Sohl #126 Posted June 1, 2021 23 hours ago, Thomas Jentzsch said: Then I am pretty sure this is a driver problem and there is not much we can do. You can try the Software renderer. @Thomas Jentzsch OK, thanks again. I'll try it that way too. I can live with the zoom glitch easier than the unexpected aborts, but maybe the software rendering will be more robust even if less efficient. Quote Share this post Link to post Share on other sites
+littaum #127 Posted June 23, 2021 A question on Stella's very neat "Turbo" mode. According to the changelog, when it was introduced it was described as: Added 'Turbo' mode, runs the game as fast as the computer allows. When I enable it, it says "2000% speed" on both my desktop (older Haswell Intel CPU) and my wife's laptop (a more recent Intel chip). When testing out my game (I run many games to test my AI on its effectiveness) on both systems I do notice that the average FPS in developer mode is around 1000 FPS on my PC and 1100 FPS on my wife's laptop. Is it safe to assume that "2000%" just means turbo mode, and I should be looking at the average frame rate as the true metric of how fast the game is being run? Below is an example of what I am talking about: Quote Share this post Link to post Share on other sites
Thomas Jentzsch #128 Posted June 23, 2021 (edited) Correct. The 2000% are the upper speed limit which is enabled with Turbo mode. In your example, your computer is not fast enough to reach the upper limit and therefore only the framerate speaks the truth. BTW: We can increase the upper Turbo limit any time, but 20x faster seems like a good value. Else it might become too fast on really fast computers. Edited June 23, 2021 by Thomas Jentzsch Quote Share this post Link to post Share on other sites
+atari2600land #129 Posted July 1, 2021 OK, this is stupid. I'm working on a game involving pressing and holding the fire button. When I play it on my 2600 using a Harmony cart and hold the fire button it works fine. But if I do the same thing on Stella, after about a second or so, it acts like the fire button has been depressed even though I'm still pressing space. What is going on here? Quote Share this post Link to post Share on other sites
+atari2600land #130 Posted July 1, 2021 I forgot to mention it was working fine a couple days earlier but now it isn't. Quote Share this post Link to post Share on other sites
Thomas Jentzsch #131 Posted July 1, 2021 I suppose your OS is interfering here. Windows' Ease of Access maybe? Quote Share this post Link to post Share on other sites
Keatah #132 Posted July 1, 2021 Keyboard repeat and repeat rate. 1 Quote Share this post Link to post Share on other sites
DeafAtariFromKansas #133 Posted July 1, 2021 7 minutes ago, Keatah said: Keyboard repeat and repeat rate. Exactly!.... Quote Share this post Link to post Share on other sites
+atari2600land #134 Posted July 1, 2021 But why would it change Ease of Access stuff even when I told it not to? I fiddled around with various settings and it still does the same thing. Quote Share this post Link to post Share on other sites
Thomas Jentzsch #135 Posted July 1, 2021 I suppose you have tested other games and they do the same? Quote Share this post Link to post Share on other sites
+atari2600land #136 Posted July 1, 2021 Great. Now Stella isn't working at all. I suppose I'll reset my computer. Quote Share this post Link to post Share on other sites
Keatah #137 Posted July 1, 2021 FilterKeys? Maybe Typematic rate in BIOS? Or, maybe the Autofire rate in Stella itself? Quote Share this post Link to post Share on other sites
+atari2600land #138 Posted July 1, 2021 I reset my computer and Stella works again, but I still have the same problem. I reset everything to original settings, too. Quote Share this post Link to post Share on other sites
+johnnywc #139 Posted July 1, 2021 19 minutes ago, atari2600land said: I reset my computer and Stella works again, but I still have the same problem. I reset everything to original settings, too. I've seen this before; for me it was because the Auto-fire rate in Stella was set to something other than 'off': Hope that helps! Quote Share this post Link to post Share on other sites
+atari2600land #140 Posted July 1, 2021 It wasn't set to off. I set it to off. It works now. Thanks! 2 Quote Share this post Link to post Share on other sites
