ratwell
The best video to HDMI converter
Posted (edited)
13 hours ago, snicklin said:
What is the inherent problem with RF? Why is it so poor? Is it a standard that could produce decent output if there were decent cables? Or is there a quality problem that RF could never overcome?
RF modulators inside low-budget computers were made as cheaply as possible and by the millions.
Splitting audio and video into separate signals to improve image quality always worked towards improving the image quality (composite -> s-video -> component -> etc) and reduce signal losses.
Having said that, were these low-res games any less fun when played on a 1977 CRT?
The blurring of low-res images was also somewhat helpful reducing the obvious pixelation now easily seen via emulators.
Edited by ratwell
Posted (edited)
On 4/10/2021 at 5:47 AM, ratwell said:
Here are some screen captures from an 800XL -> RetroTink 2x Mini -> Elgato Cam Link. The stock S-Video in B&W is the giveaway it's an 800XL.
I was wondering if I should expect the same from my XEGS with a S-Video cable on it?
edit: without any extra hardware. Is it worth it to upgrade from composite to S-video on my XEGS?
Edited by Zeptari1
The XEGS does not have S-Video, so without hardware modification you are out of luck. The composite video on the stock XEGS is actually pretty good.
Posted (edited)
On 4/10/2021 at 2:47 AM, ratwell said:
Q: I have a replacement logic board which doesn't quite allow the monitor output jack to align with the opening in the case. I guess Atari changed this towards the end of the XL production run? Has anyone else run into this issue?
This is what I'm talking about:
Edited by ratwell
A kind soul sent me a pm with this info:
Quote
All Rev C and D machines I have carry a smaller 'whole'. The diameter was resized from approx. 2 cm on the Rev A machines to ca. 1.78 cm on the Rev C and D ones.
Thanks!
That looks way out of alignment. What does the PBI slot look like? Are you sure the motherboard is settled properly in the bottom shield, and the shield is settled in the case?
Posted (edited)
The motherboard is sitting high in that photo above looking at the edge connector:
Edited by ratwell
3 hours ago, ratwell said:
Got the same email overnight. That’s a lot of money for a scaler. And still no guarantee that it won’t choke on the screwy video timings of a 2600 (which the 2X-Pro can and does for some titles), or that an out-of-spec A8 or 5200 title won’t throw it for a loop with extra or fewer lines in the ANTIC Display List. I’ll hold onto my money for now.
Compared to the RetroTink 2X-Pro, they added +145 USD for Scart and remote control, ouch. Now the price comes close to a Framemeister, which was simply too expensive for me.
Besides, which RetroTink gives good/best results for the A8 (PAL or NTSC), the 2X Mini, the 2X Classic or the 2X Pro ?!?  Or are they all good/very good for the A8 via composite/S-Video ?
I have a 2X-Pro and it’s very good for an A8 via S-video or composite from my UAV-equipped machines.
Has anyone given the RetroTink 2X mini a try with our Atari systems?
It's the cheapest version they offer at $79.99, but will still do S-Video to HDMI conversion.
I bought one on recommendation from AtariAge members and it has worked great.
No audio passes through unless there is a video signal is the only shortcoming I’ve noticed so far.
Well, then or now. I picked my Framemeister up for the same price as this new Retrotink, but now they cost $500-$1000 due to it not being made any more and demand still there. Given that their pricing is maybe not too crazy.
I like Retrotink products, I have a couple for different rooms, but some of their claims on here about "first scalar doing X" features - well, I guess they're not counting the Framemeister since it isn't available any more, because it has about all of these features.
Not good when playing sounds, samples, etc. with Poke 559,0 / screen off...  :-(
What about the 2X Pro - does it have audio passthru even when there is no video signal?
I'm trying to think of when this might be an issue. When would be a time that you had no video signal but wanted audio, or would even have audio, at least in relation to an Atari?
Look up
I doubt it. The 2X-Pro is a simple (albeit nice) line-doubler and HDMI converter. If there is no signal to double, it will have no signal to pass through as HDMI.
Hey @DrVenkman. How well does your hdmi converter function with Battlezone 2600?  I had the chance to get a retrotink classic clone for $35 and took it. It is great, except for that game...
1 hour ago, Stephen said:
Look up
OK, I guess I'm having a dense moment. I'm coming up blank.
Sorry - it was in the post directly above your question.
The reason would be, many older demos that did sample playback, have to disable ANTIC screen DMA (in BASIC, this would be POKE 559,0).  I believe the Software Automated Mouth program also blanks the screen when "talking" to avoid glitches in the voice.
Posted (edited)
Oh! gotcha...
Still, the computer was on, and you were playing samples or something with the screen off, but the computer on, it's still putting out a signal, right, even if the screen is black?
I guess if it completely disables ANTIC though...
Edited by bfollowell
50 minutes ago, bfollowell said:
Oh! gotcha...
Interesting question - not that I think about it, I guess the machine is still outputing video with sync pulses, just a black screen.  I saw this because when I pull a video cable out of my PVM, it will say "No sync" but turning off the screen DMA does not cause that, nor does the screen roll.  So yeah - my guess is that the device would still let audio pass.
Terrible. :) I've posted about it somewhere around here in one of the forums. I've also had problems with Activision Starmaster which flat doesn't work, and with Parker Bros. The Empire Strikes Back, which works but destroying a walker makes the screen go nutty for a second.
