xxl
Most efficient compression for Atari
I add BitBuster - pretty fast, nice compression and very short procedure (even without the use of ZP).
BitBuster: 1774
https://www.cpcwiki.eu/forum/programming/dumb-question-15839-bitbuster-1-2/msg31362/#msg31362
In a few days I will complete the sources on the site - https://xxl.atari.pl/bitbuster-decompressor/
example of use:
debitbust6502.obx
Edited by xxl
Having run out of disk space for PoP (using APL), I thought it was time to have another look at the available compressors:
test file: 39,689 PoPCore.bin
23,972 PoPCore.bin.shrinkler (-d -p -9)
24,761 PoPCore.bin.zx0 (-f)
25,131 PoPCore.bin.apl
25,150 PoPCore.bin.deflate
25,201 popcore.bin.exomizer (-raw)
25,688 popcore.bin.packfire (-t)
26,712 PoPCore.bin.pucrunch
Shrinkler is better on paper, but its decoder is twice bigger than zx0 (+-450 bytes?) and takes 3KB of temp storage. the dealbreaker: it takes 1 minute to decompress while others are done in seconds!
ZX0 systematically beats APL by a few percent on every file I've tried. It decrunches very quickly as well (using Elmer's version which takes 192 bytes and a little bit of ZP).
ZX0 seems to be the best packer/depacker available right now for the A8. PoP just wouldn't fit on disk without it
Many thanks @xxl and @elmer for this very useful thread and converting those depackers. ( and Einar Saukas for the compressor )
  • Like 6
it's true, I can see a bright future for this decompressor for Atari and more and more people are seeing it. One cannot forget about the considerable speed of decopression and the ease of use.
I know that the new version of DC Montezuma's uses this decompression on the fly for levels without any slowdowns, especially since it is a version with a minimalist use of ZP :) (https://xxl.atari.pl/zx0-decompressor/)
On the last SV2020+1 one of the best coders did tests and was also surprised 🙂
MadPascal also has a module for this decompression ...
there is also a special boot loader for files packed with this compressor,
it can also be used when loading packed exe programs in .CAS files
... it is worth a try
Edited by xxl
  • Like 8
the ZX0 mutation appeared, the decompressor is slower, but the efficiency of the ZX5 takes the lead anyway. only the Shrinkler is higher (of the available Atari decompressors).
code translated from Z80 with minor optimizations.
https://github.com/einar-saukas/ZX5
The source of the decompressor for 6502 will be available tonight.
ZX5: 1532
zx5-gfx.obx
  • Like 5
Einar Saukas has changed the ZX0 format and published a new version of the v2 compressor - the new compressor is not compatible with the old decompressors!!!
https://github.com/einar-saukas/ZX0
below I publish the new decompressor:
http://xxl.atari.pl/zx0-decompressor/
if you used ZX0 v1 be sure to upgrade!!!
Hello @xxl,
This is an interesting thread, thanks for creating it. One small suggestion I have for improving it is to try a larger set of files than a single one, preferably with different content. Otherwise I think the results can be misleading.
Case in point: For a ST game I'm working on I tried a few packers mentioned in this thread just to see which produces the best packing ratio, and here's my results so far.
Test 1: 9 files of graphics (tiles) in ST interleaved bitplane format.
Original combined size: 144k
LSZA1: 31k
LZSA2: 27k
ZX5: 27k
Cranker: 35k
Exomizer (data mode): 29k
ZX0 v1: 29k
ZX0 v2: 29k
ARJBETA mode 4: 28k
ARJBETA mode 7: 24k
Of course this is half of the story, if I break the values down on a file-by-file basis I see that on some files zx0/zx5 takes the lead while on others zx0/zx5 perform much poorer than arjbeta. But on cumulative size arjbeta mode 7 takes the lead. Unfortunately this mode is not very practical for 8 bit machines as it requires a massive 13-14k table for depacking!
Test 2: The levels file
Original file size: 15607 bytes
LSZA1: 4147
LZSA2: 3785
ZX5: 3550
Cranker: 4345
Exomizer (data mode): 3469
Exomizer (level mode): 3486
ZX0 v1: 3627
ZX0 v2: 3627
ARJBETA mode 4: 3807
ARJBETA mode 7: 3426
I hope the above illustrates how differnt packers on different data sets can yield much different result than a single file!
(As to what packer I will probably use? I'll probably go for LZSA 2, in my case it is a good compromise between depacking speeds (very fast) and pack ratio (one of the better ones))
P.S. for completion's sake, here's what arjbeta manages with your reference conan.gfx:
ARJBETA mode 4: 1841
ARJBETA mode 7: 1657
As to where to get arjbeta - well, there hasn't been an official distro to my knowledge, but you could download the packer for windows from http://onorisoft.free.fr/jag/bjlpak.zip (which contains the mode 7 unpacker in 68k asm), and I can attach the mode 4 depacker here (again 68k asm)
mode4new.s
That's right, we should always test different methods on our data.
