Fierodoug5 Posted December 31, 2020 Share Posted December 31, 2020 Thanx! I will try this after work on Thurs Link to comment Share on other sites More sharing options...
Fierodoug5 Posted January 1, 2021 Share Posted January 1, 2021 This is what I get everytime. There is no time between busy p....and ok. It goes right to ok AT+CIPMUX=0 OK AT+CIPMUX=0 AT+CIPSTART="TCP","pluscart.firmaplus.de",80 busy p... OK AT+CIPCLOSE ERROR Link to comment Share on other sites More sharing options...
Fierodoug5 Posted January 1, 2021 Share Posted January 1, 2021 here is my connection info AT+CWJAP? +CWJAP:"DougBethinternet","9c:34:26:96:65:ba",6,-47,0 Link to comment Share on other sites More sharing options...
+Andrew Davie Posted January 1, 2021 Share Posted January 1, 2021 22 minutes ago, Fierodoug5 said: here is my connection info AT+CWJAP? +CWJAP:"DougBethinternet","9c:34:26:96:65:ba",6,-47,0 Just as an aside-question.... does your WiFi password include any characters on the PlusCart keyboard line containing the "/" character? There's just been a bug found in the handling of those "keys". Link to comment Share on other sites More sharing options...
Fierodoug5 Posted January 1, 2021 Share Posted January 1, 2021 No, its all letters and numbers. No characters. Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 1, 2021 Author Share Posted January 1, 2021 (edited) 1 hour ago, Fierodoug5 said: This is what I get everytime. There is no time between busy p....and ok. It goes right to ok AT+CIPMUX=0 OK AT+CIPMUX=0 AT+CIPSTART="TCP","pluscart.firmaplus.de",80 busy p... OK AT+CIPCLOSE ERROR after you pressed the "AT+CIPMUX=0" button you have to wait for the OK messages before starting the connection. Thats why the ESP is responding with "busy processing" And you have to press this button only once, to set the ESP in single connection mode. Edited January 1, 2021 by Al_Nafuur Link to comment Share on other sites More sharing options...
Fierodoug5 Posted January 1, 2021 Share Posted January 1, 2021 I am only hitting it once and waiting for the ok. The second AT+Cipmux=0 is doing it by itself when I hit start connection Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 1, 2021 Author Share Posted January 1, 2021 11 minutes ago, Fierodoug5 said: I am only hitting it once and waiting for the ok. The second AT+Cipmux=0 is doing it by itself when I hit start connection ? that's strang, but if the ESPlorer is sending both commands at once the ESp8266 will respond with "busy p..." Link to comment Share on other sites More sharing options...
Fierodoug5 Posted January 1, 2021 Share Posted January 1, 2021 yup, all I hit is the start connection button, and this is what I get OK AT+CIPMUX=0 AT+CIPSTART="TCP","pluscart.firmaplus.de",80 busy p... OK Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 1, 2021 Author Share Posted January 1, 2021 (edited) We just want to check the connection time, so we could use the multi connection mode of ESP8266 too so: press the "AT+CIPMUX=1" button and set the switch to "AT+CIPMUX=1 Multiple" and the try the connection button.. Edited January 1, 2021 by Al_Nafuur Link to comment Share on other sites More sharing options...
Fierodoug5 Posted January 1, 2021 Share Posted January 1, 2021 Same problem.... OK AT+CIPMUX=1 OK AT+CIPMUX=1 AT+CIPSTART=0,"TCP","pluscart.firmaplus.de",80 busy p... OK Link to comment Share on other sites More sharing options...
Fierodoug5 Posted January 1, 2021 Share Posted January 1, 2021 Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 1, 2021 Author Share Posted January 1, 2021 you can copy and paste the : AT+CIPSTART=0,"TCP","pluscart.firmaplus.de",80 to the input field at the lower right of the ESPlorer and press the send button (make sure the "CR" and "LF" checkboxes at the top right are set) Link to comment Share on other sites More sharing options...
Fierodoug5 Posted January 1, 2021 Share Posted January 1, 2021 AT+CIPSEND=0,48 AT+CIPSTART=0,"TCP","pluscart.firmaplus.de",80 busy p... busy p... busy p... link is not valid ERROR Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 1, 2021 Author Share Posted January 1, 2021 Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 1, 2021 Author Share Posted January 1, 2021 the other lower right ? Link to comment Share on other sites More sharing options...
Fierodoug5 Posted January 1, 2021 Share Posted January 1, 2021 oops Link to comment Share on other sites More sharing options...
Fierodoug5 Posted January 1, 2021 Share Posted January 1, 2021 OK AT+CIPSTART=0,"TCP","pluscart.firmaplus.de",80 AT+CIPSTART=0,"TCP","pluscart.firmaplus.de",80 Link type ERROR ERROR Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 1, 2021 Author Share Posted January 1, 2021 press the "AT+CIPMUX=1" button on the TCP/IP tab before sending the "AT+CIPSTART=0,"TCP","pluscart.firmaplus.de",80" request. or use the single connection mode "AT+CIPMUX=0" button and the send without the connection ID parameter: AT+CIPSTART="TCP","pluscart.firmaplus.de",80 from the input field in the lower right.. Link to comment Share on other sites More sharing options...
Fierodoug5 Posted January 1, 2021 Share Posted January 1, 2021 AT+CIPSTART="TCP","pluscart.firmaplus.de",80 AT+CIPSTART="TCP","pluscart.firmaplus.de",80 AT+CIPMUX=1 busy p... CONNECT OK CLOSED Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 1, 2021 Author Share Posted January 1, 2021 how long did it take until the "CONNECT" appeared? don't use any buttons on the left side except the "AT+CIPMUX=0" before you send the connection request with the input field on the right. Link to comment Share on other sites More sharing options...
Fierodoug5 Posted January 1, 2021 Share Posted January 1, 2021 under a second Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 1, 2021 Author Share Posted January 1, 2021 (edited) deleted Edited January 1, 2021 by Al_Nafuur Link to comment Share on other sites More sharing options...
Fierodoug5 Posted January 1, 2021 Share Posted January 1, 2021 I only hit AT+CIPMUX=0 then SEND Link to comment Share on other sites More sharing options...
Fierodoug5 Posted January 1, 2021 Share Posted January 1, 2021 Have to get to bed for work in the morning, thanx for the help so far! Link to comment Share on other sites More sharing options...
