152, cache_start=46080, cache_end=46592
[12:34:46]tnfs_lseek success, new pos=49152, response pos=49152
[12:34:46]tnfs_lseek currpos=49280, pos=49152, typ=0
[12:34:46]_tnfs_cache_seek current=49280, destination=49152, cache_start=49152, cache_end=49664
[12:34:46]_tnfs_cache_seek within cached region
[12:34:46]tnfs_lseek currpos=49152, pos=49936, typ=0
[12:34:46]_tnfs_cache_seek current=49152, destination=49936, cache_start=49152, cache_end=49664
[12:34:46]tnfs_lseek success, new pos=49936, response pos=49936
[12:34:46]COMPLETE!
[12:34:46]
[12:34:46]CF: 31 52 88 01 0d
[12:34:46]ACK!
[12:34:46]ATR READ
[12:34:46]COMPLETE!
[12:34:46]
[12:34:46]CF: 31 52 89 01 0e
[12:34:46]ACK!
[12:34:46]ATR READ
[12:34:46]COMPLETE!
[12:34:46]
[12:34:46]CF: 31 52 8a 01 0f
[12:34:46]ACK!
[12:34:46]ATR READ
[12:34:46]COMPLETE!
[12:34:46]
[12:34:46]CF: 31 52 8b 01 10
[12:34:46]ACK!
[12:34:46]ATR READ
[12:34:47]->SIO write 128 bytes
[12:34:47]COMPLETE!
[12:34:47]
[12:34:47]CF: 31 52 8c 01 11
[12:34:47]disk sio_process()
[12:34:47]ACK!
[12:34:47]ATR READ
[12:34:47]COMPLETE!
[12:35:03]
[12:35:03]CF: 31 52 8c 01 11
[12:35:03]disk sio_process()
[12:35:03]ACK!
[12:35:03]ATR READ
[12:35:03]->SIO write 128 bytes
[12:35:03]COMPLETE!
[12:35:03]
[12:35:03]CF: 31 52 8d 01 12
[12:35:03]ACK!
[12:35:03]ATR READ
[12:35:03]COMPLETE!
[12:35:03]
[12:35:03]CF: 31 52 8e 01 13
[12:35:03]ACK!
[12:35:03]ATR READ
[12:35:03]COMPLETE!
[12:35:03]
[12:35:03]CF: 31 52 8f 01 14
[12:35:03]ACK!
[12:35:03]ATR READ
[12:35:03]COMPLETE!
[12:35:03]
[12:35:03]CF: 31 52 90 01 15
[12:35:03]ACK!
[12:35:03]ATR READ
[12:35:03]COMPLETE!
[12:35:03]
[12:35:03]CF: 31 52 91 01 16
[12:35:03]ACK!
[12:35:03]ATR READ
[12:35:03]COMPLETE!
[12:35:03]
[12:35:03]CF: 31 52 92 01 17
[12:35:03]ACK!
[12:35:03]ATR READ
[12:35:03]COMPLETE!
[12:35:03]
[12:35:03]CF: 31 52 93 01 18
[12:35:03]ACK!
[12:35:03]ATR READ
[12:35:03]COMPLETE!
[12:35:03]
[12:35:03]CF: 31 52 94 01 19
[12:35:03]ACK!
[12:35:03]ATR READ
[12:35:03]COMPLETE!
[12:35:03]
[12:35:03]CF: 31 52 95 01 1a
[12:35:03]ACK!
[12:35:03]ATR READ
[12:35:03]COMPLETE!
[12:35:04]
[12:35:04]CF: 31 52 96 01 1b
[12:35:04]disk sio_process()
[12:35:04]ACK!
[12:35:04]ATR READ
[12:35:04]->SIO write 128 bytes
[12:35:04]COMPLETE!
[12:35:04]
[12:35:04]CF: 31 52 97 01 1c
[12:35:04]ACK!
[12:35:04]ATR READ
[12:35:04]COMPLETE!
[12:35:04]
[12:35:04]CF: 31 52 98 01 1d
[12:35:04]ACK!
[12:35:04]ATR READ
[12:35:04]COMPLETE!
[12:35:04]
[12:35:04]CF: 31 52 99 01 1e
[12:35:04]ACK!
[12:35:04]ATR READ
[12:35:04]COMPLETE!
[12:35:20]
[12:35:20]CF: 31 52 99 01 1e
[12:35:20]disk sio_process()
[12:35:20]ACK!
