arudzki #1 Posted January 18, 2021 All, I have a question about sending out serial messages from the XL/XE. If I have a board with a UART on it, can I just use the DATAIN, DATAOUT and COMMAND signals on the SIO port and handle the serial communication myself with code and the POKEY registers? Secondly, are there any tutorials on doing this? Thanks in advance. Tony Quote Share this post Link to post Share on other sites
Rybags #2 Posted January 18, 2021 There's various methods of SIO that can be done - unclocked, clocked by internal or external source though most usage cases see the clocking done by Pokey. You can also bit-bang but it's a fairly rare thing - the default cassette handler the only OS based thing that uses it and only for determining timing requirements at the start of each block read. Pokey does the byte level IO automatically for you but it uses 0 start bit, 8 data bits lsb first then a 1 stop bit. You get no choice to change any of that (unless you bit-bang). Many external Atari and 3rd party peripherals just assume a default bitrate or use special commands to set a higher one and don't use the clocking facility. Generally the stop to start bit transition is sufficient to compensate for any slight timing differences. All the signalling is 0/5 Volt levels (though the specs have high/low voltage levels that are assumed for 0 & 1s) Depending on what you want to do you can either have your device behave like an Atari smart peripheral, waiting for the Command line to go low then reading the command frame and responding if the device ID matches your own. Or just act as a dumb peripheral, assuming it's the only device on the bus and deal with the raw serial data. Tutorials and such - not a great deal around I think. I wrote a 1050 emulator on the ST about 30 years ago and referred to the Atari OS and Hardware manuals - they have needed stuff like the framing and command protocols and timing requirements (e.g. if your device responds too fast it can be missed) I no longer have the source for it - I sold the ST I had and it was on floppies for DBasic which in itself is probably a lost product as it uses a custom 1K sector format. 3 1 Quote Share this post Link to post Share on other sites
djmips #3 Posted August 6, 2021 How do you bitbang on a Pokey. Can you use it as a 1 bit I/O to control a transistor for example. Turn on. Turn off. I understand the logic level is 4V on and 0 V off which falls into TTL logic spec. Just wondering how to take control of ensuring it goes true and false without worrying about it inserting start bits and stop bits. Quote Share this post Link to post Share on other sites
Rybags #4 Posted August 6, 2021 When nothing's going on there'll be "1" present on the output. There's an SKCTL bit called "force break" which forces output to "0". Toggling that bit is how you do bit-banging. Using /Command is optional for your own projects - in fact you'd probably be better off using Motor Control as having Command active while doing your own IO might confuse other peripherals. 2 Quote Share this post Link to post Share on other sites
TGB1718 #5 Posted August 6, 2021 On 1/18/2021 at 5:04 AM, arudzki said: I have a question about sending out serial messages from the XL/XE. If I have a board with a UART on it You could always use something like an Arduino, it has Serial Ports and also libraries for Software Serial if you want more than one Serial line Quote Share this post Link to post Share on other sites