+johnnywc #141 Posted July 1, 2021 1 minute ago, atari2600land said: It wasn't set to off. I set it to off. It works now. Thanks! FYI I also had an issue where "Allow all 4 directions on joystick" was set and it was causing a bug in RobotWar since I wasn't handling left+right at the same time. Quote Share this post Link to post Share on other sites
Keatah #142 Posted July 1, 2021 I wonder how that setting magically changed on its own?? Quote Share this post Link to post Share on other sites
Rodney Hester #143 Posted July 7, 2021 I've found a rather fascinating but harmless bug that only seems to affect the R77 build. The "items found" count on the main games path is one less than the number of games actually present/listed. It's not that any are 'missing', if you hand count them, it's always 1 higher than the count displayed in the upper right. This doesn't happen on the Windows build, at least. In the interest of bug-chasing, I've attached the exact contents of my games directory. stella_653_count_bug.zip Quote Share this post Link to post Share on other sites
Thomas Jentzsch #144 Posted July 7, 2021 Probably it is counting the current directory too. Quote Share this post Link to post Share on other sites
Rodney Hester #145 Posted July 7, 2021 6 hours ago, Thomas Jentzsch said: Probably it is counting the current directory too. No, it's the other way 'round...I just tested the R77 with just a single ROM in the games directory, and sure enough, it says "0 items found". *laughs* What's more strange to me is that it's inconsistent between platforms - Windows reports "1 items found". I'm not sure what the Mac version says. Quote Share this post Link to post Share on other sites
Thomas Jentzsch #146 Posted July 7, 2021 15 minutes ago, Rodney Hester said: No, it's the other way 'round...I just tested the R77 with just a single ROM in the games directory, and sure enough, it says "0 items found". *laughs* Ha, then it probably subtracts the current dir. Which doesn't exist for R77. Quote Share this post Link to post Share on other sites
hizzy #147 Posted July 13, 2021 Is it possible to set up your computer to boot directly into stella? I have an old machine that I would like to make into my Stella Station. Thanks! Quote Share this post Link to post Share on other sites
+fdr4prez #148 Posted July 13, 2021 3 hours ago, hizzy said: Is it possible to set up your computer to boot directly into stella? I have an old machine that I would like to make into my Stella Station. Thanks! Put a shortcut into your Startup folder Quote Share this post Link to post Share on other sites
TheHoboInYourRoom #149 Posted July 20, 2021 On Fedora Workstation 34, x86_64: I'm trying to install 6.5.3 with the RPM archive from the github.io site, but this is the response I get: Quote [[email protected]<redacted> Downloads]$ sudo dnf install ./stella-6.5.3-2.x86_64.rpm [sudo] password for evie: Last metadata expiration check: 5:15:05 ago on Tue 20 Jul 2021 09:08:15 AM CDT. Dependencies resolved. ================================================================================ Package Architecture Version Repository Size ================================================================================ Installing: stella x86_64 6.5.3-2 @commandline 3.1 M Transaction Summary ================================================================================ Install 1 Package Total size: 3.1 M Installed size: 9.2 M Is this ok [y/N]: y Downloading Packages: Running transaction check Transaction check succeeded. Running transaction test Error: Transaction test error: file /usr/bin from install of stella-6.5.3-2.x86_64 conflicts with file from package filesystem-3.14-5.fc34.x86_64 I'm not familiar with the RPM packaging process, so I don't know how minor the issue might be. Quote Share this post Link to post Share on other sites
Capt Moore #150 Posted July 26, 2021 I just got a raspberry pi 4 to try and make a RetroPie/Stella system, but as far as I can tell, the only version of stella is 6.0.1? Is there an easy way of getting the latest version into RetroPie, or do I need to attack this via another method such as using the raspberry pi os and settings some kind of autorun command? Quote Share this post Link to post Share on other sites