[12:35:20]ATR READ
[12:35:20]->SIO write 128 bytes
[12:35:20]COMPLETE!
[12:35:20]
[12:35:20]CF: 31 52 9a 01 1f
[12:35:20]ACK!
[12:35:20]ATR READ
[12:35:20]COMPLETE!
[12:35:20]
[12:35:20]CF: 31 52 9b 01 20
[12:35:20]ACK!
[12:35:20]ATR READ
[12:35:20]COMPLETE!
[12:35:20]
[12:35:20]CF: 31 52 9c 01 21
[12:35:20]ACK!
[12:35:20]ATR READ
[12:35:20]COMPLETE!
[12:35:20]
[12:35:20]CF: 31 52 9d 01 22
[12:35:20]ACK!
[12:35:20]ATR READ
[12:35:20]COMPLETE!
[12:35:20]
[12:35:20]CF: 31 52 9e 01 23
[12:35:20]ACK!
[12:35:20]ATR READ
[12:35:20]COMPLETE!
[12:35:20]
[12:35:20]CF: 31 52 9f 01 24
[12:35:20]ACK!
[12:35:20]ATR READ
[12:35:20]COMPLETE!
[12:35:20]
[12:35:20]CF: 31 52 a0 01 25
[12:35:21]ACK!
[12:35:21]ATR READ
[12:35:21]->SIO write 128 bytes
[12:35:21]COMPLETE!
[12:35:37]
[12:35:37]CF: 31 52 a0 01 25
[12:35:37]disk sio_process()
[12:35:37]ACK!
[12:35:37]ATR READ
[12:35:37]->SIO write 128 bytes
[12:35:37]COMPLETE!
[12:35:37]
[12:35:37]CF: 31 52 a1 01 26
[12:35:37]ACK!
[12:35:37]ATR READ
[12:35:37]COMPLETE!
[12:35:37]
[12:35:37]CF: 31 52 a2 01 27
[12:35:37]ACK!
[12:35:37]ATR READ
[12:35:37]COMPLETE!
[12:35:37]
[12:35:37]CF: 31 52 a3 01 28
[12:35:37]ACK!
[12:35:37]ATR READ
[12:35:37]COMPLETE!
[12:35:37]
[12:35:37]CF: 31 52 a4 01 29
[12:35:37]ACK!
[12:35:37]ATR READ
[12:35:37]COMPLETE!
[12:35:37]
[12:35:37]CF: 31 52 a5 01 2a
[12:35:37]ACK!
[12:35:37]ATR READ
[12:35:37]COMPLETE!
[12:35:37]
[12:35:37]CF: 31 52 69 01 ed
[12:35:37]ACK!
[12:35:37]ATR READ
[12:35:37]tnfs_lseek currpos=53904, pos=46080, typ=0
[12:35:37]_tnfs_cache_seek current=53904, destination=46080, cache_start=53520, cache_end=54032
[12:35:37]_tnfs_cache_seek outside cached region
[12:35:37]tnfs_lseek success, new pos=46080, response pos=46080
[12:35:37]COMPLETE!
[12:35:37]
[12:35:37]CF: 31 52 6a 01 ee
[12:35:37]ACK!
[12:35:37]ATR READ
[12:35:37]COMPLETE!
[12:35:37]
[12:35:37]CF: 31 52 7e 01 03
[12:35:37]ACK!
[12:35:37]ATR READ
[12:35:37]tnfs_lseek currpos=46464, pos=48128, typ=0
[12:35:37]_tnfs_cache_seek current=46464, destination=48128, cache_start=46080, cache_end=46592
[12:35:37]tnfs_lseek success, new pos=48128, response pos=48128
[12:35:37]tnfs_lseek currpos=48256, pos=48128, typ=0
[12:35:37]_tnfs_cache_seek current=48256, destination=48128, cache_start=48128, cache_end=48640
[12:35:37]_tnfs_cache_seek within cached region
[12:35:37]tnfs_lseek currpos=48128, pos=48784, typ=0
[12:35:37]_tnfs_cache_seek current=48128, destination=48784, cache_start=48128, cache_end=48640
[12:35:37]tnfs_lseek success, new pos=48784, response pos=48784
[12:35:38]->SIO write 128 bytes
[12:35:38]COMPLETE!
[12:35:38]
[12:35:38]CF: 31 52 7f 01 04
[12:35:38]disk sio_process()
[12:35:38]ACK!
[12:35:38]ATR READ
[12:35:38]COMPLETE!
