SoundGammon
Space Invaders Deluxe Roklan version.
Roklan was working on an official conversion back then.  I found a prototype but I can’t get it to work.
Maybe "compile" them into one 16k chip!
Tried that, didn’t work.
Just now, SoundGammon said:
Maybe it's the 8-bit version.
Nope, found on a 5200 board in a 5200 case.
Is it known who at Rocklan was working on the official conversion?
No, it is not known who was working on it.
Bump.  Has anyone looked into this?  How close is the code to the 8-bit version?
Posted (edited)
This is unlikely to work. The dumps seem to be correct, but there is a lot of unused space in them. The 8-bit version is 8K in size. These 3 chips contain only about 4K of data.
The HI chip is mostly empty, except for the init vectors at the end, so it should be mapped to $B000-$BFFF.
The LO-MID chip is fully filled, while the HI-MID chip only contains data in the first $50 bytes. I believe this is correct though - when joined together, LO-MID and HI-MID matchthe last ca. 4K of the 8-bit version. It seems that LO-MID should be mapped to$7000-$7FFF and HI-MID to $8000-$8FFF.
The issue is, there is no data on the chips that would match the first 4K of the 8-bit version. The init vector points to $6047, which means that the missing 4K should be mapped to $6000-$6FFF.
Overall, this cartridge seems to use the "Two chip 16 KB 5200 cartridge" mapping. The ROM image should be formed by joining the missing 4K, LO-MID, HI-MID and HI in that order, to form the following memory mapping:
???    -> $4000-$4FFF, $6000-$6FFF
LO_MID -> $5000-$5FFF, $7000-$7FFF
HI_MID -> $8000-$8FFF, $9000-$9FFF
HI     -> $A000-$AFFF, $B000-$BFFF
Edited by Kr0tki
Thanks for confirming.  I guess we need to find that missing chip.  Sounds like the game was going to be the same as the 8-bit version though.
I don't know much about ROM reading, but is it possible that LO-MID is in fact an 8K chip that was dumped as a 4K one?
Wouldn't they all have to be the same size?
Not necessarily - it depends on the wiring of the cartridge PCB. I suppose that for prototyping they might have been using PCB's that are universal, i.e. accept either 4K or 8K chips in the sockets.
The chips were found on a standard Atari made 5200 board.  The chips were read correctly and are in fact the correct size.
I thought so.  So one is missing then.  Bummer