I'm saving the results - thanks.
in 68k world there are still PackFire and Shrinkler - both in two versions and both better than ARJBET, even lightning fast and practically no requirements PackFire Tiny.... check on your own data.
please note that the results can - and indeed do - vary considerably for data for 8-bit machines - above all, the size of the input file matters.
As for ZX5 and ZX0, actually in most cases ZX5 is stronger but there are examples that it is worse:
RiverRaid.ROM: 8192
LZ4          : 7414
BitBuster    : 6618
aPLib        : 6366
ZX5          : 6334
ZX0          : 6313
PackFire Tiny: 6284
Deflate      : 6192
Shrinkler NP : 6020
Landscape.xex: 30653
LZ4          : 16934
BitBuster    : 14591
PackFire Tiny: 13823
aPLib        : 13679
ZX0          : 13530
Deflate      : 13486
ZX5          : 13459
Shrinkler NP : 12764
Edited by xxl
would you please guide me i try to reproduce your results but i get this:
arjbeta.exe a -m4 conan.arj conan.gfx
file size: 1944
Betty's issues intro.dat (gfx+msx+code)         : 9˙086
zopfli  -v --deflate --i10000  : 4˙957
exomizer raw                      : 4˙870
bbpack                                : 5˙186
packfire -t                            : 4˙881
zx5                                     : 4˙805
I'll do that for sure, it's just that both packers take unreasonable amounts of time for my tastes to depack even the small files such as 4k or 8k (well, small for ST/Amiga in any case). Since my project will be loading in game, the depacking time won't be a one-time cost. Waiting for a game for a long time to change graphics data isn't very appealing to me. In any case I'll do some tests so we have an academic comparison.
file size: 1944
Certainly, and my mistake for not clarifying this in my post above. The file arjbeta generates is an actual ARJ achive, so it adds a lot of unnecessary header. This can be removed by using the "dumparj" command in the archive I linked. So,
dumparj conan.arj conan.gfx conan_packed_with_arj.gfx
will generate "conan_packed_with_arj.gfx" which can then be depacked using mode 4/7 routines.
Can't edit my post above so let's make another one for PackFire and Shrinkler.
Test 1:
PackFire (large model): 24k
PackFire (tiny model): 42k
Shrinkler: 23k
Test 2:
PackFire (large model): 3183
PackFire (tiny model): 3471
Shrinkler: 3188
So, PackFire seems pretty much equivalent to arjbeta mode7 for the graphics files, and for the levels file both PackFire and Shrinkler beat everything by a large margin. However, like I said in the previous post, I don't think I'll be subjecting people to slow depack speeds :).
unfortunately, I am not able to properly unpack the data with this 68k procedure, I suspect I have a wrong stream of packed data.
could you please attach the packed conan.gfx data?
Okay, I had a go at depacking the files myself and found a small "gotcha" of dumparj: it actually adds a 4 byte header which has the original file size (in big endian). So, in 68k code, the correct way to call the depacking routines is:
                lea     m4_pack,A1
                lea     m4_unpack,A0
                move.l  (A1)+,D0
                jsr     decode_m4
                lea     m7_unpack,A0
                lea     m7_pack,A1
                move.l  (A1)+,D0
                bsr     unarj
So, from the packed buffer we read the unpacked size, advance by 4 bytes, then call the depack  routines. Just for posterity I uploaded the packed files as well as the source code for both depackers, including a small addition by me to call the depackers and compare the bytes to the reference unpacked file.
Apologies for the confusion! Goes to show I shouldn't be writing hasty posts without testing...
conan.m4 conan.m7 UNPACK.S
thanks to this procedure (and the mini emulator 68k on 6502 - the decompressor code on this emulator took over 1KB and after optimization to 6502 only about 200 bytes) we read the compressor data format, 6502 decompressor by Konop, Rastan, xxl
in general ... the procedure is rather slow, and the compressor itself does not sin with efficiency, but I am placing it as a chronicler ;-)
unarj4-gfx.obx
As you can easily see ARJ m4 wastes bits encoding the amount of data to copy from the dictionary, for example to encode length 255 it needs 14 bits. It also has a limitation for the offset to 4 KB - this is already an overkill even for 8bit machines.
Source for the decompressor available here: https://xxl.atari.pl/arj4-decompressor/
35 minutes ago, Estece said:
I will throw a lossy idea for conan.gfx image compression.
DXT1 aka S3TC for atari,any one?
easy: dxt1 is 4bit per pixel so a 2bit per pixel image of 7680 bytes will "compress" down to 15360 bytes 👍
  • Haha 2
Unfortunately this thread will no longer be updated by me, if there is something new it will be directly on the site: https://xxl.atari.pl/
in the menu on the right are procedures to use in your own programs.
  • Confused 1
Not that I'm expecting it to beat other compressors - but did anyone ever try Scrunch on this test?   I remember that being the first compression utility I ever came across..
