wietze
Ti99/4a + 32kb rom + FinalGrom99 = Lot of Blue screens (hardware failure?)?
4 hours ago, wietze said:
Asmusr pointed me out in PM that I have a TMS9929NL chip, which is lacking the `A'. Which in turn implies it does not have support for the bitmap mode.
I hope that I can just replace the TMS9929NL chip with a TMS9929ANL chip then!
If you don't have a spare lying around, PM me with your address (assuming you are in the U.S.) and I'll mail the used one I pulled out of my system a few years back... if you don't mind having to straighten a few bent pins.
1 hour ago, atrax27407 said:
A TMS9918ANL is NOT a replacement for a TMS9929ANL.
Crap, obviously I wasn't thinking.  29 is not 18... DUH!  Well, they say Senior Moments are not bad... unless they all run together.
On 12/7/2020 at 10:53 AM, wietze said:
Just opened her up, and it seems to have a TMS9929NL vdp chip.
I currently connect the machine to the display using a `Texas Instruments TV PAL Encoder PHA 2030'.
Could the use of a PAL vdp chip cause the abovementioned graphical behaviour with some programs?
(Edit: some thread in this forum suggests that all cartridges encountered are PAL/NTSC compatible; so I assume answer is `no').
How come there is a wrong VDP inside your console? The non-A variant should only be in the TI-99/4, I should have expected.
No idea, this is how I got it.
I replaced the (non-A) VDP with a TMS9929ANL. And now the machine displays bitmap graphics.
Awesome! This resolves the issue I had. Now I can play all the nice TI games to my delight!
Thank you for the help.
