Spector
My Harmony Encore Cart is buggered!
I bought a Harmony Encore Cart in 2018 and have been playing it again recently, trying out some of the great Homebrews with melody enhancement. I was playing Space Rocks these last few days, and this morning when I turned the Atari on and selected it from the menu, I got the spinning ball in the middle of the screen as you do. But the spinning ball never went away, so after half a minute I turned the console off. I turned it on again to find a blank screen, then several more power cycles gave me various colours, vertical bars and sustained high pitch noises. In other words, it's buggered!!
I tried some other carts and there's no problem. I have to say I'm deeply disappointed because I've only been using the cart for less than two years on and off, and that's it broken already? My Cuttle Cart from 2001 still works fine, so I'm a bit angry. But are there any miracle suggestions to try and fix it?
Edited by Spector
Ha. I always wanted a Cuttle Cart.
I'd trade three PlusCarts for a Cuttle Cart :)
You should be able to reflash the firmware and get it going again. The instructions for doing so are in the manual located here: https://harmony.atariage.com/files/harmony_manual_v2_online.pdf
If you have question or have issues with the procedure, feel free to PM me and I can walk you through the process.
It's a big problem though because the PC is not recognising the Harmony Cart when I connect it. The red dot appears at the bottom of the pop up menu to show this. My USB cable works fine on that PC for recognising other devices, so the problem must be with the cartridge. It seems totally dead.
Which other devices? A USB cable that works with a digital camera, for example, is typically a 4-pin mini-B cable and this kind is not compatible with a 2018 Harmony cart. A 2018 Harmony cart needs a USB 5-pin mini-B cable.
And that could well be it! I am using a cable without knowing whether it's 4 pin or 5 pin. Didn't even though the differences existed. I use the cable for a digital camera and a Dictaphone device, and while I see on ebay that mini b 5 pin cables can also be used for cameras, I'm pretty sure that's why it's not being recognised, so I've ordered a 5 pin cable off ebay and I'll see what happens later this week when I get it.
I got the cable in today, a day later than advertised from an Ebay seller, took it out the packaging and... he sent me the wrong bloody cable. Talk about frustrating? 🥵😡
Edited by Spector
I finally have the right cable, but when I attach it to my PC it says "the last USB device you connected to this computer malfunctioned and Windows does not recognise it." Does that make the Harmony beyond repair?
Edited by Spector
Have tried to removing the bad/corrupt usb device/driver from the windows device manager and plugging it back in and having windows install a new usb driver?
Sent from my iPad using Tapatalk
I'm not sure what to do next to be honest. I'm not sure how to remove the corrupt usb device driver.
The update is that I received a Harmony Cart in the post today at the sorting office and tried it... and it works! Well well, thank goodness for that. The older one continues to not work at all and seems utterly fried. I would like to thank Batari for his help in this very awkward situation. Looking at this sub-forum, it doesn't seem too common that a harmony encore stops working completely, and that's what worried me. I'm just wondering if there's anything I did that could have caused it. All I was doing was turning it on and off to play games, and often only a couple of times per session. Maybe it was just a dud cart. Who knows?
Maybe you could send it back for diagnosis/post-mortem?
Yeah that seem the best option. And the only option really, cause I've not got much use for it now! I also think there is a chance it could be made to work again, even though it could be a bit complicated to do so.
Edited by Spector
I agree you should send it back so the problem can be diagnosed. Knowing what went wrong may be of help to others someday.
If @batari doesn't want it back for post-mortem, I'm in the market for one. I'd pay the postage + a bit extra and take a risk I could fix it.
I'll send a message to batari and see what he says. So good to play Space Rocks again🙂
Edited by Spector
Space Rocks is indeed amazing. And it's well-worth buying in cart form, if only to support @SpiceWare and encourage him to keep making amazing 2600 games. :)