[12:35:38]
[12:35:38]CF: 31 52 80 01 05
[12:35:38]ACK!
[12:35:38]ATR READ
[12:35:38]COMPLETE!
[12:35:38]
[12:35:38]CF: 31 52 81 01 06
[12:35:38]ACK!
[12:35:38]ATR READ
[12:35:38]COMPLETE!
[12:35:38]
[12:35:38]CF: 31 52 82 01 07
[12:35:38]ACK!
[12:35:38]ATR READ
[12:35:38]COMPLETE!
[12:35:38]
[12:35:38]CF: 31 52 83 01 08
[12:35:38]ACK!
[12:35:38]ATR READ
[12:35:38]COMPLETE!
[12:35:38]
[12:35:38]CF: 31 52 84 01 09
[12:35:38]ACK!
[12:35:38]ATR READ
[12:35:38]COMPLETE!
[12:35:38]
[12:35:38]CF: 31 52 85 01 0a
[12:35:38]ACK!
[12:35:38]ATR READ
[12:35:38]COMPLETE!
[12:35:38]
[12:35:38]CF: 31 52 86 01 0b
[12:35:38]ACK!
[12:35:38]ATR READ
[12:35:38]COMPLETE!
[12:35:38]
[12:35:38]CF: 70 dc 00 00 4d
[12:35:38]sioFuji::sio_process() called
[12:35:38]NAK!
[12:35:38]
[12:35:38]NAK!
[12:35:38]
[12:35:38]NAK!
[12:35:38]
[12:35:38]NAK!
[12:35:38]
[12:35:38]NAK!
[12:35:38]
[12:35:38]NAK!
[12:35:38]
[12:35:38]NAK!
[12:35:38]
[12:35:38]NAK!
[12:35:38]
[12:35:38]NAK!
[12:35:38]
[12:35:38]NAK!
[12:35:38]
[12:35:38]NAK!
[12:35:38]
[12:35:38]NAK!
[12:35:38]
[12:35:39]CF: 70 dc 00 00 4d
[12:35:39]sioFuji::sio_process() called
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]CF: 70 dd 00 00 4e
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]CF: 70 db 00 00 4c
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]NAK!
[12:35:39]
[12:35:39]CF: 71 4f 0c 00 cc
[12:35:39]sioNetwork::sio_process 0x4f 'O': 0x0c, 0x00
[12:35:39]sioNetwork::sio_open()
[12:35:39]ACK!
[12:35:39]<-SIO read 256 bytes
[12:35:39]ACK!
[12:35:39]parseURL: N:TCP://api.ipstack.com:80
[12:35:39]parseURL isValidURL: TCP://api.ipstack.com:80
[12:35:39]Open: TCP://api.ipstack.com:80
[12:35:39]HEAP CHECK PASSED sioNetwork::allocate_buffers
[12:35:39]networkProtocolTCP::ctor
[12:35:39]networkProtocolTCP::open api.ipstack.com:80
[12:35:39]Connecting to host  port 80
[12:35:39]Resolving hostname "api.ipstack.com"
[12:35:40]Resoled to address 172.67.73.233
[12:35:40]Connected? 1
[12:35:40]Creating new rateTimer
[12:35:40]JSON::setProtocol()
[12:35:40]COMPLETE!
[12:35:40]CS: 1    PCS: 0
[12:35:40]
[12:35:40]CF: 71 57 af 00 78
[12:35:40]sioNetwork::sio_process 0x57 'W': 0xaf, 0x00
[12:35:40]sioNetwork::sio_write() 175 bytes
[12:35:40]ACK!
[12:35:40]<-SIO read 175 bytes
[12:35:40]ACK!
[12:35:40]TCP write 175 bytes
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]CF: 71 53 00 00 c4
[12:35:40]sioNetwork::sio_process 0x53 'S': 0x00, 0x00
[12:35:40]ACK!
[12:35:40]sioNetwork::sio_status()
[12:35:40]Status bytes: 00 00 01 01
[12:35:40]->SIO write 4 bytes
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]ACK!
[12:35:40]Status bytes: 1e 04 01 01
[12:35:40]COMPLETE!
[12:35:40]
[12:35:40]CF: 71 52 1e 04 e5
[12:35:40]sioNetwork::sio_process 0x52 'R': 0x1e, 0x04
[12:35:40]sioNetwork::sio_read()
[12:35:40]ACK!
[12:35:40]Read 1054 bytes
[12:35:40]TCP read 1054 bytes
[12:35:40]->SIO write 1054 bytes
[12:35:40]COMPLETE!
