Magnus Clyde
The exact speed of the TIA
The Atari 2600 main clock is 3.58 mhz which is fed to the TIA chip.  The TIA chip divides this by 3 to provide the CPU clock running at 1.19mhz.
3.58 mhz is the frequency used by the NTSC color sub-carrier.
I mean, how precise do you want it? This is the Phi0 clock signal being fed into SALLY on a 7800 while playing a 2600 game:
And this is the OSC input to the TIA from the NTSC crystal on the board:
20 minutes ago, ClausB said:
1,193,182 Hz
I understand there are slight differences between PAL/NTSC/SECAM but I don't know the exact figures.
NTSC
TIA CLOCK    =     3579545 Hz
CPU CLOCK    =    1193182 Hz
PAL
TIA CLOCK     =    3546894 Hz
CPU CLOCK    =    1182298 Hz
SECAM
TIA CLOCK    =    3562500    Hz
CPU CLOCK    =    1187500    Hz
PAL-M
TIA CLOCK    =     3575611 Hz
CPU CLOCK    =    1191870 Hz
