Andrew Davie
Wizadry on the Woodgrain - Tiki
Proposal:  Wizadry on the Woodgrain - Tiki
I thought it might be worthwhile to have a comprehensive Wiki/Tiki - a single place where all the accumulated technical knowledge could be stored.
The concept is a place where the technical information can be brought together in a curated and carefully crosslinked reference to programming the machine, with the technical details as thorough as possible. If you want to know something about colours/palettes, then you'd go to the above page.  It's only a brief start, of course, and the rest of the tiki at the moment is just garbage from the default install I did.
But it does seem to be working properly, and I'll be making some effort whenever new stuff pops up to add a note to the tiki and slowly it will, I hope, become a valued resource for all of use. I invite you to join/register and add content as you think fit.
My approach will be to always link to original sources, where appropriate, but also have a local copy of relevant information so that it is not lost. For example, if something is mentioned here on the forum then the tiki should link to that post - but also preserve the technical content so that it is readable in-context with the rest of the information each tiki page is discussing.  Attribution is very important.
Anyway, so that's the plan. As with all things, one might lose interest -- but I hope that several of you may find some use/interest in participating in this.  As an aside, in collating the small bit of information about colours I have already come across a few things that I had forgotten about... and also run into a few broken links on stuff that I wanted to know about. Hopefully this will fix all that.
Edited by Andrew Davie
new URL
  • Like 7
  • Thanks 3
Now live. The minor hiccup was I had to install PHP7.x for the tiki, which totally broke an old forum that I run that is "stuck" on PHP5.x
That's something I felt it was needed for quite some time, as there's so much info resulting from the last over two decades of homebrew scene that is hard to find because it is scattered all over the place.
I hope many people will participate to add contents. 👍
As is normal with these things, it takes someone to start it and make it useful for others. It's not useful yet as it has no content, but if I keep at it for a while eventually someone else will join in and then the ball's rolling.
Good stuff, Andrew. Definitely something that's needed.
If you find any value in taking stuff from the 7800 dev wiki TIA guides, help yourself. It already has wiki markup, which might be helpful.
I think the "local copy" part of your first post is very important. Stuff tends to go away.
... as a for-example, a single reference point documenting all of the bankswitching schemes, how they work, and sample source code both for usage and in emulator code... would be very useful. I'll make a start.
  • Like 4
Finally, a place I can go to that will (or at least potentially) have all the bankswitching schemes.  I usually end up running into at least two different versions of Kevin Horton's document when searching for that information.  Thanks!
3 hours ago, Andrew Davie said:
I've completed a first-pass on all of the bankswitching schemes...
http://www.taswegian.com/WoodgrainWizard/tiki-index.php?page=Bank-Switching
Cool. You can also find some bankswitching info in the Stella's header files of the CartXY classes.
I've been through already and grabbed what I can.
Some have little documentation so will need more work to get the details.
This is a great idea. Having the bankswitching stuff there for reference alone makes it worth it, but there's a ton of possible useful content. Hopefully devs will end up making use of this, and add a lot of useful content.
Kind of off topic but, "This site contains technical information about the Atari 260 game system."
S/b 2600.
Edited by BigO
S/b 2600.
TY. Fixed.
You know you could have registered and edited/fixed that one yourself and had all the satisfaction and that warm glowy feeling instead of me...
My point being it's a wiki and designed for everyone to particpate... don't be shy.
I registered and got:
Note
  • Account validated successfully.
 Error
You do not have permission to view this page.
54 minutes ago, Andrew Davie said:
TY. Fixed.
Regarding that - I registered as Karl G, and confirmed my email with the link, but when I am logged in I don't have permission to even view pages. Do you need to do something on your end to validate my account first?
Sorry, new to the forum software and how it works.
I'll look into it ASAP.
I think I may have found the settings and fixed.
Bizarrely, by the default install, non-logged-in users had higher permissions than registered users.
Just now, Thomas Jentzsch said:
Seems to work now. :thumbsup:
BTW: Why did you name "F8" as "F8 and F9"?
I will fix this. I was just block-copying documentation from here there and everywhere without really studying it. I found F8/F9 and thought it curious, but kept it until I understood more about why F9.  Please feel free to edit/fix :)
1 hour ago, Thomas Jentzsch said:
How can I edit the name of a page?
I have fixed that one already.
I had that option disabled as I didn't think we would want registered users to change page names.
I'll enable it tomorrow ASAP.
But normally when you're on a page it appears as a page on the bottom "RENAME"
@Andrew Davie did you choose the "taswegian.com" domain on purpose? Maybe (a subdomain) of your other ".org" domain would be better for SEO reasons. Also for SEO reasons you should fill the keywords list.
I have registered even though I am sure there is not much I can contribute except maybe a chapter about PlusROM functions if you like.
It was just what was convenient.
I'm reluctant to use atari2600.org for anything/much as there's some legal agreement with Atari regarding my use of it, and to be honest I have (1) forgotten what the agreement was exactly and (2) it stresses me out to even think about that company and having to deal with their lawyers again.
  • Haha 1
100% understandable, nobody wants to waste lifetime with lawyers.
But maybe someone else is interested into the domain?
