atari-passion
Atari 64K Memory Card (Atari 64KMR) for 1090 xl expansion system
hi,
  I am glad you found my git page. I was going to ask you to have a look until I saw your latest post.
  very nice looking boards. I have just ordered  some myself last Thursday and waiting for them to come in. Along with the 1090xl MB as well. cant wait to get these tested. I really do hope they work. the boards were done as close as I could get them as I have no original 1090 hardware here. I would really like to know your results.
thanks!
Ken
26 minutes ago, kenames99 said:
hi,
thanks!
Ken
Hello,
Some silkscreened details are missing on the PCB, for the switch and for the card selector as well as for the card edge connector.
Attention on your diagram you put that c1 a value of 0.1uF while atari indicates a value of 0.22 uF
Also for the resistors a slightly larger spacing would have been desirable.
Arnaud
Wow. Maybe get one or more for my 1090xl. It has no cards at all. All metal back plains are in tho only 1 can have a card mounted. Are you going to look into the metal part one day?
What about the 50? pin header? It is for the Z80 card. Wounder if Atari did CP/M Bios for it?
James
[Wow, (possibly) a second chance to be pedantic in one night!]
<little mr. pedant>
Are you confusing backplane with card cage? The backplane is the board that receives the edge connectors on the cards. The card cage is the metal (in this case) frame that the cards are mounted to, and that holds them in place from moving.
</little mr. pedant>
Edited by MrFish
  • Haha 1
3 minutes ago, sup8pdct said:
Alright, Card cage then.......
Alright, no real problem. I just wasn't quite sure what you meant... and don't take my sarcasm too seriously; I'm just a little goofy here before crashing at 4:00a after work...
Owning a 1090, alone, gives you partial license to call the parts whatever you want. ;)
  • Haha 1
I have had several alcoholic beverages due to it being evening here and am winding down due to a hard ?!? days work.
Also an Aussie so can see when someone is taking the piss :D
I have no top cover either. Makes a very bare 1090.
James
6 hours ago, sup8pdct said:
I have had several alcoholic beverages...
I envy that too, as I have none available at the moment.
Eh, it just makes it look more "techie" without the cover.
Just bolstering my inflated sense of self-importance a bit. :D
James
hi,
  I was doing the electronic parts and Curt was doing the chassis/metal parts. I have no idea where he was looking or how far he got. I even have no clue how to start shopping for chassis parts. any suggestions welcome.
Ken
20 hours ago, atari-passion said:
Hello,
Arnaud
hi atari-passion,
  I have done these updates with the exception of resistor spacing. I looked at your photos and the spacing between resistors looks ok, unless you are talking about spacing between leads at ends of resistors which does seem a bit short.
  I have not regenerated the gerber files yet, waiting for you to confirm my resistor conclusions. thank you for your input. it is always welcome and appreciated.
Ken
Hello,
yes the problem is spacing between leads at ends of resistors which does seem a bit short.
there is also another small problem, the resistor "R2"  which seems a little too close to the switch, depending on the model used .
Edited by atari-passion
hi,
  also, U17 is listed as 74LS51 but should be 74S51 according to original schematic. I have updated the github schematic but have not pushed it yet. give me a few minutes yet for that.
Ken
James
hi James,
  do you have any of the plug in cards for your 1090? if so, any hires photos you can provide would be a very large help to me. thank you in advance and thank you also for your help in the past.
Ken
6 hours ago, kenames99 said:
hi James,
Ken
No. A very empty space waiting for some cards ;)
James
Maybe the resistors were intended to be installed vertically, Atari did that in some devices.
indeed - lets face it, the 1090 is hardly a low profile device..!
hello,
I have just tested the card that I have reproduced.
With an atari 600xl, if the switch is on position 1064, I have 64 kb and the games seem to be working fine.
On the other hand, if I use it with an 800xl with Bank mode selected on the card, no diagnostic software can see the additional memory.
I would like to point out that for some components I use 74ls03 74ls09 and 74ls20 and 74ls51 instead of version 74s03, 74s09, 74s20, 74s51 and for the memory of mt4264-15 instead of 4164 chip.
Is there an electronic problem on the card that prevents recognition of the extra memory on an 800xl ???
Or do you need a special program to use it?
Here are some pictures during my test with a 600xl pal computer.
  • Like 5
hi,
  that is really good to hear that it basically works. as far as modes and how it works past what you have tested, I do not know. I will have to go read the manual for it. I know there is a mode switch but there is also a jumper toward middle of board. but your success with basic 64k makes me very happy that I got the layout mostly or fully correct.
thank you for this info.
Ken
hi everyone,
  just a quick update, I have mostly assembled a 1090xl board and am happy to report it works, at least as far as I have tested. all power rails are proper voltage. leds light up. so things look good so far. there are numerous fixes I have applied to the board since these were made. enjoy.
Ken
  • Like 8
1 hour ago, kenames99 said:
hi everyone,
Ken
I look at your photo and realize that on my 1090xl proto, I don't have the 2nd led red on the front.
hi,
  correct. I just put it there cuz, well, why not. I have the parts and it just looks cool. sorry, I just could not resist putting the led and resistor there.
Ken
Be careful there. The 4264 needs 256 cycle refresh and so won't work correctly with the older ANTIC chips. Also MT branded RAMs have a poor reputation.
If you read the manuals for the 1064 it explains how banking is done.  I don't think it is compatible at all with anything that was done which explains why no test will show it.  I encourage someone to write a test.  😀
Perhaps with a program that will be loaded first, it will make the card compatible, such as with atari translator disk software ???