[12:35:46]
[12:35:46]CF: 71 52 1e 04 e5
[12:35:46]sioNetwork::sio_process 0x52 'R': 0x1e, 0x04
[12:35:46]sioNetwork::sio_read()
[12:35:46]ACK!
[12:35:46]Read 1054 bytes
[12:35:46]TCP read 1054 bytes
[12:35:46]->SIO write 1054 bytes
[12:35:46]ERROR!
[12:35:46]
[12:35:46]CF: 71 53 00 00 c4
[12:35:46]sioNetwork::sio_process 0x53 'S': 0x00, 0x00
[12:35:46]ACK!
[12:35:46]sioNetwork::sio_status()
[12:35:46]Status bytes: 00 00 01 01
[12:35:46]->SIO write 4 bytes
[12:35:46]COMPLETE!
[12:35:46]
[12:35:46]CF: 71 43 00 00 b4
[12:35:46]sioNetwork::sio_process 0x43 'C': 0x00, 0x00
[12:35:46]sioNetwork::sio_close()
[12:35:46]
[12:35:46]ACK!
[12:35:46]closing TCP client
[12:35:46]COMPLETE!
[12:35:46]networkProtocolTCP::dtor
[12:35:48]
[12:35:48]CF: 71 4f 0c 00 cc
[12:35:48]sioNetwork::sio_process 0x4f 'O': 0x0c, 0x00
[12:35:48]sioNetwork::sio_open()
[12:35:48]Deleting existing rateTimer
[12:35:48]ACK!
[12:35:48]<-SIO read 256 bytes
[12:35:48]ACK!
[12:35:48]parseURL: "N:TCP://api.openweathermap.org:80
[12:35:48]parseURL isValidURL: TCP://api.openweathermap.org:80
[12:35:48]Open: TCP://api.openweathermap.org:80
[12:35:48]HEAP CHECK PASSED sioNetwork::allocate_buffers
[12:35:48]networkProtocolTCP::ctor
[12:35:48]networkProtocolTCP::open api.openweathermap.org:80
[12:35:48]Connecting to host  port 80
[12:35:48]Resolving hostname "api.openweathermap.org"
[12:35:49]Resoled to address 192.241.245.161
[12:35:49]Connected? 1
[12:35:49]Creating new rateTimer
[12:35:49]JSON::setProtocol()
[12:35:49]COMPLETE!
[12:35:49]
[12:35:49]CF: 71 57 bd 00 86
[12:35:49]sioNetwork::sio_process 0x57 'W': 0xbd, 0x00
[12:35:49]sioNetwork::sio_write() 189 bytes
[12:35:49]ACK!
[12:35:49]<-SIO read 189 bytes
[12:35:49]ACK!
[12:35:49]TCP write 189 bytes
[12:35:49]COMPLETE!
[12:35:49]
[12:35:49]CF: 71 53 00 00 c4
[12:35:49]sioNetwork::sio_process 0x53 'S': 0x00, 0x00
[12:35:49]ACK!
[12:35:49]sioNetwork::sio_status()
[12:35:49]Status bytes: 00 00 01 01
[12:35:49]->SIO write 4 bytes
[12:35:49]COMPLETE!
[12:35:49]
[12:35:49]ACK!
[12:35:49]COMPLETE!
[12:35:49]
[12:35:49]ACK!
[12:35:49]COMPLETE!
[12:35:49]
[12:35:49]ACK!
[12:35:49]Status bytes: a8 01 01 01
[12:35:49]COMPLETE!
[12:35:49]
[12:35:49]CF: 71 52 a8 01 6d
[12:35:49]sioNetwork::sio_process 0x52 'R': 0xa8, 0x01
[12:35:49]sioNetwork::sio_read()
[12:35:49]ACK!
[12:35:49]Read 424 bytes
[12:35:49]TCP read 424 bytes
[12:35:49]->SIO write 424 bytes
[12:35:49]COMPLETE!
[12:35:49]
[12:35:49]ACK!
[12:35:49]COMPLETE!
[12:35:49]
[12:35:49]CF: 71 43 00 00 b4
[12:35:49]sioNetwork::sio_process 0x43 'C': 0x00, 0x00
[12:35:49]sioNetwork::sio_close()
[12:35:49]
[12:35:49]ACK!
[12:35:49]closing TCP client
[12:35:49]COMPLETE!
