atarimac #1 Posted January 8 New Features (in version 5.5.0): Added support for the PCLINK host disk system, providing a working alternative to H: for SpartaDOSX. Added enhanced copy and paste, so that ATASCII graphics characters may be copied and pasted as well, along with support for automation with delays. Added ability to specify a string that is pasted automatically at the startup of the emulator. Added Break key to Touch Bar, and removed Power key. The funtionality of the Power key is now achieved by pressing Shift along with the Reset Touch Bar key. Bug Fixes (in version 5.5.0): Fixed copy of text in Full Screen Fixed copy of text in 80 column modes You can get the release here: https://github.com/atarimacosx/Atari800MacX/releases or http://atarimac.com/downloads.php . Note, for PCLink to work, you need to have the PCLINK.SYS driver available on the SpartDosX Toolkit disk. PCLINK use is documented under the Preferences->Hard Drives Tab section in the built in help. The Copy and Paste is documented under the Copy and Paste topic in the built in online help. 12 Quote Share this post Link to post Share on other sites
Dinadan67 #2 Posted January 8 great progress, thanks! Quote Share this post Link to post Share on other sites
atarimac #3 Posted January 8 I just released an updated version 5.5.1 which has a very small fix for the correct SIDE2 hard disk mounting (RAW or VHD) based on the image name. (.vhd and .img are mounted as VHD, anything else is mounted as RAW, along with images named .vhd or .img which fails to mount as a VHD image). 1 1 Quote Share this post Link to post Share on other sites
