Materion #1 Posted November 27, 2020 Hello, Anyone have scheme to make S-Video cable to Atari 65XE ? It would have S-Video plug + 2xchinch for audio. Thanks in advance ! :). Quote Share this post Link to post Share on other sites
fenrock #2 Posted November 27, 2020 (edited) This? http://www.hardwarebook.info/Atari_8-bit_S-Video Also this post: And this article: https://www.atarimax.com/freenet/freenet_material/5.8-BitComputersSupportArea/8.TipsandTricks/showarticle.php?48 You can buy a ready made cable from https://www.8bitclassics.com/product/atari-xlxe-5-pin-din-to-s-video-composite-av-cable/ I don't know if the Chroma is connected to the video output port on the 65XE. It wasn't on my 800XL, which I needed to connect when installing the UAV Edited November 27, 2020 by fenrock Chroma! not Luma Quote Share this post Link to post Share on other sites
TGB1718 #3 Posted November 27, 2020 Here's one I made earlier Out of an old S-Video lead and Audio Lead. Most important if you make your own is SHIELDING, failure to have a decent shield will drastically affect the video signal Quote Share this post Link to post Share on other sites
xrbrevin #4 Posted November 27, 2020 (edited) 1 hour ago, fenrock said: I don't know if the Chroma is connected to the video output port on the 65XE XE's do have fully connected SVideo as standard (except XEGS) but is worth doing some minor internal component mods to further improve the image quality. I like the "Ultravideo XE S-Video mod" Here is an image of the monitor pinout: Edited November 27, 2020 by xrbrevin image Quote Share this post Link to post Share on other sites
Materion #5 Posted December 2, 2020 (edited) Hello, in these schematics its the ports in computer/TV? Or its cable plugs in these schematics ? http://www.hardwarebook.info/Atari_8-bit_S-Video Edited December 2, 2020 by Materion Quote Share this post Link to post Share on other sites
MrFish #6 Posted December 2, 2020 It's the cable plugs. See where it says "male" on both of them? S-Vid and Atari Video DIN cable plugs are both male. Quote Share this post Link to post Share on other sites
MrFish #7 Posted December 2, 2020 You can also figure it out by comparing the DIN pinout on that page with the computer video connector pinout above; they're opposites. Quote Share this post Link to post Share on other sites
BillC #8 Posted December 2, 2020 13 hours ago, Materion said: Hello, in these schematics its the ports in computer/TV? Or its cable plugs in these schematics ? http://www.hardwarebook.info/Atari_8-bit_S-Video You can tell if you look at the pin order, the pin numbers on male/female connectors are reversed so they match when plugged into each other. Quote Share this post Link to post Share on other sites
svhovater #9 Posted December 3, 2020 I can vouch for the cable from 8bit classics - good heavy duty quality cable. Quote Share this post Link to post Share on other sites