[12:35:49]networkProtocolTCP::dtor
[12:48:30]
[12:48:30]CF: 71 4f 0c 00 cc
[12:48:30]sioNetwork::sio_process 0x4f 'O': 0x0c, 0x00
[12:48:30]sioNetwork::sio_open()
[12:48:30]Deleting existing rateTimer
[12:48:30]ACK!
[12:48:30]<-SIO read 256 bytes
[12:48:30]ACK!
[12:48:30]parseURL: "N:TCP://api.openweathermap.org:80
[12:48:30]parseURL isValidURL: TCP://api.openweathermap.org:80
[12:48:30]Open: TCP://api.openweathermap.org:80
[12:48:30]HEAP CHECK PASSED sioNetwork::allocate_buffers
[12:48:30]networkProtocolTCP::ctor
[12:48:30]networkProtocolTCP::open api.openweathermap.org:80
[12:48:30]Connecting to host  port 80
[12:48:30]Resolving hostname "api.openweathermap.org"
[12:48:30]Resoled to address 192.241.245.161
[12:48:30]Connected? 1
[12:48:30]Creating new rateTimer
[12:48:30]JSON::setProtocol()
[12:48:30]COMPLETE!
[12:48:30]
[12:48:30]CF: 71 57 bf 00 88
[12:48:30]sioNetwork::sio_process 0x57 'W': 0xbf, 0x00
[12:48:30]sioNetwork::sio_write() 191 bytes
[12:48:30]ACK!
[12:48:30]<-SIO read 191 bytes
[12:48:30]ACK!
[12:48:30]TCP write 191 bytes
[12:48:30]COMPLETE!
[12:48:30]
[12:48:30]CF: 71 53 00 00 c4
[12:48:30]sioNetwork::sio_process 0x53 'S': 0x00, 0x00
[12:48:30]ACK!
[12:48:30]sioNetwork::sio_status()
[12:48:30]Status bytes: 00 00 01 01
[12:48:30]->SIO write 4 bytes
[12:48:30]COMPLETE!
[12:48:30]
[12:48:30]ACK!
[12:48:30]COMPLETE!
[12:48:30]
[12:48:30]ACK!
[12:48:30]COMPLETE!
[12:48:30]
[12:48:30]ACK!
[12:48:30]Status bytes: aa 01 01 01
[12:48:30]COMPLETE!
[12:48:30]
[12:48:30]CF: 71 52 aa 01 6f
[12:48:30]sioNetwork::sio_process 0x52 'R': 0xaa, 0x01
[12:48:30]sioNetwork::sio_read()
[12:48:30]ACK!
[12:48:30]Read 426 bytes
[12:48:30]TCP read 426 bytes
[12:48:30]->SIO write 426 bytes
[12:48:30]COMPLETE!
[12:48:30]
[12:48:30]ACK!
[12:48:30]COMPLETE!
[12:48:30]
[12:48:30]CF: 71 43 00 00 b4
[12:48:30]sioNetwork::sio_process 0x43 'C': 0x00, 0x00
[12:48:30]sioNetwork::sio_close()
[12:48:30]
[12:48:30]ACK!
[12:48:30]closing TCP client
[12:48:30]COMPLETE!
[12:48:30]networkProtocolTCP::dtor
Good grief!  Sorry, that last post was incredibly long.  What can I do to make it shorter next time?
Hello SS
You can hide the code using the spoiler option.  It's the "eye" icon, to the left of the smiley icon.
Spoiler
Peekaboo!
Sincerely
Mathy
Edited by Mathy
I figured out where the WiFi interference is coming from more precisely: It's the area right around the DVI port, where the cable is plugged in. I enlarged the hole so that the cable can be more fully inserted into the port, and that helped a little. However, if I place a piece of metal above the connection, it almost completely eliminates the interference. (See photos.)
I think if I make some sort of metal cowl to shield the DVI port, it should fix the issue.
before.thumb.jpeg.edab89b08fc3669478bc7bf90d77dcbf.jpegafter.thumb.jpeg.b583aae11bd08f14fb08c07df2e041bb.jpeg
As someone who has 2 Sophia 2's on order this somewhat concerns me.  Maybe it won't be as bad on the Sophia 2.  I'm using an XEGS so I could come of the side rather than the back, but still...hopefully people smarter than me chime in with better solutions....
Just to follow up, placing a piece of metal around the DVI port isn't as effective as it seemed at first. Sometimes I still get interference. Fortunately, moving the FujiNet further away with an SIO cable does seem to be 100% effective, if not 100% elegant.
