MHaensel
Connect a modern computer to a Radio Shack/TRS-80 printer?
I don't have a retro TRS-80 printer yet, but one is in my future, either a daisy wheel or a dot matrix (Line Printer or DMP). I'd like to connect it to my 2020-era laptop. It would be fun to output from a modern computer to one of these heavy-duty beasts.
A USB->Centronics adapter gets me most of the way there. Do I need a card edge adapter or something for early printers, or were they standard Centronics ports?
Edited by MHaensel
Added "it would be fun"
I believe that they all used Centronic based connectors. Card edge would usually be for the computer. Like the TRS-80 Model I/III/4 for example. Some Dot Matrix Printers and Daisy Wheel printers used both Parallel/Serial connections. Okidata still sells DMP printers today. Although, you will have to look at their website and see how they connect to modern PCs. I have a DMP-130A printer for my CoCo. However, I have never attempted to connect it to my Windows based laptop. If you have a printer in mind, you probably can find the manual to it at https://archive.org
Would the absence of driver software be an issue? If memory serves, there is a "generic" printer driver under Windows, but that may just support basic text printing -- no fonts, bold, underlining, or other features of the printer.
You just need to find DOS software to use it. Nothing much could be done from Windows. I mean, it will print the text from Notepad or something, but nothing much beyond that.
Windows XP still had drivers that supported my Star NX 1000 which was made in the 80s. It printed out everything from tax forms to web pages nicely.
I bet it's doable if you find a printer that has Epson or IBM compatible modes. Most from mid 80s supported both and were selectable with dip switches.
Yes, this could be a major issue.  The OEM's of many of the TRS-80 line of printers were not all the same if memory serves.  You may have to try many different printer drivers to even find some basic compatibility.  Good luck!
If I recall correctly, IBM made some mistake when implementing their first Centronics interface, so there is a slight difference with the "original" spec, which became the only way it was done afterward. So watch out for that.
