Harry Potter
cc65 Atari 8 disk access?
I am wondering how to handle drive access on an Atari 8 computer using cc65.  I am also wondering how to handle keyboard input from assembler.  I want to create Atari 8 ports of SimpleIO, MadLib and Template Creator.  BTW, should I advertise Template Creator for DOS and Windows here?
Well, you could use the usual C suspects such as fopen, fread, fscanf, etc.. Or you could go down 1 layer to the CIO routines, which involves filling out a memory structure and calling a few OS routines. See De Re Atari and/or Mapping the Atari for more info.
https://www.atariarchives.org/dere/chapt08.php#H8_6
https://www.atariarchives.org/mapping/memorymap.php
Edited by danwinslow
small example of cc65 code, just checks a file exists :-
    // gets input filename and checks if it exists
int getinfile(void)
    int done=0;
    char ret;
    FILE *finput;
    char infile[30];
    gets(infile); // dummy to clear buffer of CR
    do
        clearline(0,12);
        clearline(0,10);
        printf("Enter Input Filename (RETURN to Abort)");
        clearline(0,11);
        gets(infile);
        if((strlen(infile)) == 0) // CR so abort
            return(1);
        ret = checkfile();
        if(strlen(infile) > 30)
            clearline(0,12);
            printf("Filename too long %s",infile);
            delay(90);
        else
            finput=fopen(infile,"r"); // check if file exists
            if(finput == NULL)
                clearline(0,12);
                printf("File does not exist");
                delay(90);
            else
                fclose(finput);
                done=1;
    }while(!done);
    return(0);
I thank you for your information.  All I really need that can't be accessed via the ANSI C functions is the file attributes.  I don't know how to access the attributes of an Atari 8 file.
Edited by Harry Potter
I forgot to mention something.
If your using Spartados X there's a section on file attributes using the ATR command, reading the attributes doesn't seem
to be covered (at least I can't see it).
It will also depend on what DOS your using, in Atari DOS's I think you can only lock a file and the way to see that
is open the disk directory and look for a "*" in the filename.
Here's a quick BASIC program that opens the directory and displays the contents
1 TRAP 100
10 OPEN #1,2,0,"D:*.*"
20 GET #1,A
30 ? CHR$(A);
40 GOTO 20
100 CLOSE #1
READY
RUN
* DOS     SYS 037
* DUP     SYS 042
CENT2021M65 009
CENT2021ASM 016
CENT2021OBJ 002
TESTBOOTOBJ 018
CENTNEW M65 016
CENTNEW OBJ 004
CENTNEW ASM 031
* TEMP00  ASM 007
532 FREE SECTORS
READY
I think the only way is to use direct CIO calls as @danwinslow  said, you would need to set the AUX1 byte to 2, in the OPEN then
read a character at a time to retrieve the directory listing .
Probably easier to do it as an assembler procedure within cc65
Edited by TGB1718
In CC65 there is one more intermediate layer between C functions (like fopen, fread etc) and OS routines:
#include <fcntl.h>
with functions such as open, read, write etc. - they are smaller variants of the fXXX functions.
16 hours ago, Harry Potter said:
I have everything I need; thank you.  :)  Just one more question: How do I read the directory from a cc65 program?
opendir/readdir/closedir
What attributes are you talking about?
I think he means things like size, date, etc. He might also mean permissions, but  of course most 8bits are anarchy in that department. It's an interestig question though - do any 8bits have anything like file ownership and individual r/w permissions?
Going OT because I can and the OP has already said he has quite enough info/
#include <fcntl.h>
Yep, true, and that's  actually part of the base C library on any box, which is why I lumped it all in together.
Did a bit of checking, I think the answer is that cc65 does not support retrieving file attributes, in C you can use the stat() function.
Although cc65 has the header file sys/stat.h it is all but empty, it should at the very least have this:-
struct stat {
    dev_t     st_dev;     /* ID of device containing file */
    ino_t     st_ino;     /* inode number */
    mode_t    st_mode;    /* protection */
    nlink_t   st_nlink;   /* number of hard links */
    uid_t     st_uid;     /* user ID of owner */
    gid_t     st_gid;     /* group ID of owner */
    dev_t     st_rdev;    /* device ID (if special file) */
    off_t     st_size;    /* total size, in bytes */
    blksize_t st_blksize; /* blocksize for file system I/O */
    blkcnt_t  st_blocks;  /* number of 512B blocks allocated */
    time_t    st_atime;   /* time of last access */
    time_t    st_mtime;   /* time of last modification */
    time_t    st_ctime;   /* time of last status change */
So a simple piece of code to use it could be:-
int main ( int argc, char *argv[])
    struct stat MyStat;
    if(argc <= 1)
        printf("Usage:= mystat <filename>\n");
        exit(1);
    if (stat(argv[(argc - 1)], &MyStat) < 0)
        printf("Error = %s\n", strerror(errno));
    else
        printf( "File Permissions:= %d\n", MyStat.st_mode );
    return 0;
Yes, that's missing in cc65. I've also noticed that now.
Do you know how to get that information inside the "stat" struct on the Atari? MyDOS, Sparta, AtariDOS would be the main targets.
I think you would have to write something yourself to deal with those as they have different attributes, Sparta has the most features
I think, but as I said before, I know how to set attributes, but not found a way to see them, AtariDOS, it's the "*" in the filename for
a locked file, so fairly easy to detect that, I've not used MyDos, but you may find some info here :- http://www.mathyvannisselroy.nl/mydos.htm
By "attributes" I mean anything attached to a file that may need to be preserved when copying a file.  If that is not necessary, then I have everything I need. :)
Have a look at SpartadosX Copy command, it does allow for some attributes to be preserved
These switches are available:
/B - backup mode
/C - confirmation mode
/D - do not preserve date and time
/I - ask before overwriting a file
/K - copy and set attribute '+A' to the original file
/M - delete the source file (move)
/N - skip existing destination entries
/Q - do not print anything (except error messages)
/R - dig recursively into subdirectories
/S - switch off display during copy
/V - summary (number of files and directories copied)
Look at the 'stat' struct posted before. I would need to programmatically query this info (when available, uid for example doesn't exist on the Atari DOSes I know)
@Harry Potter What are the use-cases in the library/wrapper you are building for these - on the A8 platform they aren't too much use, with the exception of SpartaDos where, say you wanted to make a Make tool, then timestamps would be useful. But in stock Atari DOS you've typically only got a 'deleted' or 'locked' flag to go with, no timestamp.
Edited by Wrathchild
Okay.  SimpleIO is a quick-and-dirty solution for writing to the screen and accepting keyboard input that uses the kernal directly; MadLib is my version of the MadLib word game with eight stories, and Template Creator is a program that can derive new files from old ones.
Hmmm,
file status? Something like:
normal file
file locked
file deleted
file not closed
<filename.ext> file occupies sectors beyond 720
  (Atari DOS 2.5 and compatibles in 130k format)
file beyond sector 720 and locked
file beyond sector 720 and deleted
file beyond sector 720 and not closed
file uses both sides of a disk (e.g. on a 360k disk)
not a file, just a DIR comment (usually with a length of 000 sectors)
sub-directory (MyDOS, SpartaDOS, etc.)
Maybe a XIO 13 (status request) can help here ?
