Lumpy01 #1 Posted March 8 So, I picked up a FujiNet a few months ago and finally got the time to play around with it. I didn't get very far. It just doesn't boot. Things I've tried so far: Every conceivable button combination. The serial logs when booting while connected to the latest flash utility tell me nothing. I successfully flashed it to the latest firmware with no impact on booting. I tried it with a 5v USB power supply attached even though I read it's not necessary on the 130XE's. I get the same results on two different 130XE's. I tried it on a 1200XL (with the 5v SIO fix) with the same results. I know it's probably something simple. What the heck am I doing wrong? Video attached. Pay no attention to the portly shiny-headed reflection in the monitor.🙂 FujiNet.mp4 Quote Share this post Link to post Share on other sites
mozzwald #2 Posted March 8 12 minutes ago, Lumpy01 said: So, I picked up a FujiNet a few months ago and finally got the time to play around with it. I didn't get very far. It just doesn't boot. Things I've tried so far: Every conceivable button combination. The serial logs when booting while connected to the latest flash utility tell me nothing. I successfully flashed it to the latest firmware with no impact on booting. I tried it with a 5v USB power supply attached even though I read it's not necessary on the 130XE's. I get the same results on two different 130XE's. I tried it on a 1200XL (with the 5v SIO fix) with the same results. I know it's probably something simple. What the heck am I doing wrong? Video attached. Pay no attention to the portly shiny-headed reflection in the monitor.🙂 The SIO LED is constantly lit which means something isn't right. Can you paste the serial debug log output of a boot attempt? It may tell you nothing, but it may tell us something Quote Share this post Link to post Share on other sites
Lumpy01 #3 Posted March 9 23 hours ago, mozzwald said: The SIO LED is constantly lit which means something isn't right. Can you paste the serial debug log output of a boot attempt? It may tell you nothing, but it may tell us something Using 'COM3' as serial port. Showing logs: [19:11:22]BUTTON_B: LONG PRESS [19:11:22]ACTION: Reboot [19:11:22]Shutting down device 5a [19:11:22]Shutting down device 43 [19:11:22]Shutting down device 50 [19:11:22]Shutting down device 40 [19:11:22]Shutting down device 99 [19:11:22]Shutting down device 45 [19:11:22]Shutting down device 70 [19:11:22]disk UNMOUNT [19:11:22]disk UNMOUNT [19:11:22]disk UNMOUNT [19:11:22]disk UNMOUNT [19:11:22]disk UNMOUNT [19:11:22]disk UNMOUNT [19:11:22]disk UNMOUNT [19:11:22]disk UNMOUNT [19:11:22]Shutting down device 5f [19:11:22]Shutting down device 78 [19:11:22]Shutting down device 77 [19:11:22]Shutting down device 76 [19:11:22]Shutting down device 75 [19:11:22]Shutting down device 74 [19:11:22]Shutting down device 73 [19:11:22]Shutting down device 72 [19:11:22]Shutting down device 71 [19:11:22]Shutting down device 38 [19:11:22]Shutting down device 37 [19:11:22]Shutting down device 36 [19:11:22]Shutting down device 35 [19:11:22]Shutting down device 34 [19:11:22]Shutting down device 33 [19:11:22]Shutting down device 32 [19:11:22]Shutting down device 31 [19:11:22]All devices shut down. [19:11:22]WIFI_EVENT_STA_STOP [19:11:22]Shutdown handler called [19:11:23][19:11:23] [19:11:23]--~--~--~-- [19:11:23]FujiNet 0.5.d4cb81e3 2021-02-24 05:19:32 Started @ 4 [19:11:23]Starting heap: 4056764 [19:11:23]PsramSize 3917592 [19:11:23]himem phys 4456448 [19:11:23]himem free 4456448 [19:11:23]himem reserved 262144 [19:11:23]FujiNet Hardware v1.0 [19:11:23]SPIFFS mounted. [19:11:23]E (1253) vfs_fat_sdmmc: mount_to_vfs failed (0xffffffff). [19:11:23]SD mount failed with code #-1, "ESP_FAIL" [19:11:23]fnConfig::load [19:11:23]No config found - starting fresh! [19:11:23]WIFI_EVENT_STA_START [19:11:23]disk MOUNT [19:11:23]ATR MOUNT [19:11:23]mounted ATR: paragraphs=5760, sect_size=128, sect_count=720, disk_size=0 [19:11:23]Creating a default printer using FS_SPIFFS storage and type 1 [19:11:23]SSH client initialized. [19:11:23]ModemSniffer::ModemSniffer(FS_SPIFFS) [19:11:23]SIO SETUP [19:11:23]Set HSIO baud from 0 to 67431 (index 6), alt=68209 [19:11:23]Available heap: 3969820 [19:11:23]Setup complete @ 460 (456ms) [19:11:32] [19:11:32]CF: 00 ff c0 00 00 [19:12:47][19:12:47] [19:12:47]--~--~--~-- [19:12:47]FujiNet 0.5.d4cb81e3 2021-02-24 05:19:32 Started @ 4 [19:12:47]Starting heap: 4056764 [19:12:47]PsramSize 3917592 [19:12:47]himem phys 4456448 [19:12:47]himem free 4456448 [19:12:47]himem reserved 262144 [19:12:47]FujiNet Hardware v1.0 [19:12:47]SPIFFS mounted. [19:12:47]E (1253) vfs_fat_sdmmc: mount_to_vfs failed (0xffffffff). [19:12:47]SD mount failed with code #-1, "ESP_FAIL" [19:12:47]fnConfig::load [19:12:47]No config found - starting fresh! [19:12:47]WIFI_EVENT_STA_START [19:12:47]disk MOUNT [19:12:47]ATR MOUNT [19:12:47]mounted ATR: paragraphs=5760, sect_size=128, sect_count=720, disk_size=0 [19:12:47]Creating a default printer using FS_SPIFFS storage and type 1 [19:12:47]SSH client initialized. [19:12:47]ModemSniffer::ModemSniffer(FS_SPIFFS) [19:12:47]SIO SETUP [19:12:47]Set HSIO baud from 0 to 67431 (index 6), alt=68209 [19:12:47]Available heap: 3969820 [19:12:47]Setup complete @ 471 (467ms) [19:13:35]CF: 00 f8 31 53 00 Quote Share this post Link to post Share on other sites
mozzwald #4 Posted March 9 48 minutes ago, Lumpy01 said: [19:11:22]BUTTON_B: LONG PRESS [19:11:22]ACTION: Reboot It appears that you get one command frame from the Atari and then the FujiNet resets and there's one more command frame at the end. Try getting the logs with the following process: 1. Plug Fujinet into Turned off Atari 2. Plug microusb cable from PC into Fujinet 3. Load FujiNet Flasher and press the serial debug button 4. Short press the RESET button (far right button) on the Fujinet. You should see the startup messages from fujinet on the PC 5. Turn on Atari 6. When Atari is finished attempting to boot, copy and paste the debug output here Quote Share this post Link to post Share on other sites
Lumpy01 #5 Posted March 9 11 minutes ago, mozzwald said: It appears that you get one command frame from the Atari and then the FujiNet resets and there's one more command frame at the end. Try getting the logs with the following process: 1. Plug Fujinet into Turned off Atari 2. Plug microusb cable from PC into Fujinet 3. Load FujiNet Flasher and press the serial debug button 4. Short press the RESET button (far right button) on the Fujinet. You should see the startup messages from fujinet on the PC 5. Turn on Atari 6. When Atari is finished attempting to boot, copy and paste the debug output here Using 'COM3' as serial port. Showing logs: [20:27:07][20:27:07] [20:27:07]--~--~--~-- [20:27:07]FujiNet 0.5.d4cb81e3 2021-02-24 05:19:32 Started @ 4 [20:27:07]Starting heap: 4056764 [20:27:07]PsramSize 3917592 [20:27:07]himem phys 4456448 [20:27:07]himem free 4456448 [20:27:07]himem reserved 262144 [20:27:07]FujiNet Hardware v1.0 [20:27:07]SPIFFS mounted. [20:27:07]E (1253) vfs_fat_sdmmc: mount_to_vfs failed (0xffffffff). [20:27:07]SD mount failed with code #-1, "ESP_FAIL" [20:27:07]fnConfig::load [20:27:07]fnConfig::load read 305 bytes from config file [20:27:07]WIFI_EVENT_STA_START [20:27:07]disk MOUNT [20:27:07]ATR MOUNT [20:27:08]mounted ATR: paragraphs=5760, sect_size=128, sect_count=720, disk_size=0 [20:27:08]Creating a default printer using FS_SPIFFS storage and type 1 [20:27:08]SSH client initialized. [20:27:08]ModemSniffer::ModemSniffer(FS_SPIFFS) [20:27:08]SIO SETUP [20:27:08]Set HSIO baud from 0 to 67431 (index 6), alt=68209 [20:27:08]Available heap: 3969852 [20:27:08]Setup complete @ 461 (457ms) [20:27:20][20:27:20] [20:27:20]--~--~--~-- [20:27:20]FujiNet 0.5.d4cb81e3 2021-02-24 05:19:32 Started @ 4 [20:27:20]Starting heap: 4056764 [20:27:20]PsramSize 3917592 [20:27:20]himem phys 4456448 [20:27:20]himem free 4456448 [20:27:20]himem reserved 262144 [20:27:20]FujiNet Hardware v1.0 [20:27:20]SPIFFS mounted. [20:27:20]E (1253) vfs_fat_sdmmc: mount_to_vfs failed (0xffffffff). [20:27:20]SD mount failed with code #-1, "ESP_FAIL" [20:27:20]fnConfig::load [20:27:20]fnConfig::load read 305 bytes from config file [20:27:20]WIFI_EVENT_STA_START [20:27:20]disk MOUNT [20:27:20]ATR MOUNT [20:27:20]mounted ATR: paragraphs=5760, sect_size=128, sect_count=720, disk_size=0 [20:27:20]Creating a default printer using FS_SPIFFS storage and type 1 [20:27:20]SSH client initialized. [20:27:20]ModemSniffer::ModemSniffer(FS_SPIFFS) [20:27:20]SIO SETUP [20:27:20]Set HSIO baud from 0 to 67431 (index 6), alt=68209 [20:27:20]Available heap: 3969852 [20:27:20]Setup complete @ 463 (459ms) [20:27:25] [20:27:25]CF: 00 31 53 00 00 Quote Share this post Link to post Share on other sites
mozzwald #6 Posted March 9 9 minutes ago, Lumpy01 said: [20:27:08]Setup complete @ 461 (457ms) [20:27:20][20:27:20] [20:27:20]--~--~--~-- [20:27:20]FujiNet 0.5.d4cb81e3 2021-02-24 05:19:32 Started @ 4 Similar results. Sounds like a hardware problem to me. Contact your vendor about a replacement Quote Share this post Link to post Share on other sites
