Al_Nafuur
Common code base with UnoCart
Works Perfect!
First tried with 2 pages of roms. Back and forth pages fine, Exit back to main menu no problem
Then I copied my UnoCart to the Pluscart SD card. Multiple folders full of roms. Also no issues, worked Perfect!
Thanx! Will let you know if any issues pop up during further testing
1 minute ago, Fierodoug5 said:
It ain't pretty, but at least I don't have to open the case to use the cube programmer.
Great, now you don't have to open the case which was specifically designed to be opened.
  • Haha 1
lol. Its just for this test cart, I was opening that thing like everyday.
I have plenty of clean pretty ones!
Edited by Fierodoug5
I have visions of cutting a hole in a Van Gogh painting to get easier access to the hook on the wall...
because I was hanging that thing everyday 😜
  • Haha 1
9 minutes ago, Andrew Davie said:
I was trying to test this but don't seem to have a MacOS tool to convert the .elf to .bin.
Could you possibly post a .bin for me?
My initial attempt seems to have been correct - just program the .elf file direct via STM32Programmer.
I have a working PlusCart Duo - however the SD still locks up when I go to page 2 and back again.
On 2/18/2021 at 3:57 AM, Fierodoug5 said:
It still doesn't work even with that latest firmware? That fixed my sd browser
Have just double-checked. Does not work with my PlusCart/SD combo.
12 minutes ago, Fierodoug5 said:
That's weird. That firmware fixed mine. I have multiple files and pages of roms. All works as expected
Yes it doesn't make much sense. I downloaded/burned the latest ".elf" file several times.
I can go to page 2, but any attempt to go back to page 1, or onward to page 3... lockup.
I will check once again tomorrow. If only there was a unique version # on the status/info page, I could verify that way.
I'm assuming there isn't, but I will check that tomorrow too.
The New Pluscart(SD) boards that Andrew made are a success and fully working, I ran it through lots of tests tonight using the PlusCart Duo.elf that Al_Nafuur posted in post #100
All seems to be working 100%
Is there a UNOCart 2600 file that can be flashed to this STM32 board to check if we got the GPIO pins right for unocart?
There has to be, because I checked/ran the common code base (i.e., PlusCart look/feel) on my own UnoCart.
Found it...
Post
Found it...
Post
This is the the v2.0.0 version. I'll build and post the v2.0.10 draft version today.
the original UnoCart firmware should work on this hardware too:
https://github.com/DirtyHairy/UnoCart-2600/releases
(flash the firmware.bin file to start address 0x08000000)
Posted (edited)
@Fierodoug5
These builds (v2.0.12) include:
  • update STM32CubeIDE to v1.6.0
  • reset RIOT at start and after exit emulation
  • exit input fields properly
  • more generic keyboard
  • clean up status messages
  • always escape spaces in API HTTP requests
  • @Andrew Davie's fix for menu delays (init and joystick up/down)
  •  a basic row of space/punctuation on the alpha keyboards
  • Bugfix eeprom addressing
PlusCart Duo.bin PlusCart Duo.elf UnoCart.bin UnoCart.elf
Edited by Al_Nafuur
All working well so far on 2.0.14 on Pluscart and PluscartSD. Was able to connect to WiFi with keyboard entry, downloaded offline roms no problem.
When we merge the new reunion branch to the master branch, we need a new name (and Readme) for the GITproject and for the STM32CubIDE project too.
Currently the GIT Project is named "Atari 2600 PlusCart", this will not be sufficient if a firmware for the UnoCart and other variants can be build with the code. The STM32CubeIDE Project is named "PlusCart" which is also not sufficient, when the build directories in the project are then named "PlusCart", "PlusCart Zero", "UnoCart", "UnoCart Zero",...
The problem is, I have no idea for a new name and renaming a GIT project and a Eclipse project is a nasty thing.
So how shall we name a project for the common code-base/build-environment for all the UnoCart, PlusCart and variants. Any suggestions?
I would name the project after what all variations have in common (e.g. multi-cart, for the same consoles, using the same CPU...). Or make up a completely unrelated name which could describe the unified character (e.g. "Trinity").
Posted (edited)
"Trinity" sounds good. I also thought of "Pandora", "Hydra", "Double-edge" or "Multi-edge" but have no idea how to bring that in relation to Atari, VCS, 2600 and the code base of MultiCarts
Edited by Al_Nafuur
