Sign in to follow this
KG7PFS
Apple RAM Expansion in the IIc Plus?
I've read that the Apple RAM expantion for the IIc is not compatible with the IIc Plus. Is that true? Is there an easy way to fix it? I just ordered one and I need to know witch "c" to put it in.
I don't claim to be an expert on this, but I have a IIc and IIc Plus. From what I understand, a ROM 255 or 0 IIc can't use a memory expansion. If you have a ROM 3 or 4 IIc then I think you are good.  I purchased an expansion from a2heaven for my IIc then realized it was not the proper ROM level to use it, so I installed it in my IIc Plus!
From my experimenting with RAM cards, only the RAM Express works with the IIc+.  ZRAM 2 and 3 do not work with the IIc+, but works with the Iic's with expansion port.
Ah yes, that's what I bought for my II c before realizing it would not work in my II c due to the firmware revision.
Apple IIc RamExpress II+
So OP, I guess it depends on which memory expansion card you have. I'd also check the ROM revision as well.
