Larry
OS Checksum re-calculator?
Is there a utility to re-calculate (and insert in the OS file) a new checksum after making changes?  (The question about moving the left margin got me to think about this.)  A BASIC tool would be really nice.
Let me add a twist to the original question:
How are the Atari rom checksums calculated?
Are the checksum bytes themselves included in the calculated checksums?
Edit: I was evidently interested in this about 10 years ago, so there is an earlier thread about this topic. Here is that thread:
Yes, probably is, but I'd like to understand it.
But since you mention removing the validity check, can someone show the bytes to replace?
If you want to learn about checksums, you could look at this tool. It does a whole bunch of them...
http://rehash.sourceforge.net/
It might be that if you run it against the OS ROM (-checksum) one of them will match.
Though pretty sure someone here probably knows the actual function offhand and its simple.
You'd want to retain the checksum (validation from within the OS doesn't much matter) because there's still that odd bit of software (mainly Electronic Arts?) that does it's own validation (though possibly it just checks against hardcoded values for the 400/800 only)
But then you'd have to endure red ROM bars in the XL self test.... :dunce:
For those few titles I'd just temporarily switch back to the stock OS.
kr0tki about the algorithm, used by 400/800 OS:
A tool by HiassofT to set the checksum in XL OSs:
I "poached" this link from the Zero Left Margin? thread. Has some good info for here too.
Not Basic, but here is a C source which does that:
checksum.c
  • Like 4
Thanks. I probably can read the source code and figure out what it's doing, but do you by chance also have a compiled version in Atari format?  I haven't dabbled with C for probably 30 years.
Larry why not go with the link that @DjayBee provided to the @HiassofT solution. I've used it under Linux with a virtual XP OS and it does the trick, no fuss no muss ;-) . Should work with most any Windows system, and probably also with Wine.
Posted (edited)
My Atari ROM Checker download has been enhanced with and the "Atari ROM Patcher" tool to display, compute and fix OS checks sums for Atari XL/XE computers. It can also be used to swap the floating-poing package. The tool is written in Atari BASIC and starts automatically when the disk is booted. Also, typos and swapped columns in the documentation have been fixed. Also, the disk images are now single density, so they also work on Atari 810.
EDIT: Fixed incorrect TRAP that would skip loading the FP ROM in case you enter a wrong file name.
Edited by JAC!
  • Like 7
